Ranko_SD
Pa nabildovao ju je od drzenja puske :dProvalite koliko mu je leva ruka deblja od desne, a covek je desnjak?! :zgran: 😀
Whereas you could sneak in a few sleeper hold attacks in the original game, that line of offense usually meant you were spotted by the nearly omniscient cast of pirates. In Among Thieves, Naughty Dog is giving you the tools to get your Solid Snake on and silently take down the bad guys if you wish. If enemies haven't spotted Drake, he's going to move differently than if they had seen him. He's going to slink along walls, carefully peek over cover, and move silently.
Nego ovi "shotovi" izgledaju impresivno, ali se zna da su malo nabudzeni, hteo bih da vidim ipak kako to izgleda dok se igra..
We've spent a lot of time focused on the distinctive look that snow has as it falls and is blown by the wind, and of course on the way in which Drake leaves footprints as he trudges through the snowdrifts in the Himalayan mountains that he ventures to. When he's out in the snow he'll accumulate a layer of snowflakes on his clothes and in his hair, which will slowly thaw when he gets back inside under cover. Ice reflects light in a way that cleverly mimics the sub-surface scattering that goes on inside a chunk of frozen water, and gives it a look of incredible volume and density. We have a few more tricks up our sleeves, too - all in all, we're really happy with the way the weather's shaping up in Uncharted 2.
Prvi deo mi spada medju tri najbolje next gen igre, tako da 2. deo planiram da kupim cim izadje 🙂
Btw trenutno pokusavam da predjem prvi deo na crushing i bas je izazovno 😀
