ATI Eyefinity
Radeon HD 5870 Eyefinity Edition Spotted
Izvor: TechPowerUP.com
Jel ono 6 display porta?
da samo... 6 x Mini Display Port.
ode Matrox vechnu mu slava...
+1 na totalnu glupost demo-a. Bar sto se tice igranja na takvom multimonitor resenju.
Gde je FPS? :)
Pa, imas vec u threadu.
Ova simulacija letenja na 24 monitora (FSX?) ne pise kako radi, ali fps verovatno umire. :)
Prikazani CE3 demo na tri 1080p ekrana je igriv, samo to verovatno nije iz igre koja ce se pojaviti, jer je scena u sumi iz igre koja je otkazana, ako se ne varam.
Evo za ostale:
That's six Dell 30" displays, each with an individual resolution of 2560 x 1600. The game is World of Warcraft.
Driving all of this is AMD's next-generation GPU, which will be announced later this month. I didn't leave out any letters, there's a single GPU driving all of these panels. The actual resolution being rendered at is 7680 x 3200; WoW got over 80 fps with the details maxed
I played Dirt 2, a DX11 title at 7680 x 3200 and saw definitely playable frame rates. I played Left 4 Dead and the experience was much better. Obviously this new GPU is powerful, although I wouldn't expect it to run everything at super high frame rates at 7680 x 3200.
That's six Dell 30" monitors, each at a resolution of 2560x1600, showing Dead Space at over 24 megapixels. The game ran fluidly, and as you can see, your character on screen is pretty much life-sized, if not a little larger.
Ma cela ova prica je po sistemu ja tebi ti meni. Samsung ce prodati vise svojih (ne narocito kvalitetnih) monitora a AMD novih procesora i graf. karti koje su neophodno da bi ovo cudo radilo kako treba. Samo treba naci dovoljno ljudi sa viskom para (i u ovom slucaju manjkom inteligencije) kojima je ideja igranja na 24 monitora WOW. Ok je ova tehnologija za posao ali za igre...
Shto se tiche Nvidije i 3D naochara, to je potez u skladu sa vremenom - 3D stereo je sada "in" i Nvidija prati trendove.
Hmm sada? Pa nVidija od svog nastanka propagira 3D naocare. Ako se dobro secam 3D naocare su se mogle koristiti i uz TNT karte prve generacije. A to da je 3D stereo in, pa mozda u bioskopima. Ona ideja sa zakrivljenim ekranom/platnom je mnogo bolja i prakticnija.
Da, sa Asusovom GeForce256 DDR su dolazile naočale, u to sam siguran :).
to je onaj matori fake render :)
Mozda će biti ako ATI tehnologiju omogući i za low/mid level proizvode :).
Све је то супер, али ови црни оквири стварно убијају у појам.
Шта је оно на 1:22, као да је слика на 4 лева монитора каснила за остатком? У оном делу када река испод прелази преко њих, прелаз са десних на централне је нормалан, а онда се баш примећује кашњење.
@Geble
Bas to, pazi jos iz daleka snimano. Zamislite malo blize...
Mada ovo je tek pocetak, odreagovace Samsung i drugi sigurno povoljno.
Ako su 24 monitora u pitanju, onda je to QuadFire konfiguracija, zar ne?
Dobro, jeli to nesto novo :) Bez veze!
Ovo vec ima smisla.
Ne znam,odlicno izgleda i sve to,ali nekako je "pljosnat":d,bas mnogo razvucen.Bilo bi bolje da je ekran malo visi,nekako je slika prirodnija,ovako mi se bas puno i ne svidja:p
P.S.Ni malo se ne bih bunio da ga imam:-devil-::D:-devil-:
Takvo ti je vidno polje, vise ti znaci sirina nego visina ;)
Uradi mali test:
Gledaj pravo ispred i rasiri ruke, pa vidi do koje sirine ih vidis (perifernim vidom).
E sad isto to samo po vertikali. Skontaces da bi nam trebao monitor sa odnosom strana ~5:1...
Glupo je sto razvoj ide u tom pracu, umesto da razvijaju VR.
Kineski sajt PCPop.com (Googlish) je objavio prikaz ATI's Radeon HD 5870 Eyefinity6 Edition kartice.
Glavne razlike u odnosu na referentni model su 6 Display portova, 2GB memorije, 8-pin + 6-pin PCI-e power konektori i blago izmenjeno hlađenje.
Proizvod će biti dostupan ovog meseca.
Bice lepo videti kako 2GB utice na performance, za singl monitor varijantu.
Bezveze je to što po onome što čitam ovaj referentni 2xDVI+HDMI+DisplayPort ne radi kako treba sa više od dva monitora.
Ne radi samo kombinacija 2xDVI + HDMI.
Moguće kombinacije su ovakve (prema AMD specifikacijama):
DVI1 +DVI2 + DP
ili
DVI1 + DP + HDMI
ili
DVI2 + DP + HDMI
Da, to je ono što sam i ja pročitao. Valjda proizvođači stavljaju samo dva DVI pajplajna ili tako nešto.
Samo... koliko ljudi ima monitor sa DisplayPort-om?
DVI1 +DVI2 + DP
ili
DVI1 + DP + HDMI
ili
DVI2 + DP + HDMI
E do djavola, bas isplanirao sa drustvom da probamo 2xDVI + HDMI :S:... jel postoji DP to DVI adapter?
Edit: sad videh da ima, samo jos da se nabavi...
