ArmA 2
New version of the 1.02 patch released!
http://www.armaholic.com/page.php?id=6081
Popravlja:
VERSION 1.02.58134 HIGHLIGHTS
* Improved AI driving skills
* Lowered enemy AI skills for regular and recruit difficulty levels
* Improved Micro AI tactics, attack in pairs, path limiting to avoid passing through walls.
* Fixed multiplayer session NAT negotiation
* Improved game stability (various crash opportunities fixed)
* Multiple save slots supported
* Improved terrain shape beyond map borders
* Various campaign and localisation fixes and improvements
* Modules (F7) support added in the Mission Editor
* Antialiasing enabled in Video options
* Different logic of fillrate optimizer: separate settings for 3D Resolution and UI Resolution implemented instead
CHANGELOG:
Engine
* .58134 Fixed localVRAM detection on Vista x64 systems with 8 GB RAM and more
* .58134 Enabled MSAA in Video options
* .58134 Fixed possible crash in Radio target reporting for NULL target
* .58134 Fixed DOF always enabled on game start.
* .58134 Added safeguard againg frequent reset into RequestFlushMemory as well.
* .58134 Improved Cannot create surface Rpt messages.
* .58134 Relaxed reset recovery conditions to that "profylactic" reset happens less often.
* .58134 HC command - enabled page selection
* .58134 Commandline parameter -netlog available in retail version again
* .58134 Editor fix: modules info serialization Fixed
* .58134 Fix: weapon fire effects in MP
* Multiple savegame positions allowed.
* Configuration fixes in radio protocol (including faster reaction to crew-related orders in vehicles).
* Multiplayer server browser enlarged.
* Improved steering for car.
* Improved mobile artillery simulation.
* Improved terrain shape beyond map borders.
* Added UAV camera stabilization.
* Indication of player connection status in list of players (Diary).
* Possible to connect to server with template-based MP scenario.
* Repeated weapon change command fixed in radio protocol.
* Game no longer crashes when copying a linked trigger in the Mission Editor.
* Different radio notification of multiple units attacking.
* NAT negotiation issue removed (different negative sign cookie on client and server).
* Fixed possible crash after or during Get In in multiplayer.
* Improved transfer of building destruction in multiplayer.
* Fine surface information are now properly used for surface properties.
* Destroyed targets are no more massively reported after player has left the vehicle.
* Proper update of AI pathfinding when new building is created in the landscape (new objects were ignored).
* VON no longer crashes the game in certain circumstances.
* AI sprinting on the spot removed if route was planned across the roof.
* Server shown as passworded in Server Browser when passworded or locked.
* Improved functionality of Get In command if player is vehicle commander.
* Swimming soldiers no longer drop inventory items.
* Swimming players cannot use Gear dialog.
* New scripting function "GetPlayerId unit" available to help server admins better recognize teamKillers etc.
* Fillrate optimization in Video Options is now defined via combo box.
* Improved light count optimization (should help performance when many distant lights are present).
* Low-frequency effect (subwoofer) improved.
Scenarios
* Added or fixed markers in pre-mission briefings in various scenarios.
* "Eye for Eye" singleplayer scenario: Hostiles balanced and loadouts of playable units fixed.
* "Counterattack" singleplayer scenario: Flow fix, player's group now properly advance from the harbour if strong enough to continue.
* "Trial by Fire" script error fixed.
* Campaign: Time flow screen added to scenario intros.
* Campaign: "Murder" mission ends are now triggered also when firing from a vehicle.
* Campaign: Multiplayer info for all campaign scenarios added.
* Campaign: Scene-specific sound entities are deleted after end of a scene.
* "First to Fight" campaign scenario:
* Shooting range bug fixed.
* Officer's speech has titles added.
* "First to Fight" campaign scenario: O'Hara animation speed fixed.
* "Into the Storm" campaign scenario: Conditions of interaction with civilians improved.
* "Razor Two" campaign scenario:
* Mission-failed end now performs correctly.
* Razor members cannot use UAV during conversations.
* "One Week Later" campaign interlude: Conversation more logical.
* "Manhattan" campaign scenario:
* Animations of ambient people improved.
* Task waypoint for main task positioned better.
* Insurgent animations after death disabled in scene.
* Civilian woman stuck near transport prevented.
* Reinforcements navigation fixed.
* "Bitter Chill" campaign scenario:
* Conversations and broken mission flow fixed.
* Accidental death of Cpt. Shaftoe after a scene prevented.
* Improved positions of several killed unit.
* Radio chatter disabled where disturbing.
* "Badlands" campaign scenario:
* Ending and conversation flow fixes.
* Scene of talking to locals improved.
* "Dogs of War" campaign scenario:
* Insurgent leader presence now logical.
* Several story-related vehicles are now properly usable.
* Initial conversation work in multiplayer.
* "War That Never Was" campaign outro: Amount of units decreased, behaviour improved.
* AI grouping prevented in team deathmatch and deathmatch scenarios.
* Module for limiting area of operation script fixes.
* Recomposed fortifications and minor fixes in Warfare.
* First-aid module performance improvements.
* Language and gameplay fixes in multiplayer and singleplayer templates.
Art/Environment
* Changed lighting values for early morning and dusk.
* Improved wheeled vehicles turning definitions.
* Utes: Improved carrier deck collision shape and F-35B geometry.
* Gas stations on map can now refuel nearby vehicles.
* Minor object fixes on Chernarus map (traffic signs tweaks, small objects).
