AMD Phenom II - zvanična tema
wPrime jeste merodavan ali daleko od toga da ti je stabilan ako prolazi wPrime.
Ps: kod mene prolazi wPrime na 4700MHz a nije ni s od stabilan.
Tako i drugima prolazi SPi na sumanutim frekvencijama a nije s od stabilnog ;)
covek ocigledno pocetnik gledajuco na setup , vreme u spi1m postize ipak lepe rezultate sa novom 945icom
http://www.xtremesystems.org/forums/showthread.php?p=3703877#post3703877
pogledajte mu dice hladjenje (-49°C) sa obicnim box-culerom i malkice suvog leda na istom aka Gheto !
Ipak 5GHZ :D
Wprime prolazi na 4420@1,375V ...... :)
ko ovome dade ovaj CPU :wall: nema ni plocu ni ram kako treba :wall: gde samo izbunari 2x256 rama ali fini rezultati i jos kad dodje DDR3 :D :-devil-:
'Phenom II X4 955' sample surfaces, is overclocked to 4GHz
The Phenom II X4 955 exists, and it's a pretty nice overclocker. At least, that's the impression you might get after reading a thread at the XtremeSystems Forums, in which a member has posted CPU-Z screenshots of the unannounced AMD processor running overclocked in the Windows 7 beta.
As you might remember, we last wrote about this purported Phenom II X4 955 two weeks ago. Back then, word was that the 3.2GHz quad-core CPU would hit stores in April, and that it would be a Socket AM3 part with a 125W thermal envelope and support for DDR3-1333 memory. That chip was also said to be a replacement for a 3.1GHz Phenom II X4 950, which AMD supposedly canceled because of better-than-expected yields.
Dumo from the XtremeSystems Forums shows the 955 engineering sample running at the stock 3.2GHz speed with a 1.25V voltage setting. At 1.45V with air cooling, the poster claims he was able to hit a cool 4GHz by pushing the HyperTransport speed from 200 to 250MHz—and he even has a screenshot to prove it. That screenshot shows Dumo also overclocked his memory to 1666MHz, which netted over 11GB/s of read bandwidth according to a Lavalys Everest benchmark.
source
Ovaj... mozda cu zvucati glupavo, ali moram da pitam:
Koliko je default voltaza za Phenom II X4 940BE na 3.0 GHz. Moj DFI je podesio na 1.344 pa me zanima da li to nije malo povisena voltaza?
Nije puno visoka nebrini verovatno kao kod mene neocitava tacnu voltazu odnosno senzor nije tacan.
Kod mene ocitava 1.28v a ustvari je 1.25v tako i za sve ostalo.
Naravno da sam izmerio.
Pa sam pomislio da i kod njega senzor brljavi.
Ko je kalibrisao unimer i gde si nasao shemu?
to mozes i sam naci ;) daj sliku i reci cu ti gde mozes izmeriti napon tj. pokushcu da ti nadjem tacku
Nisam ja licno merio nego moj jedan prijatelj elektronicar jer ja nemam pojma o tome cak ni instrument neznam namestiti.
Znaci on je izmerio i reko mi je da je oko 1.25v kako je to odredio nemam pojma.
Ako pogledas datasheet za icl7106 videces da on i svi drugi A/D konvertori sa dual slope principom rada imaju internu referencu i self calibration i greska merenja je u najgorem slucaju sa atenuatorom kome je greska 1% maximalno 3%, tako da ti je pitanje vise nego glupo.
Moj unimer ima gresku od 100mV-500mV kada se isprazni baterija, dok displej radi sasvim normalno, tek kad napon baterije padne ispod 7,5V daje indikaciju da se promeni baterija.
Sta ako je u pitanju analogni unimer?
Nije to bila poenta a i mislim da je sve bilo jasno posle "pocepala mi je domaci neka teta u prevozu" odgovora.
Naravno da je tako kada se isprazni baterija. Zato neki ljudi nameste konektor za eksterno napajanje koje je izvedeno da ima naizmenicni sum reda do 10µV i onda nemaju problema sa praznom baterijom, pa su im i merenja tacna.:D
P.S. Sto se tice merenja analognim multimetrom, da li ona kineska s**nja sto se prodaju za 10 eura nazivas multimetrima?!?! Analogni multimetar ima, na opsezima za niske napone, manje od 100koma unutrasnje otpornosti (i to najbolji medju njima) tako da unose poremecaj u kolo koje se meri i onda su ti merenja netacna i sa, sveze, bazdarenim multimetrom. Kvalitetniji digitalni multimetri imaju unutrasnju otpornost od 10Moma i ona je konstantna bez obzira na merni opseg, dok je kod analognih zbog konstukcije promenljiva i kod boljih uredjaja je 20koma/V ili prevedeno na konkretne brojke za opseg do 2,5V otpornost multimetra je u najboljem slucaju 50koma.
Ili se lepo kupi litijumska baterija pa su opet merenja tacna, uzeo sam sad kad sam bio u SAD za 6,5$ ;)
Fluke je majka !
Trenutno radim na platini za vise kanalni digitalni multimetar na bazi PT100 odpornika.
