Mozes nalog i hard da prebacis na drugu nebanovanu konzolu.
Jel ban sledi samo ako se wave 4 igre konvertuju u wave 3 ili i ako se koristi na 1.6 firmware-u aktivacioni disk za startovanje wave 4 igara?
Ako imas flesovanu konzolu ban ce da usledi u 90% slucajeva ne vezano za wave 4 ili activation disc, osetio sam to na svojoj kozi na zalost
Da nisi možda iša online sa igrom koja još nije zvanično izašla?
ima li nekih naznaka da bi se moglo uciniti "nesto" kako bi hardovi postali upotrebljivi za instalaciju igara na banovanim konzolama? da li se uopste moze ocekivati neko resenje ili su prakticno dozivotno osudjene na DVD citac?
FW je definitivno problem. Koliko vidim najvise je ljudi naebalo sa 1.60 FW.
Ja imam FW 1.60 i čak imam spoofed dvd drive ( navodno još veći rizik ) i stalno sam na live-u i nisam banovan, tako da mani se "definitivnih" zaključaka
Recent estimates have said over 1 million gamers have been affected by Microsoft's 360 bans. Modders have attempted to free users from Microsoft's grip by releasing what is known to us as "iXtreme LT". According to a forum post on Xbox-Scene you can now unban your Xbox 360.
"what you need:
your 8955 live console + cpu key
a 2nd unbanned console
nandpro b + flash cable
xell loader
degraded
1888 fs
robinsod's flashtool
process:
use nandpro and dump nand from unbanned console.
flash xell and use jtag hack to obtain cpu key.
use flashtool to extract file system.
dump nand from 8955 console.
use flashtool to patch nand dump with kv.bin from unbanned console.
save patched file (patched_kv.bin).
open degraded + 1888 fs.
create 1888 downgrader image (downgrader.bin) from your patched_kv.bin file.
flash downgrader.bin to 8955 console.
attach hdd + ethernet cable and boot console.
connect to live and update to 8955 dashboard.
console is now fully working and unbanned!"
Nadjeno resenje za povratak HDD-a (tako kazu):
http://forums.xbox-scene.com/index.php?showtopic=697073
Sad, sta kazu neki iskusniji clanovi. Jel ovo moguce? Verujem da bi dosta ljudi bilo zainteresovano za ovaj fix.(Ja prvi).
evo ja druginekako navikao sam se na igre instalirane na hardu tako da jedva cekam da se to nekako "opravi". za live me briga.
naravno da sam zainteresovan! ali jel se znam ko ovo radi i kolika je cena ovog zadovoljstva?
Ja sam isto zainteresovan za vracanje HDD-a u stanje u kakvom je bio pre ban-a.
Vidim na netu detaljne tutorijale kako se ovo radi. Da li je neko probao i da li neko od nasih poznatih xbox majstoraradi ovo, posto vidim da je procedura malo komplikovanija pa se ne bih sam upustao.
