IW ladno moze da izbaci jos dva MW-a u istom endzinu, sa gotovo identicnom pricom i malo novih lokacija i uz malo marketinga i hype-a garant ce prodati igru u manje vise istom broju.
Yesturday after downloading mw2 skidrow release , i tried to login to steam and said my account have been disabled, is steam scanning you're computer for release rar's?
Hello Andrew, Thank you for contacting Steam Support. We have found activity in your Steam account related to piracy. Per the Steam Subscriber Agreement, we have disabled your account and any games contained in it. Your account will not be reactivated. The Steam Subscriber Agreement can be found at: http://www.steampowered.com/v/index.php?area=subscriber_agreement In addition to violation of contract, activities on your account may violate federal law and state law. If such activities persist, Valve reserves the right to refer the matter to authorities.
pa to je neki ***** očigledno, trebao si skidrow da skineš ali sa proverenog sajta.
jedino sigurno je kad imaš gomilu rar fajlova od po 15MB a neko stavlja i od 95MB, koliko sam ja primetio. to je dobro kad narežeš na disk a neki postanu corrupt nakon nekog vremena, onda skineš opet samo taj koji ne valja i igra radi, dešavalo mi se sa krizom i cod 4
Jel moze da se igra Multy online?
Igra je vrh, ona misija u Gulagu je mnogo dobra ! I sve sa Roach-om su odlicne, a i one sa amerima manje vise, vecinom su dobre... Mnogo je dobra igra, mozda igra godine, samo je kratka.
Izgleda da ne igramo istu igru jer je ova koju ja igram teško đubre. Momentalni uninstall
• Navigate to the folder: 'program files\steam\steamapps\common\call of duty modern warfare 2\players' and open the file config_mp.cfg
• Change scoresping_interval from 100 to 20, and maxbars from 4 to 10 (10 is the max).
• This means that each of the 10 bars represents 20ms, with full green being 20ms or lower, and 1 red being 200ms or higher.
Ne znam zasto ali kod mene igra radi, radi pa iz cista mira pocne da kove ko luda. Prva trening misija radi bez problema, ali ubrzo kad krene voznja dzipom pocene da kove ko da trazi 12 gb rama.
Ne znam sta je problem, sve ostale mnogo zahtevnije igra rade bez problema.
Inace, C2D @ 3800 GHz, 8800 GT 512, 2 GB ram, Win 7 Utimate 64.
ram ram...