* Added small signs to Chernarus map.
* Less frequent occurence of thunderbolts.
VERSION 1.02.58134 <-- i dalje su zadnje 4-5 misije totalno neigrive... razor tim ne reaguje na komande pa jedino mozes igrat sam sto je u tim misijama jako tesko...
izdavaci igre na forumu jedino ne daju odgovor na ovaj problem sto samo znaci da je problem sa protekcijom igre i da se ceka resenje od strane securom-a... sramota za sve kupce originala
a jel zna neko kako da ja update-ujem ovu igru...
HOW TO INSTALL THE PATCH:
- Run the patch setup executable, the patch is then applied automatically.
- It will install the entire contents of the patch to a folder within your ArmA 2 installation (default is C:\Program Files\Bohemia Interactive\ArmA 2 or Bohemia Interactive\ArmA2).
- Please note that it is NOT possible to rollback to a previous version after the installation of this patch, only a full reinstall of the game is possible.
- It is not recommended to use any savegames created in versions 1.00 or 1.01.
:banana::banana:
:banana::banana:
sto se tice savegama nije problem ako uspes da predjes misiju iz koje je save.. jer u naradenoj ne pravi problema ali u tekucoj moze...
JOs nemam celu verziju nego Demo , ali mi nece da je pokrene."This aplication has failed to start because X3DAudio1_6.dll was not found".Ako neko zna o cemu se radi.
evo nekog resenja za XP zealote koji zele 1.2 patch i klone bez kreka :p
I can confirm the Virtual CD method WORKS!! Finally working on Windows XP SP3
- Download the Virtual CD demo and install it
- Mount the image in Daemon Tools
- Create a virtual cd in Virtual CD and choose as source: the mounted ARMA2 image in Daemon Tools
- Just leave the settings alone, and wait a few minutes for it to complete
- Mount the virtual cd in Virtual CD
- Close Daemon Tools (and YASU if you still have it running)
- Play the game!
inace ja sam jos u misiji Badlands gde treba bazu da pravim ... i tu stojim jer dosta toga neznam kako a cujem da se misija nemoze zavrsiti ... ;)
Izgleda da je Ponovonapunjeni uspeo da je izleči.
A jel izasla uopste full verzija.
Ja imam betu od 7,7GB.
ovaj topic treba zatvoriti dok ne izadje patch 2.0 jer ja goru igru nisam video... odustajem totalno... zadnje misije su smesne najblaze receno...
Jel ti imas betu (nemacku), ili full verziju ?
Ima nade, upravo se pojavila Arma II-RELOADED.
nemacka, itwins i reloaded su sve jedna te ista verzija, po serijskom broju igra odredjuje koji ti je jezik dostupan..
i da beta verzija ne postoji jer oni sto ljudi igraju jos je alfa fazi izrade...
Pa sta je onda ovaj Reloaded ?
Sta su oni izlecili, preaplha :D ?
pa kad je neko rodjen retard mozes ga ti leciti koliko oces...
sto je najgore izgleda da se izdavac pravi blesavim jer vecina ljudi igra multiplayer pa i nije svesna da je kompanja neigriva.. a ja se pitam da li ce oni patchevima ikad resiti sve probleme
sto je najgore review sajtovi nisu ono sto su nekad bili i testiraju igru povrsno a i ko zna koji dil imaju...
Posle patcha 1.02 pojavio se novi, 1.02.58134 koji bi trebalo da ispravi bagove iz kampanje. Nisam isprobao jos...
Излијечили су верзију 1.02! Иначе, заболи ме да ли ради кампања када на нету има брдо екстра мултиплејер мисија које су одличне, а пошто игра ради преко хамачија... То је оно што се цијени. Ова игра је нешто посебно, једини изданак оваквог жанра, а уосталом само одређена група људи ће знати да је цијени.
МИслим, мени је рецимо Crysis тешки смор, али ми је зато вишечасовна опрезност и пузање од дрвета до дрвета, покривање, кординација чланова тима и сл. права посластица макар с времена на вријеме налијетао на левдеће дрвеће и војнике који после препливавања ријеке остају голи и боси (нестане им оружје-мада је castum мисија)
mreza: arma2srbija
sifra: srbija
Па да се организујемо!
Jer ima neko rešenje za zvuk... Mislim imam zvuk ali bih rekao da nešto nije tu ok... Neka mesta su skroz mutava pa nisam pametan dal to tako treba ili ne. A opet dijalozi i recimo disanje nekako čudno zvuče, kao da se zvuk pomalo cepa i kao da je pod distorzijom. Inače instalirao sam patch 1.2, a koristim ovu iTwins verziju igre...
Ne znam za zvuk al ja nikako da pogodim nekog neprijatelja, cak i u onom kampu prilikom gadjanja jedva iz ko zna kojeg pokusaja pogodih 10 meta, u odnosu na neke druge igre ovoga tipa bas je tesko.
lici na fade protekciju, nisi "pravilan serial" koristio..
Ma nije to, pogodim al kad se priblizim i ispucam 30 metaka, jednostavno u odnosu na rainbow six vegas na primer gde je nisan slicno uradjen ovde je preciznost katastrofa.(pricam za onu pusku kojom pocinjes igru)
R6 Vegas i Arma2, nisu ni u ludilu za poredjenje. Vegas je arkadna pucacina, a Arma simulacija, sever i jug, zapad i istok, plus i minus,...
