Q6600 G0 + Asus Rampage Formula
Diablo
Q6600 @3.6 na Rampage Formula ploci posle par sati opterecenja ume da se zabaguje ili resetuje te molim da mi ustedite vreme i posavetujete sta da promenim u BIOS-u od podesavanja. Narocito mi je bitno oko napona sta da stavim s obzirom da ova ploca ume sama da povecava napone u zavisnosti od opterecenja (ukoliko je ostavljeno na AUTO).
Sa leve strane su moja trenutna setovanja, a sa desne neka koja sam nasao na netu te mi javite koja da ostavim a koja da promenim.
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Setting : AUTO...........................Manual?
FSB Frequency : 400
FSB Strap to North Bridge : AUTO................400?
PCI-E Frequency: 100................................110?
DRAM Frequency: AUTO
DRAM Command Rate : AUTO
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time : AUTO
Write Recovery Time : AUTO
Read to Precharge Time : AUTO
Read to Write Delay (S/D) : AUTO
Write to Read Delay (S) : AUTO
Write to Read Delay (D) : AUTO
Read to Read Delay (S) : AUTO
Read to Read Delay (D) : AUTO
Write to Write Delay (S) : AUTO
Write to Write Delay (D) : AUTO
DRAM Static Read Control: AUTO..................Disabled?
Ai Clock Twister: AUTO
Ai Transaction Booster: AUTO
CPU Voltage: 1.5v.....................................1.4500v
CPU PLL Voltage: AUTO..............................1.6v
North Bridge Voltage: 1.25v.........................1.59v
DRAM Voltage: 1.94v..................................2.20v
FSB Termination Voltage: 1.20v....................1.5v
South Bridge Voltage: Auto..........................1.150v?
Loadline Calibration: AUTO...........................Enabled?
CPU GTL Reference: AUTO...........................0.63x?
North Bridge GTL Reference: AUTO................0.67x?
DDR2 Channel A REF Voltage: [Auto]
DDR2 Channel B REF Voltage: [Auto]
DDR2 Controller REF Voltage: [Auto]
SB 1.5V Voltage: [Auto]
NB LED Selection: NB Volt
SB LED Selection: SB Volt
CPU LED Selection: CPU Volt
Voltimeter LED: Enabled..............................Disabled?
CPU Spread Spectrum: AUTO.......................Disabled?
PCIE Spread Spectrum: AUTO......................Disabled?
Hvala! :wave:
Vidi, moze biti dosta razloga za kocenje racunara na tom kloku... Pokusaj malo da povecas voltazu, ako nije to, onda pogledaj koja ti je frekvencija memorije posto vidim da si strap stavio na auto.. PCI-E freq ne diraj, tj vrati na 100 (ume nekad da zabode sistem zbog toga). SB ostavi na auto, Loadline Calibration ostavi na enable. Pokusaj ovo pa javi ;)
Probao sam da stavim cpu na 1.51V. Pokrenuo PC Probe II i startovao 3DMark06. Posle par testova cujem alarm, alt+tab i vidim PC Probe prijavljuje milion kriticnih stvari... npr dram, nb, sb, itd... na 4V (!?!?) wtf
Vratih napon na 1.5V, opet pokrenuo 3DM06 i od svega samo prijavljuje kriticnu temperaturu od NB-a (45+C).
PCI-E mi stoji sve vreme na 100. Vrednosti sa desne strane nisu moje. Samo sa leve.
Sto pitas za frekvenciju memorije? 800MHz je posto sam stavio 9x400 za cpu. :)
:wave:
Nekima je stabilan tek i na 1.55v i vise ;) Mada kazi kakve su ti temperature.. I cime ga opterecujes, nije valjda samo sa 3dmark06?? Koristi prime95 i 3dmark06 zajedno, kako bi opteretio ceo procesor (ukljucujuci instrukcije). A za memoriju na auto strapu sa 400 za fsb moze biti na 800 i 1066 koliko me pamcenje dobro sluzi :D Zato sam te pitao... Nista, budi mesar pa povecavaj jos malo V proca i izjasni temperature ovde ;) A sad vidim da ti je i nb na 1.25v, povecavaj po malo..
Ma jok... 3DMark je samo za testiranje na brzaka. :) Prime ne koristim. Bitno mi je da mi ne pucaju igre posle par sati.
Ukoliko CoreTemp ne laze, temperatura nijednog jezgra ne prelazi 50C prilikom igranja.
Mislis da bi trebalo FSB Strap to North Bridge da stavim na 400?
Zna li se koja je dozvoljena (bezbedna) temperatura za NB?
