Catalyst 9.1 će biti bolje multithreading optimizovan?
9.1 Release Notes
New Features
This section provides information on new features found in this release of the
Radeon™ Display Driver. These include the following:
• Full OpenGL™ 3.0 support
This release of ATI Catalyst™ provides full OpenGL™ 3.0 extension support.
The following is a list of OpenGL™ 3.0 extensions added in Catalyst 9.1:
• ARB_framebuffer_object
• ARB_half_float_vertex
• ARB_texture_rg
• EXT_texture_array
• EXT_texture_integer
• EXT_transform_feedback
• NV_conditional_render
• WGL/GLX_create_context (for new 3.0 contexts)
• GLSL 1.3
• ARB_color_buffer_float
• ARB_vertex_array_object
• EXT_draw_buffers2
Resolved Issues for Windows Vista and Windows XP
Operating Systems
• “Move to Monitor” option does not work for some Open GL application
• Playing back MPEG2 files may fail to respond when task switching between
virtual desktops in extended desktop mode
• Restoring to factory default, Catalyst Control Center may become unresponsive
when multidesktop is enabled
• Catalyst Control Center: display index number are not the same as Displays
Manager in Graphics Settings
• Catalyst Control Center: Some Catalyst text labels may be missing “General
Settings Option” under Windows Traditional Chinese
• Catalyst Control Center: System may become unresponsive when uninstalling
Hydravision package with all HV aspects checked in multi adapter configurations
• Catalyst Control Center: Enabling "Enable Desktop Manager" and "Enable
Multi Desktop" will cause the following to be displayed in the Windows Task
Manager HydraDM64 and HydraMD64
• Catalyst Control Center: Preparing Help dialog window will come up in
English on other localized Windows operating systems
• About Catalyst Control Center window may display some text corruption,
when launched from the system tray
• Catalyst Control Center stops working when skin is changed to Quicksilver
Resolved Issues for the Windows Vista Operating
System
This section provides information on resolved issues in this release of the ATI
Catalyst™ Software Suite for Windows Vista. These include:
• With some ATI Radeon adapters and Windows Vista 64 systems with more
than 4 GB of system memory the display driver may fail to load and report a
code 43 error
• Some video performance playback may be noticed when using the latest version
of Pixela
• Video combing effects may be noticed during movie playback while fast forwarding
or rewinding
ATI Catalyst™ Release Note 6
• Catalyst Control Center: some screen corruption may be noticed after
enabling 1080p HDMI support and adjusting the scaling options
• Video may not fill secondary display when playing back HD 1080i content
with Overlay Theater Mode enabled
• Launching Medal Of Honor Allied Assault Spearhead game demo may result
in a system stopped working error
• Unable to extend the display to a secondary adapter until the system has been
restarted after enable/disable CrossFire™
• Reinstalling the display driver using the INF method on a multi-display (ATI
Radeon HD 3870 X2, Radeon HD 3870) system may cause the operating system
to fail
• Playing Picture-in-Picture on a DVD with PowerCinema or PowerDVD may
cause the system to halt.
• System may become unstable when mode switching during playback of
blu-ray content using WinDVD
• System becomes unresponsive exiting Windows Media Center while playing
high definition content
• DXVA2 Video Decoder DDI Test failures on R7xx ASICs on Windows Vista
Systems
• Some interlacing may be noticed when fast forwarding a DVD playback
• Catalyst Control Center: system may fail to boot after disabling CrossFire™
with dual ATI Radeon HD 48xx adapters
• System unresponsive on reboot after installing the Catalyst 8.12 driver on ATI
Radeon HD 4800 Series CrossFire™
Resolved Issues for the Windows XP Operating System
Catalyst™ Software Suite for Windows XP. These include:
• Catalyst Control Center Runtime does not restart automatically after HydraVision
installation in Windows XP
• Catalyst Control Center: Hydravision tab is not shown in limited user
accounts for Windows XP 64 bit
• Test corruption may be noticed when display is rotated to 'Left (90 ccw)' in
resolutions greater than 1600 x 1200
• Playing back some HD MPEG2 videos will either shows black or show a
reduced Overlay Theater mode on the secondary display
• TV may fail to display an image after installing the display driver with an
HD-TV connected using DVI-HDMI adapter
• Video corruption may be noticed with some DVI monitors during a mode
switch
• On some systems the following ATI warning dialog may be displayed after a
system restore “Not enough displays to enable driver. Add another display
device and try again.
