@isnogood: Prijatelju, nema smaranja, reci cu ti ono sto sam uspeo da saznam za vreme dok je uredjaj bio kod mene. Kao sto sam napomenuo na pocetku, ovaj ruter je kod mene bio "na probi". U medjuvremnu sam morao da ga vratim drugaru, ali sam odlucio da kupim jedan primerak za sebe.
Odgovaracu na tvoja pitanja obrnutim redosledom:
1)
da li je uredjaj iz netiksa? - DA, ali kada sam se raspitivao za kupovinu vise nisu imali nijedan na stanju, nadam se da su u medjuvremenu dobili novu kolicinu
2)
ako mozhe cena? - cena sa PDV-om je oko 13.000,00 dinara (zavisno od kursa EUR)
3)
da li ima neki kvalitetan QOS u sebi? - ovaj ruter ima u sebi QoS, ali prethodno mora da se uradi upgrade na najnoviji firmware da bi se u meniju pojavile opcije za setovanje.
3a)
kvalitet QoS-a? - posto se nisam mnogo bavio time, jedino mogu da ti prikazem opise sa njegovog web interfejsa, pa ti sam da zakljucis:
"QoS Settings Help
In this page you can disable or enable the QoS feature. The QoS Rules will work properly only when the QoS feature is enabled.
Enable QoS - If enabled, the QoS rules will take effect.
Egress Bandwidth - The upload speed through the WAN port.
Ingress Bandwidth - The download speed through the WAN port.
Qos Rules List Help
This page shows the Qos rules list.
ID - The sequence of entry.
Description - The information of description include address range, the port range and protocol of transport layer.
Mode - Independent bandwidth means every port has its own upload and download bandwidth. Share bandwidth means the addresses or ports share the upload and download bandwidth.
Egress Bandwidth - The max upload speed which through the WAN port, default number is 0.
Ingress Bandwidth - The max download speed which through the WAN port, default number is 0.
Enable - Rule status, show whether the rule takes effect.
Modify - Choose to modify or delete an existing entry.
QoS Rules Setting Help
This page is for the bandwidth configure of the Qos rules.
Enable Enable or disable the rule.
IP Range - Interior PC address range. If both are blank(or 0.0.0.0), the domain is noneffective.
Port Range - The port range which the Interior PC access the outside PC. If all are blank(or 0), the domain is noneffective.
Protocol - Transport layer protocol, here there are all, TCP, UDP- This domain works only the port range is selected.
Mode - Independent bandwidth means each port has its own upload and download bandwidth. Share bandwidth means addresses or ports share the upload and download bandwidth.
Egress Bandwidth - The max and the min upload speed which through the WAN port, default number is 0.
Ingress Bandwidth - The max and the min download speed through the WAN port, default number is 0."
4)
da li ima opcija da se "rangeovi" portova teraju na odredjeni WAN tipa 27000-28000 wan1? - IMA
Primer jednog podesavanja:
1 Priority WAN 1 Source IP From LAN ALL 192.168.1.10-192.168.1.20 27000-28000 Modify Delete
2 Only WAN 2 Source IP From LAN ALL 192.168.1.30-192.168.1.50 30000-32000 Modify Delete
5)
da li radi sa dinamichkim IP adresama? - RADI, a ima i mogucnost za DDNS
The router offers a Dynamic Domain Name System (DDNS) feature. DDNS lets you assign a fixed host and domain name to a dynamic Internet IP address. It is useful when you are hosting your own website, FTP server, or other server behind the router. Before using this feature, you need to sign up width DDNS service providers such as www.dyndns.org. The Dynamic DNS client service provider will give you a password or key."
6)
Kako radi failover? - automatski i skoro neosetno; ovaj ruter sam, u stvari, i uzeo u razmatranje najvise zbog ove opcije. ("K'o za inat", u poslednje vreme mi i SBB i ADSL rade vrlo solidno i stabilno, skoro da uopste nema prekida konekcije sto je donedavno bilo vrlo cesto)
7)
Na kom principu radi detekciju? - na ovo pitanje ne mogu da ti dam konkretan odgovor, osim da su load balancing i failover automatski, ali da ti isto tako preko opcije 'Network / Flow ballance' mozes da
"... specify priority channels according to source or destination IP addresses, distributing flexibly Internet resource and services from different ISPs. For example, you can specify some packets prior forwarding from WAN port 1, which depend on specified source or destination IP addresses."