Pozz
Idi do 1.44v za nb max... Dzaba ti stabilnost u 3dmark-u, jer iako ti prodje par puta, ne znaci da nece puci neki sledeci put ;) Temp su ti ok, tako da to nebi trebalo da predstavlja problem...
Prckao po biosu i sad je prosao 3dmark06 @3.7 bez problema. Dobih prvi put preko 20,000 skor. :)
Nego, u sred testa ukljucio se alarm od PC Probe-a i pokazao napone od 4.08V za SB, NB, VCORE, DRAM... Pustih ga da odradi test do kraja. Izgleda PC Probe malo prolupao.
Jos malo cu da se igram pa postavljam krajnja setovanja iz biosa.
Hvala
:wave:
P.S. Oho... evo ga posle jos malo igranja cpu @3.8 GHz i skor od 20,490 u 3dmark06. :)
Nema na cemu ;) Ignorisi PCProbe ;) Koristi HWMonitor ;) Ufff, kako deru dve 4850 u cf XD Jedva cekam dve 4870 da se palo pozabavim ;D
Na 3.8GHz nije bas najstabilniji iako prolazi 3DMark bez problema, tako da sam ga stavio na 3.7GHz za sad. Setovanja u BIOSU su sledeca:
Extreme Tweaker
Ai Overclock Tuner: Manual
OC From CPU Level Up: AUTO
CPU Ratio Setting: 09.0
FSB Frequency: 412
FSB Strap to North Bridge: 400
PCI-E Frequency: 105
DRAM Frequency: 824
DRAM Command Rate: 2N
CAS# Latency: 5
RAS# to CAS# Delay: 5
RAS# Precharge: 5
RAS# ActivateTime: 15
RAS# to RAS# Delay: 3
Row Refresh Cycle Time: 45
Write Recovery Time: 6
Read to Precharge Time: 3
Read to Write Delay (S/D) : 8
Write to Read Delay (S) : 3
Write to Read Delay (D) : 5
Read to Read Delay (S) : 4
Read to Read Delay (D) : 6
Write to Write Delay (S) : 4
Write to Write Delay (D) : 6
Write to PRE Delay : 14
Read to PRE Delay : 5
PRE to PRE Delay : 1
ALL PRE to ACT Delay : 6
ALL PRE to REF Delay : 6
DRAM Static Read Control: Enabled
Ai Clock Twister: Strong
CPU Voltage: 1.500v
CPU PLL Voltage: 1.5v
North Bridge Voltage: 1.41v
DRAM Voltage: 2.12v
FSB Termination Voltage: 1.4v
South Bridge Voltage: 1.050v
Loadline Calibration: Enabled
CPU GTL Reference: .067
North Bridge GTL Reference: .067
DDR2 Channel A REF Voltage: AUTO
DDR2 Channel B REF Voltage: AUTO
DDR2 Controller REF Voltage: AUTO
SB 1.5V Voltage: 1.5v
CPU Spread Spectrum: DISABLED
PCIE Spread Spectrum: DISABLED
:wave:
Oleshio si ga. 1.5V za procesor, 1.41V za northbridge i 2.12V za memoriju i nece stabilno na 3.8GHz? Daj temperature.
50c ne predje u igri a 1.5v si mu dao ?
Baci nam CPUz i CoreTemp ili jos bolje HWMonitor tokom igranja/3dmark pa da vidimo idle i load.
I koliko ti u sobi C ?
X48 ploca koliko sam citao i trazi veci napon od 1.4V za NB. Neki cepaju i na 1.6V.
Dacu temperature kad dodjem kuci. Radio sam gomilu loop-ova u 3dmarku sinoc i posle bacio pogled na temperature u tray-u. Jedino tako mogu da uradim i brzo uzmem printscreen cim izadjem iz 3dmarka.
Odvrnuo sam klimu u sobi, ali ne znam kolika je temp bila.
Provericu danas po podne pa javljam.
Pozz
Mozes na laksi nacin da mesi temp ;) Upali u Riva tuneru Hardware monitoring (tu ces videti kolika ti je bila max temp grafe), i skini HWMonitor gde ces videti max temp proca ;) Istina je da X48 zahteva malo vise napona za nb, npr meni je trebalo 0.04v vise nego na maximusu, jer su same latencije cipseta zategnutije ;)
evo posle nekog vremena opterecenja:
EDIT: Koliko smem da idem sa DDR naponom za ovaj jeftini transcend sa elpidinim cipovima? :)
Meni ovo bash nisu realne temperature na tom kloku....
Hladnjak: Thermalright Ultra-120 Extreme
Ventilator: Sunon 120mm 3500rpm
Kuciste otvoreno, odlicno provetreno kuciste, radi klima u sobi.
