@RazbojNick
Ako ti treba samo za icq servis, program QIP2005 ver.8070 je No1 za to...
http://qip.ru/en/pages/download_qip_en/
..inace, koristim poodavno Trillian-portable verziju bez problema, "kreiranu"
😀 po sledecem uputstvu:
"Synopsis: Trillian is a skinnable instant messaging client that supports AIM, ICQ, MSN, Yahoo Messenger, and IRC. It provides capabilities not possible with the original clients, while supporting standard features such as audio chat, file transfers, group chats, chat rooms, buddy icons, multiple simultaneous connections to the same network, server-side contact importing, typing notification, direct connection (AIM), proxy support, encrypted messaging (AIM/ICQ), SMS support, and privacy settings.
-Writes settings to: Application folder
How to extract:
Download the installer and install to the default folder C:\Program Files\Trillian. Then launch the program. First it will show you the "Welcome to Trillian!" window, where you get to choose either "Trillian Basic" or "Trillian Pro". Click on the "Trillian Basic" button. You will then be brought to the "Your Identity Information" window. Click "Cancel" at this point!. Trillian should exit after creating the basic default profile information. You can now copy all files from the installation folder into a folder of your choice and uninstall the program.
-Load the following configuration files into a text editor: trillian.ini, users\global\plugins.ini, users\default\plugins.ini, users\default\talk.ini and users\default\trillian.ini. Replace all absolute paths with relative ones eg. change C:\Program Files\Trillian\skins\Whistler to .\skins\Whistler. Once you are done with the changes, save the files and make them read-only. This is to prevent Trillian from reverting them back to absolute paths. You can now run Trillian from any machine by double-clicking on trillian.exe."
..oba programa rade i sa usb-mem.sticka, sa bilo koje mashine.. :wave:
