SLI za Intel Core i7/i5 platforme
  • Začetnik teme Začetnik teme starac
starac
http://www.nvidia.com/object/io_1249876351744.html
SANTA CLARA, CA—AUGUST 10, 2009—NVIDIA Corporation today announced that Intel Corporation, and the world’s other leading motherboard manufacturers, including ASUS, EVGA, Gigabyte, and MSI, have all licensed NVIDIA® SLI® technology for inclusion on their Intel® P55 Express Chipset-based motherboards designed for the upcoming Intel® Core™ i7 and i5 processor in the LGA1156 socket. As a result, customers who purchase a validated P55-based motherboard and Core i7 or Core i5 processor when available can equip their PCs with any combination of NVIDIA® GeForce® GPUs, including Quad SLI, for the ultimate visual computing experience.
Znaci dogovor je pao 🙂
Sada su lepo pokazali AMD-u da sve to moze da radi i bez nV cipseta 🙂
As a result of today’s announcement, NVIDIA SLI technology is now available for all consumer PC platforms, including the Intel Core i7, Core i5, Core 2 Quad and Core 2 Duo processors, as well as those based on the AMD Phenom II CPU.
Nadam se da ovo znaci da cu moci da nabodem jos jedan 8800GTS 512 u mog ASUS P5E.
Na zalost, sumnjam da ce to biti slucaj, posto se dogovor verovatno odnosi na P55 i derivate sa LGA1156 podnozjem. Slican dogovor je postojao i za X58/1366, pa se nije sprovodio retroaktivno, na prethodne generacije prozivoda.
Zasto bi onda pominjali Core 2 Duo i Core 2 Quad u svoj prici? P55 cipset je za Core i5 i Core i3...
Pa postoji SLI platforma za te procesore, ali je u pitanju stariji NVidia cipset. U saopstenju se samo navodi na kojim sve platformama je sada dostupna SLI tehnologija.
Intel im nije dao licencu za Core i7/Core i5, pa ne mogu dalje da razvijaju svoje cipsetove, ali sada bar mogu da zaradjuju prodajuci SLI licence proizvodjacima ploca.
Napisali su da je SLI dostupan za sve PC platforme ukljucujuci i7, i5, Core 2 Duo i Core 2 Quad. Ako su rekli sve platforme, onda bi to moralo ukljucivati i P45 i X38/X48. U svakom slucaju ne verujem da ce se dugo cekati na dalji razvoj situacije.
Sve zavisi kako definisu platformu 🙂 U saopstenju pominju samo procesore sa kojima je moguce napraviti SLI konfiguraciju. Sve ostalo je citanje izmedju redova.
Kao sto vec napisah negde, po mom misljenju su veoma male sanse da Intel da pristanak i zvanicno omoguci SLI na svojim starijim cipsetovima. Razlika u performansama koju donosi Core i5 nije previse znacajna (cca 10-ak procenata maksimalno u igrama) u odnosu Q9xxx seriju, a tim potezom bi starim procesorima samo jos malo produzili vek trajanja.
Jos malo? Pa otprilike dok DDR3 4GB ne bude po ceni isti kao DDR2 2GB a to je barem godinu dana. SumLJam da ce Intel bilo sta 'otkljucati' za stare korisnike.
