Added workaround for broken error reporting system of PowerPlay clock control interfaces in Catalyst 8.10 hotfix 2 and Catalyst 8.11 driver families. Due to internal bug these drivers report incorrect error codes in PowerPlay clock control calls, causing overclocking tools like RivaTuner, ATITool or AMDGPUClockTool to stop working properly. Until the problem is fixed in the Catalyst driver RivaTuner provides temporary workaround by disabling error control for PowerPlay clock control calls on the Catalyst 8.10 hotfix 2 and newer drivers. Please take a note that the workaround can be forcibly disabled via ATIPowerPlayErrorReportingWorkaround registry entry.
ne mogu. ATT mi resetuje komp cim kliknem "apply"
@gx-x & Misko78
Aj to sto ti prsne posle klika na apply je neki bag do tvoje masine.
ATITool matematicki pronalazi artefakte, a ne vizuelno kako se traze u igrama sistemom "juuu vidi sareni kvadratic" koji nije pouzdan, nisi bas u pravu.
Jel' ?? Onda i ja imam taj bug 😀 Samo shto meni nerestartuje mashinu nego dobijem BSOD.
Pa ovo je pod znakom pitanja... Pustim ATI Tool da trazi artifekte na 700/2180 i prodje 2 sata bez i jedne greshke ( ni vizuelno nije nishta pokazao ) i pokrenem COD4 i zapuca posle 2 minuta...
Moji utisak je da je cupava kocka radila poslednji put OK u eri G80.
da li ste koristili verziju 0.27b4 ili onu prepotopsku 0.26?
do kraja decembra treba da izadje stabilna verzija, bar tako kaze W1zzard, sa unapredjenim skenerom za artefakte. OC za Nvidiu radi ok ali problem mu prave ATI karte.
Mozda treba da mu promeni ime u nVida Tool 😀
