rAMA
Oces da kazes da su uradili teksture iz pocetka za PC verziju :d mozes vecu rezoluciju da stavis, veci draw distance i gusci saobracaj, to je to..
There are new features in the PC version of GTA 4: better streaming, new textures with higher resolutions, a higher visibility range and the possibility to set the resolution up to 2,560 x 1,600
# You're able to adjust many options in game, such as the draw distance, and even the density of the vehicles, from 1 to 100%. Rockstar even mentioned that the console version of the game would only actually be running the vehicle density at 33% of that possible on the PC version.
Increased texture resolution makes it easy to read all of the adverts and posters in the game, such as those in the subway which are nothing more than a blur on the console versions.
Zar ti ovo nije je dovoljno... Nemoj da brkaš rezoluciju igre, sa detaljnošću tekstura, to su različite stvari....