Koristicu kvalitetne operacione pojacivace od analog devices sa veoma niskim Offsetom i Drift'om kao i AVR'ov ATMega16 mikrocontroller sa kvarcom od 16MHz
Trebaju mi 4 OP'a a odlucio sam se za sledeci model :
http://de.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=5387453
Planiram minimum 4 kanala preko multiplexera da merim. Za prvu varijantu cu koristiti cetvoredni obicni LCD-Display. Kasnije ako budem imao volje i uspem da nadjem jeftino eventualno i neki 2,1" TFT Display
Umesto deljenja packi idi lepo u Servis sobu pa napisi par stikija, uputstava, saveta za nas elektronicare hobiste, posto ocigledno znanja imas da odrzis koji cas... :wave:
Malko neobicna pitanja imam, ali nemojte zameriti. Eto ja sam izdrzao 28 page-ova za poslednja 2 dana, a malo je bilo korisnih informacija (gledajuci procentualno na broj stranica). Procitao sam i 15 pageova topica o x2 7750.
Guglao sam prilicno ali poredjenja koja meni trebaju ne postoje, jednostavno su druge klase stvari u pitanju pa reko mozda neko ovde ima ideju:
1. kolika bi bila procentualna razlika otprilike izmedju dve konfiguracije koje se razlikuju samo u procesoru: x2 7750 i PII x3 710. Bez ikakvog oc-a i od znacaja bi bile samo igre. A recimo x2 7750 vs PII 940? Kontam, bolja arhitektura itd..ali nigde ne mogu da nadjem koliko to utice na gaming jer malo ko u igrama uvazava preko dva jezgra. (recimo 790GX chipset u svim kombinacijama)
2. Intel e8600 vs PII940 isto samo u igrama, bez OC-a
Da napomenem da cene samih procesora, koliko se greju, koliko je zastarela arhitektura kao ni bilo cega drugog nisu bitne. Bitno je samo koliko FPS vise ili manje Interesuje me teoretski kolika bi razlika bila 7750 u odnosu na PII bez OC-a pa bilo to 10% ili 200% . Jednostavno takvo poredjenje nisam u stanju da izguglam, kao ni poredjenje 8600 vs 940 nonOC.
Kratko i jasno, odgovor na oba pitanja :
što više jezgara - to bolje.
I trend izrade sw-a govori tome u prilog.
U prvom slucaju kontam da je nova arhitektura bolja, samo ne znam koliko. U slucaju 8600 nisam bas siguran da PII daje vise u igrama... pa zato pitam
skoro sam uzao komp sa amd phenom black edukation procesorom i trnutno sam zadovoljan videcemo dalje ,)
moj P2 radi stabilno na 3,7GHz na 1,5v sa manjim naponom puca, mada mogu da mu dam i veci napon i da dignem klok, ne greje se puno, ali se greje naponska koja greje NB jer je heatpipe-om vezan za mosfest na mojoj ploci. hladjen je vodom i uskoro ce ici jedan vodeni blok na NB pa pa cu da dizem napon i naravno klok. evo malo test stabilnosti od 3,5sata i ultra niske temperature temp u kuci je bila 22c.
    437.2 KB · Pregleda: 78
    425.4 KB · Pregleda: 63
Zanimljivo je koliko para treba uloziti u hladjenje PII sistema da bi proradio na vecem kloku od 3.6ghz.
Ipak je dobar ovaj i7:) sa V8 4ghz, pa kad podvucemo crtu cena performanse za isti klok od 4ghz dodjemo na isto, ali samo sto se tice cena posto i7 sije PII od 10% do 100% u perfomansama sve u zavisnosti od aplikacije. Svakako tamo gde je najkorisniji i7, PII nema sta da trazi, da ne kazem da je smesan po peformansam.
Do sad sam se sreo sa 5-6 PII sistema ni jedan nije hteo preko 3.6ghz kako god da se hladi, zasto?
Mene zanim jedna stvar sto se tice tebe, vidi da je nova masina, na osnovu cega si doneo odluku da kupis PII?
ja mislim da sam ti vec rekao, kad si bio sa markom kod mene, samo sam zamoenio procesore, znaci prodao sam phenom 9850 i dodao kintu i uzeo phenom2 940.
znam ja da nema sta da trazi sa nehlemom, i to u opste nije za poredjenje, mozda slabije skalira i od core2q,i to sam znao kada sam ga uzimao, i marko me je opominjao ali nisam slusao, ali i nezalim se, radi posao pored moje 4870x2 teram sve igre na maxu to mi je trenutno dovoljno, jer ga nizasta drugo trenutno ne upotrebljavam..., ali mora da se kaze da je amd otvorio malo prozor i pustio svetlo da udje( napreduje )...cuo sam se sa jimom i treba da mi posalje nesto za vodeno a izmedju ostalog i blok za NB, pa se nadam da cu malo uspeti da podignem klok, ali to ce mo da vidimo... pogledaj maretovu temu na sxt-forumu za vodeno, napisao sam ti nesto, za vodeno...
Pa ne moze Marko tako ukratko, niti si napisao o kom procesoru se radi, ni o kojim naponima, da ne nabrajam sad... :D
U svakom sluchaju, TRUE ga dere i bez ovog grafikona. :p
PS. Shto ti je ruzan novi avatar. :p
