kovacm
Moj kolega i prijatelj je kupio pre godinu dana 2.8GHz Alu iMac (tada je to bio BTO top model) i pre mesec dana su mu se pojavile fleke po ekranu!
http://www.youtube.com/watch?v=QOQGmEiGYjw
(iMac je vracen ali nazalost nisam slikao da vidite kako to izgleda, na ovom youtube klipu se vidi ali dosta slabo...)
u svakom slučaju problem je što se Alu iMac pregreva toliko da se oštedi LCD panel - odlepi se LCD sloj od ostatka panela! - nema popravke kod ovakvog kvara a jedan od komentara na youtube klipu da su mu u Apple-u potvrdili da se ovo dešava usled pregrevanja:
"UPDATE. I have information from Apple service that this issue is not because of trapped dust from outside but because everything inside generates extreme heat inside panel. Display panel is burning and some particles fall off and accumulates between lcd and backlight!
This problem is present from the first white 24" iMac and they didn't solved it yet!
Great design Apple!"
nama danas stižu dva nova 2009 iMac-a 2.93GHz pa planiram da odmah ubrzam ventilatore na 1500RPM-a za svaki slučaj...
