pa nisi valjda mislio da je *******cijaStvarno working sample!
pa nisi valjda mislio da je *******cija![]()
The upcoming DX11 parts are commonly known as R870, but some call it RV870. It's smaller sibling is similarly known as RV840. The problem is that ATI dumped the numerical code names a long time ago, those names never existed. If you have seen anything purporting to show specs on these parts, they are fabricated. Anyone that has the real chip specs would know the code names as well.
As you can see, the MS demos clearly say Evergreen, "HARDWARE: EVERGREEN" to be precise. This is the family, all of the DX11 parts all fall under the Evergeen banner. The chips under them each have their own code names, trees in the evergreen family. R8xx and RV8xx never existed as code names, and never will.
So, what are those code names? They are Cypress and Juniper. Cypress is the big chip, and Juniper is the mid-range part. ATI strongly hinted at the conference that the wafer was a Cypress, but I don't recall if a chip code name was explicitly stated. It it was Cypress, die size estimates in the 180mm^2 range should make Nvidia very nervous. If the wafer was a Juniper, Nvidia should be far more nervous.
In the end, if you see people calling any specific part Evergreen, they don't have a clue and are making things up. This was a very clever move on ATI's part, it likely will gain them at least 3 levels of cunning when they level up.SA
ala je launch date, to sam mogao i ja da ti kazem![]()
As already written, and a lot about the release date of the new generation graphics card from AMD / ATi speculated. As we now industry-related sources have been reported, the RV870 has been postponed to November. This is due largely to the low yield rate of TSMC, and this will not improve soon. Thus, the yield rate of business-related sources of TSMC is still very modest, and even after another fruitless optimizations have not improved.
Despite these problems, we suggest that an early launch beginning of November is possible. This situation has a positive aspect, namely the availability of better than with a launch in October, but we still in the same month a paper launch expected.
Sada će ih izgleda ispaliti i za RV870 kartice. Umesto da iskorise vremenski period do izlaska sledećeg nVidijinog čuda, i hype oko Windowsa 7 i DX11, RV870 će se pojaviti praktično u isto vreme kad i "GT300".
Malo nas ima koji zadnjih 5 godina kupuju samo crvene iliti kanadjane mnogo me raduje ova vest....Mislim da sa ovim cipovima postoji sansa da ATI (na moju veliku zalost kupljen od AMD-a) skoro pa i posalje zelene (Nvidia) na ivicu vecnih lovista,)
Ma naravno da je to. Kome sada da prodaju DX11 karticu kada se konačno 4800 familija bolje prodaje od GTS i GTX kartica iz konkurencije koje pripadaju istoj klasi...? Nema razloga da žure. Win 7, neki DX11 demo, dobri drajveri i yield i taman pravo vreme...
