Street Fighter 4 na PC
  • Začetnik teme Začetnik teme Zduman
Jedva cekam,takve igrice su nam falile 😀 da se vrati malo retro adrenalina ..
Konacno nesto...
Ja igram samo Guilty Gear Accent Core... 🙂 Zna se ko je cale. :smoke:
Nije da mi je dosadio, ali ce mi prijati promena.
Jesi li ikada igrao bilo koji deo SF-a na Pc-u?? ( To je licno moje misljenje da nije izvodljivo za special moves) :smoke:
SF2, SF3, SF Alpha 2 i 3, Capcom vs. SNK, Marvel vs. Capcom ... gomilu sam igrao.
Meni licno vise odgovora joypad, a ortak na primer ubija na tastaturi.
Sa Capcomovog sajta 🙂
Lastly, while I’ve hinted at it before, given that the mouse and keyboard really isn’t an ideal way to play Street Fighter IV, we felt we needed to take the opportunity to provide a turn-key solution by creating a controller/game bundle SKU in the US.
Jeste i njima cilj da uvaljaju koji kontroler, ali stvarno je besmisleno igrati SF IV na tastaturi. 1995. je odavno za nama...
Minimum
OS: Windows XP
CPU: Intel Pentium4 2.0GHz or higher
RAM: 1GB or higher
HDD: 10GB of free space or more
Video Card: DirectX 9.0c/Shader3.0 or higher compatible, NVIDIA GeForce6600 series, ATI Radeon(TM) X1600 or higher or higher, VRAM :256MB or higher
Sound: DirectSound compatible, DirectX 9.0c (or higher) compatible
Input Devices: Mouse, Keyboard
Maximum
OS: Windows Vista
CPU: Intel Core2Duo 2.0GHz or higher
RAM: 2GB or higher
Video Card: DirectX 9.0c/Shader3.0 or higher compatible, NVIDIA GeForce8600 series or higher, ATI Radeon(TM) X 1900 or higher, VRAM :512MB or higher
Input Devices: Gamepad, Xbox 360 Controller for Windows
Ahhhh, muzika me potpuno podseca na good old days, jedva cekam soundtrack 🙂
Ima vec odavno u "marketu" na netu 😉
Malo znaci nama ali ovako ce izgledati orginal:
Imaju neke slike tih novih Art shader-a? ne mogu da pogledam ovaj video..
Ima, spakovao sam u jedan rar file:
http://www9.zippyshare.com/v/56654761/file.html
Dobro ce doci ovo osvezenje za nas PCjevce... Da se odmore malo mouse+keyboard... Mada ortak otkida na keyboardu ovakav tip igara
Otkidam i ja PES na keyboard-u 😀 Samurai Showdown sam igrao na keyboardu a za ovo videcemo, ali verovatnije joypad (Logitech Precision ce da se izvadi iz spajza :d)...
Street Fighter IV
* Platform: PC
* Release Date: Jun 26, 2009
* Release Region: Europe
http://www.gamespot.com/pc/action/streetfighteriv/similar.html?mode=versions
Street Fighter 4 PC System Specs Revealed
Minimum
OS: Windows XP
RAM: 1GB or higher
Video Card: DirectX 9.0c/Shader3.0 or higher compatible, NVIDIA GeForce6600 series, ATI Radeon(TM) X1600 or higher or higher, VRAM - 256MB or higher
Maximum
OS: Windows Vista
RAM: 2GB or higher
Video Card: DirectX 9.0c/Shader3.0 or higher compatible, NVIDIA GeForce8600 series or higher, ATI Radeon(TM) X 1900 or higher, VRAM - 512MB or higher
Input Devices: Gamepad: Xbox360 Controller for Windows
:banana:
jedva cekam da je isprobam na svom novom kompu zajedno sa 360 kontrolerom yesssss. ovo ceka vec dugo izgleda nije nesto posebno zahtevna zar ne???
Ovo je sve samo ne zahtevno.
da+😉😉😉
Street Fighter IV PC explained in detail
PCGH: Can you at the current state of development tell our readers what hardware will be required to play the game with all detail in 1,680 x 1,050 (no FSAA/AF) and 1,680 x 1,050 (4x FSAA/16:1 AF)?
Yoshinori Ono: For example when tested on a PC with GTX280 with 1680x1050 (MSAA 4x), it was over 100fps. The arcade and the console versions were 1280 x 720 so at this resolution it is possible for a mid range PC of the older generation to maintain 60fps.
The PC version has many other video options available other than the resolution so it is easy to adjust accordingly to each system to balance fps and quality. Depending on how it's adjusted even laptops and ‘mobile' GPUs could run the game smoothly.
Mislim da je ovo najpotpuniji odgovor.... kao sto se i ocekivalo - smesno...cak ne zahteva dual cpu ... a i koji ce joj😀
Samo nek ga konacno izbace...
Ja ga imam na PS3 i moram da kazem da je igra extra, ovo stvarno fali PC trzistu i voleo bih kada bi Tekken uradili za PC.
Uffff Tekken 😀
Dao bi levu ruku za taj port 😀
A SF podjednako volim!
Jos malo pa ce stici a onda zbogom zivote. :d
Ali kad bi dao levu ruku onda ne bi mogao da igrash port Tekken-a.
Mislim da se igra pojavila, ali ne drzite me za rec. 🙂
Kako da se pojavi kad jos nije izasla? Mada kako su maznuli Sims-e 3, ne bi bilo cudno 😀
E nego kako se ovo uopshte igralo na PS3/XBOX360 kontroleru?
Imas 6 tastera, po 3 za udarce rukom i nogom, tako je bilo i u prvom i drugom delu i tako je oduvek 😉
Novo je da imas hvatanje/bacanje kada spojis low punch+kick, isto to sa medium je Fokus Attack (vise o ovome cete saznati kada dobijete igru 🙂 ).
Postoje jos dva tastera koji su kombinacija spojenih 3 punch i 3 kick tastera sa kojima se rade specijalni udarci kao i Ultra Combo-i.
Igra je dobra i predlazem je svima 😛
@shin
Moze da se igra super sa PS3 kontrolerom ali slazem se, bolji joypad ili cak stick je a must 🙂