• Unable to install SMBus driver on ATI Radeon HD 3200 Graphics with ATI
graphic card and integrated graphics disabled
Known Issues Under the Windows Vista Operating
System
This section provides information on known issues that may be experienced under
the Windows Vista operating system with the latest version of Catalyst™. These
include:
• The ATI Avivo video transcoder does not currently use GPU acceleration
under Windows Vista 64-bit edition
• Catalyst Control Center: error message 'CCC Host Application' may be displayed
when cancelling a transcoding process
or rewinding
• When using PowerDVD to play certain Blu-ray DVD titles, the lower portion
of the player window may intermittently appear shaky when playing Special
Features
• The Catalyst Control Center 3D settings option, Anisotropic Filtering does
not currently work when running DirectX 10 applications – Anisotropic Filtering
must be enabled within the application
• Some video tearing may be noticed when playing back some DVD titles on
WinDVD with all hardware acceleration options enabled
• Random flashes or some bright pixels/lines may be observed during playback
of some blu-ray titles
• Some flickering in the playback of a Blu-ray title may be noticed when moved
to the extended desktop
• Catalyst Control Center, CrossFire™ Overdrive, changing the GPU Clock and
Memory Clock from the default settings may cause a failure in the “Test Custom
Clocks” test
• With Anti Alias enabled Doom3 will fail to launch on a CrossFire™ system.
• Cyberlink may stop responding and terminate when playing back some H.264
content
• Resuming from suspend mode while playing an HD or Blu-ray title on a system
containing an ATI Radeon HD 46x0 series of product may intermittently
result in a Time-out Detection and Recovery (TDR)
Known Issues Under the Windows XP Operating
System
The following section provides a summary of open issues that may be experienced
under the Windows XP operating system in the latest version of Catalyst™. These
include:
• Only 2 channel audio is heard when playing back multichannel (Dolby
5.1.DTS) audio through HDMI connector
• Corruption may be noticed when running overfly.exe in screensaver mode
znaci ocekujemo neke testove u igrama.....ovaj release note mi generalno nista ne znaci jer ni jedan od tih problema nisam ni imao
sad mi neradi ccc :)
Ma naravno da nisu zaboravili ... samo se jos nisu vratili sa odmora - malo su spojili praznike pa... kineska nova g. je tek februara :d
Hehehe pa sta sam ja rekao... Do duse nije februar ali je kineska n.g. prosla.
Vratili se ljudi svezi sa odmora, zavili rukave, seli, napisali drajvere i pustili :) Ma odmor je ćudo :d
Ni kod mene ne radi CCC, not responing?
Mora da je neko pijan pisao drajvere.
I kod mene je ok.
p.s. Svi da raportiraju :d
Sve je OK, a sto se poboljsanja tiche, videcemo!
djwibe sad ima XFX-ovu 4830, ako ne grešim ;)
P.S. CCC radi bez problema kod mene.
ako hotjete da vama kojima ne radi ccc proradi, aninstal pa opet instal vam ne gine :)
Koji je OS u pitanju kod vas kojima ne radi CC? Da znam da li da instaliram na Vistu x64.
e ovako... popi**** sam vise:mad:
ozbiljno se razmisljam da prodam moju graficku i predjem u drugi tabor :(
8.12 dok sam instalirao imao sam brdo problema,nije mogao da se instalira catalyst(nije da mi je potreban ali zelim da se instalira!) tako da sam manuelno instalirao driver. Jedva sam cekao da izadju 9.1 rekoh promenice se nesto...
i evo opet isti problemi... probao sam i driver cleaner i driver sweeper i ne vredi:wall:
sad ce ortak da mi donese Vistu pa cu da probam reinstall,ako i to ne pomogne...:crash::crash::crash::crash:
Meni radi, na Visti x64 i na Win 7 x64 :) Ali Vistu definitivno gasim :)
:wave:
Radi normalno na Win 7 x64. Imam XP na dual boot-u, al' me mrzi da ga palim.:d Neće taj videti svetlost dana ako 7 nastavi da šljaka ovako.
Probaj da instaliras untached verziju XP-a i ja sam imao ranije problema kad sam instalirao razne Black,Lite i ostale gluposti XP.
Sad sam jedan nasao i radi sve bez problema
Po meni instaliraj Windows 7 i XP(ako ti treba) a Vistu baci u kantu za djubre
samo se razmisljam da li da skinem 64bit 7 ili da instaliram 32bit koji vec imam :trust:
XP nikad! sa njim sam imao 10000000 bsod... i ne zelim da ga vidim (btw ocajno izgleda)
Windows 7 jos nije zavrsen,moze da ti pravi probleme sa nekim programima i igrama.
Tako da za sad koristim oba.Kad se bude pokazalo da 7 radi sve ono sto mi treba e onda
XP saljem u zasluzenu penziju.
Pa moze da se skine 9.1 sa game.amd.com?
