Do sada su mogli da roknu nekog ko je načet već a padali su kao muve od par hitaca M4 ili snajpera ili 2 pogotka raketom turreta.
Ovako:
For starters, Patch 1.27 allows players to switch factions manually if the factions are unbalanced. If the factions consist of, say, 13 players versus 11 players, a player from the largest faction can manually switch over to make it an even 12 versus 12. Switching in the other direction is not allowed, so players from the smaller team can’t defect to the larger team if the battle doesn’t go their way. Players who switch over retain all their points, but squad affiliations will of course be lost.
Furthermore, we’ve removed the temporary invulnerability awarded to players who spawn at a spawn point other than the base camp. The players will still be safe at their own base camp, but custom-placed or mission-based spawn points do not yield temporary invulnerability anymore. This will hopefully give opposing players already at this location a fair chance.
Finally, we’ve made a couple of changes to the Badge abilities. The Assault Badge, for instance, was deemed too powerful by many players – so we tweaked down its Armor ability from 100 hit points to 50 hit points. The Tactician Badge’s secondary ability (to request air support from a Sentry Bot) has also been tweaked to make the Sentry Bot more useful. It can aim more accurately now, and its health is a little higher as well. To make it even more useful, we’ve reduced the way automated turrets target them, so they’re not shot down as fast. It should certainly make the Air Support Specialist ribbon easier to obtain!
‘High Precision’
When this option is switched on, it makes the analog sticks more responsive to small movements. Turned off, the controls behave exactly as they did before the patch. It’s not a radical overhaul of the control system, so the layout and the ‘weight’ of the controls remain the same.
I na kraju najzad resen problem Join Friend game
We’ve examined how party systems work and added similar functionality to our game where possible. The ‘Join Friend’ option has been changed so that the player can automatically join a friend’s faction and squad – even if faction balancing is on. In addition, squads and their factions are now persistent over multiple games, so friends can keep playing together continuously.
Frustraciju mi izazivaju i air botovi i tureti, ali sam provalio da je to uglavnom zbog zvuka! Znaci izludjuje me zvuk tureta! Izludjuje.
Ja sam ga ukljucio i ne gasim ga vise 😀Kako vam se cini High Precision mod? 🙂
Pa malo i mojih primedbi.....
Prilikom spawna van baze je klanica.....
Boris oce da kaze da sam los takicar ? SRAM TE BILO BORISU !!! 😀
kako nisi ? pa pogadjas sa M82 snajpera na 500m. ovo je jace nego sa auto aimom. 😀
dronovi su postali killing machines.
