Lukisa
U *** sorry :wave:Havendale nije isto sto Bloomfield. U Q4 izlazi Bloomfield - citajte malo, pre nego sto postujete nesto 🙂
9.969 sec na 4 Ghz ? Napon skoro 1.6v! Ne kažem da je to loše ali da to nije isto ili nešto malo sporije nego C2D ? :d Ili je screenshot cist fake!
Evo nekih cena koje se ocekuju :wave:
There are apparently going to be three Nehalems introduced at first:
* 3.2GHz $999
* 2.93GHz $562
* 2.66GHz $284
Za x58 maticne nisam nasao:wall:
Kome treba taj ce da kupi - as simple as that 🙂
We were surprised to see that the Bloomfield generation of CPUs will officially support DDR3 800 or 1066. Even the extreme edition 3.2GHz Core i7 officially only supports DDR3 1066 and not faster. There won't even be an official support for DDR3 1333 not to mention 1600 or faster.
Fudzilla has already mentioned the fact that for some reason you need to run memory CPU voltage synchronously which might be an overclocker's worst nightmare. At this current stage you cannot go over 1.65V and some memories such as DDR3 1600 or DDR3 2000 might need a bit more than that. With more than 1.65 you will kill any current Nehalem CPU.
Bloomfield Nehalem doesn’t run with DDR2 memory as the memory controller is inside of a CPU and so far we are not aware of any plans to release Bloomfield Core i7 CPU that would support DDR2.
DDR3 1066 doesn’t really sound like a state of the art speed but this is the reality.
source
http://www.fudzilla.com/index.php?option=com_content&task=view&id=9214&Itemid=34
hmm, ko se igra njemu bas i nije dovoljan taj celeron ako ima jaku graficku, ali kapiram sta hoces da kazes 🙂Vecini je sasvim dovoljan Celeron 1200, a u masini ima i quad i sam spadam u tu grupu 🙂 Svi volimo da imamo to je nepobitna istina.
Mislim da treba manje. http://www.hardwarecanucks.com/foru...ne-super_pi_1m_4653mhz_1.49vcore_9.953s_1.pngNe diraj nam u virmu znas :d Nego ti koliko cekas kvalitetan upgrade kod svoje ima da osedis 😛
Kako sporije zaboga? C2D-u treba oko 5GHz za to vreme.
:wave:
IMC tu sigurno pomaze.
Chekaj intel ima cpu na 4ghz? KOJI TO? 4.1 , 4.6 Ljudi cje josh da pomisle da ima 5Ghz u prodaji kad chitaju shta delimir pishe.
....mozhda loshe skalira pri oc ...ajde malo na def vrednosti da se vratimo....
Bio bi dobar test da se odradi naj slabiji nehalem proc na 2.66 i Q6600 2.4 da se vide kolike su razlike!