CoreTemp pokazuje jos nize temperature od HWMonitora.
P.S. Nadam se da gledas max temp iz HWMonitora, a ne iz CoreTemp-a (to su temp na idle-u).
Mozes ici na 2.2V sa ventom preko... ;)
@jbl, nije prime-om opterecivao, pa su max temp od 61c za jezgra sasvim normalne ;)
Pa temp. su mnogo dobre za toliko volti imas ~3-5c nizi idle od mene, mada meni load pod Prime je ~68-70c gde bi tebi trebalo da bude nesto vise ako ti je tokom igre ~61c ali kod mene je samo 1.376v.
A fan ti nije isao preko 1400RPM ? i koliko ti je u sobi *** ?
A za memaru ko sto i warmaster rece, mada ako se ne greju ja bi isao i na do 2.25v ako donosi neki veci OC i ako su hladne ( kad se hlade :p )
Pa vec rekoh Ventilator: Sunon 120mm 3500rpm na thermalright-u :)
Ne znam kolika je temp u sobi. Uglavnom celo po podne drzim klimu na "dry". Dovoljno za trenerku i duks. :D
Imam neki 140mm fan koji stoji van kucista i uperen na NB i memoriju.
Paz... prolazim sve moguce 3dmarkove, crysis testove, milion loop-ova bez problema, a onda stavim da vrti samo cpu testove u 3dmarku. posle 10-15 pukne. Kako da poboljsam stabilnost?
Evo trenutnih setovanja:
Extreme Tweaker
FSB Frequency: 423
PCI-E Frequency: 110
DRAM Frequency: 824
CAS# Latency: 6
RAS# Precharge: 5
RAS# ActivateTime: 16
CPU Voltage: 1.500v
North Bridge Voltage: 1.49v
DRAM Voltage: 2.12v
@Space, tako je rekao Diablo ;) Ne treba mu Prime stable ;)
@Diablo, tesko da ce ti proc izgurati toliku stabilnost, jer dosta zavisi i od primerka ;) Malo si ga preterao sa nb, mozda i to kolje, a i sama freq od 3.8ghz pri 1.5v na vazduhu je malo :S
U svakom slučaju evo jednog stable podešavanja ali na vodi http://www.sx-team.com/forum/index.php?showtopic=645. Sa druge strane treba da se pročita uputstvo, severni most preko 400MHz mora pod obavezno da se hladi kada je Quad u pitanju. Što se tiče TRUE kulera njegova moć se oseti tek kada se promeni način vešanja ima i o tome baš velika tema sxt-u http://www.sx-team.com/forum/index.php?showtopic=515
@Diablo stari nje te bilo dugo na forumu, stvari su se malo izmenile, pa bi najlakše bilo kad bi smogao vremena da pročitaš uputsvo sa sxt-a. :wave:
Trazi mi da budem clan SX-a kako bih temu iz prvog linka. Ono za srafove mi se svidja. Kupicu ih i pritegnuti kuler malo bolje. :)
Stvarno me nije bilo na forumu poduze vreme. Nekoliko generacija grafickih kartica sam prespavao, a vala i ostalog hardvera. :D Totalno van svih desavanja i trendova... sve do pre jedno 2 meseca kad resih da se ponovim. Citao sam sta sam stigao i gde sam stigao. Prvo oko izbora komponenti, a potom i oko OC-a quada.
Ajd odoh sad da se registrujem i na SX pa sutra da prosvrljam po nekim OC temama i tamo. :)
:wave:
Isplati li se skinuti NB hladnjak sa ove ploce i staviti termalnu pastu umesto fabricke "zvake"? Ne mogu najbolje da vidim, ali deluje kao da se moraju skinuti hladnjaci sa NB i SB zajedno (mosfet hladnjaci bi ostali)".
@Spacemaster: Koliko si dobio na OC-u otprilike zamenom srafova na TR-u?
pozz
P.S. Na 3.7GHz radi stabilno. Jos uvek se bakcem sa setovanjima za 3.8.
Koliko sam primetio, na mojoj Rampage nije pasta vec termalna folija ;) Svakako je preporucljivo staviti pastu ;)
NB hladnjak je za plocu pricvrscen srafovima. A cime je pricvrscen SB hladnjak? Mislim, kako njega da skinem?
Uf, ne secam se.. Sada mi je ploca u kucistu. Ili je i on na srafovima ili je na zabicama
Nije na srafovima. Jel to znaci da treba celu plocu da vadim da bih skinuo te zabice?
Tek sad vidim kako se drze te zabice. Mora ploca da se vadi.
