moto tomo
Нова бета 1.04.59210 ....и све бета верзије уклањају copy protection
..а за кампању не знам пошто нисам играо мада ми се чини да је сређена.АNY ORIGINAL VERSION OF ARMA 2 from 1.00 to 1.03 other than the Steam version, Steam users should use the auto updating feature instead (their game will not be playable if they apply this patch until they recover it again from Steam)
Ljudi,sta sve od patcheva treba da instaliram da bi imao dobr fps?:wall:
Ima li neka aritmeticka dusa... da kaze jednostavno ubogom seljaku:
Ako je "initial" ocena AA2 bila oko 75%... koliko bi bila sa zadnjim patchem.
(navodno je glavna zamerka bila - bagovi, valjda se nesto iscistilo...?)
:type:
[59842] Reduced town/village stutter (fixed streaming of textures used by Super shader).
[59808] Fixed: DOF in 3D scope view
[59741] Analogue throttle working for helicopters as well.
[59736] Fixed: Startup sounds are not spatial and stick to audio channels
[59715] Covering soldier in grass ("Grass layer")
[59691] Improved: Small hit be ignored by hitpoints (configurable by minimalHit)
[59668] Improved: Hitpoint can pass only a part of the hit to the total damage (passthrough setting no longer ignored).
[59446] New: IK weapon animations are now blending with primary animations.
[59351] Fixed: VoN direct speaking distance fade out
[59318] Fixed: support the highest Matrox TrippleHead2Go resolutions
[59279] Fixed: FPS on Dedicated server is not affected by server window manipulation (such as move or scroll).
[59088] Mouse lag can caused by GPU render ahead buffer be limited using GPU_MaxFramesAhead=N in ArmA2.cfg.
[59047] Fix: When player was a helicopter pilot, the AI gunner sometimes had no weapon selected on mission start
[59030] Fix: Helicopters - when manual fire on, do not allow AI gunner to switch weapons
Uopšte nemam teksture, a grafika u 1680x1050 izgleda ko 640x480 rezolucija. Očaj živi, još jedan masovni beta test od igre.
Čekam lepo OFP2, pa makar bio najgora arkada.
Uninstall....
