<?php
/*** Clock -- beginning of server-side support code
by Andrew Shearer, http://www.shearersoftware.com/
v2.1.2-PHP, 2003-08-07. For updates and explanations, see
<http://www.shearersoftware.com/software/web-tools/clock/>. ***/
/* Prevent this page from being cached (though some browsers still
cache the page anyway, which is why we use cookies). This is
only important if the cookie is deleted while the page is still
cached (and for ancient browsers that don't know about Cache-Control).
If that's not an issue, you may be able to get away with
"Cache-Control: private" instead. */
header("Pragma: no-cache");
/* Grab the current server time. */
$gDate = time();
/* Are the seconds shown by default? When changing this, also change the
JavaScript client code's definition of clockShowsSeconds below to match. */
$gClockShowsSeconds = false;
function getServerDateItems($inDate) {
return date('Y,n,j,G,',$inDate).intval(date('i',$inDate)).','.intval(date('s',$inDate));
// year (4-digit),month,day,hours (0-23),minutes,seconds
// use intval to strip leading zero from minutes and seconds
// so JavaScript won't try to interpret them in octal
// (use intval instead of ltrim, which translates '00' to '')
function clockDateString($inDate) {
return date('l, F j, Y',$inDate); // eg "Monday, January 1, 2002"
function clockTimeString($inDate, $showSeconds) {
return date($showSeconds ? 'g:i:s' : 'g:i',$inDate).' ';
/*** Clock -- end of server-side support code ***/
<html>
<head>
<title>Clock</title>
<meta name="template" content="none">
<script language="JavaScript" type="text/javascript">
/* set up variables used to init clock in BODY's onLoad handler;
should be done as early as possible */
var clockLocalStartTime = new Date();
var clockServerStartTime = new Date(<?php echo(getServerDateItems($gDate))?>);
/* stub functions for older browsers;
will be overridden by next JavaScript1.2 block */
function clockInit() {
</script>
<script language="JavaScript1.2" type="text/javascript">
/*** simpleFindObj, by Andrew Shearer
Efficiently finds an object by name/id, using whichever of the IE,
classic Netscape, or Netscape 6/W3C DOM methods is available.
The optional inLayer argument helps Netscape 4 find objects in
the named layer or floating DIV. */
function simpleFindObj(name, inLayer) {
return document[name] || (document.all && document.all[name])
|| (document.getElementById && document.getElementById(name))
|| (document.layers && inLayer && document.layers[inLayer].document[name]);
/*** Beginning of Clock 2.1.2, by Andrew Shearer
See: http://www.shearersoftware.com/software/web-tools/clock/
Redistribution is permitted with the above notice intact.
Client-side clock, based on computed time differential between browser &
server. The server time is inserted by server-side JavaScript, and local
time is subtracted from it by client-side JavaScript while the page is
loading.
Cookies: The local and remote times are saved in cookies named
localClock and remoteClock, so that when the page is loaded from local
cache (e.g. by the Back button) the clock will know that the embedded
server time is stale compared to the local time, since it already
matches its cookie. It can then base the calculations on both cookies,
without reloading the page from the server. (IE 4 & 5 for Windows didn't
respect Response.Expires = 0, so if cookies weren't used, the clock
would be wrong after going to another page then clicking Back. Netscape
& Mac IE were OK.)
Every so often (by default, one hour) the clock will reload the page, to
make sure the clock is in sync (as well as to update the rest of the
page content).
Compatibility: IE 4.x and 5.0, Netscape 4.x and 6.0, Mozilla 1.0. Mac & Windows.
History: 1.0 2000-05-09 GIF-image digits
2.0 2000-06-29 Uses text DIV layers (so 4.0 browsers req'd), &
cookies to work around Win IE stale-time bug
2.1 2002-10-12 Noted Mozilla 1.0 compatibility; released PHP version.
2.1.1 2002-10-20 Fixed octal bug in the PHP translation; the number of
minutes & seconds were misinterpretes when less than 10
2.1.2 2003-08-07 The previous fix had introduced a bug when the
minutes or seconds were exactly 0. Thanks to Man Bui
for reporting the bug.
var clockIncrementMillis = 60000;
var localTime;
var clockOffset;
var clockExpirationLocal;
var clockShowsSeconds = false;
var clockTimerID = null;
function clockInit(localDateObject, serverDateObject)
var origRemoteClock = parseInt(clockGetCookieData("remoteClock"));
var origLocalClock = parseInt(clockGetCookieData("localClock"));
var newRemoteClock = serverDateObject.getTime();
// May be stale (WinIE); will check against cookie later
// Can't use the millisec. ctor here because of client inconsistencies.
var newLocalClock = localDateObject.getTime();
var maxClockAge = 60 * 60 * 1000; // get new time from server every 1hr
if (newRemoteClock != origRemoteClock) {
// new clocks are up-to-date (newer than any cookies)
document.cookie = "remoteClock=" + newRemoteClock;
document.cookie = "localClock=" + newLocalClock;
clockOffset = newRemoteClock - newLocalClock;
clockExpirationLocal = newLocalClock + maxClockAge;
localTime = newLocalClock; // to keep clockUpdate() happy
else if (origLocalClock != origLocalClock) {
// error; localClock cookie is invalid (parsed as NaN)
clockOffset = null;
clockExpirationLocal = null;
else {
// fall back to clocks in cookies
clockOffset = origRemoteClock - origLocalClock;
clockExpirationLocal = origLocalClock + maxClockAge;
localTime = origLocalClock;
// so clockUpdate() will reload if newLocalClock
// is earlier (clock was reset)
/* Reload page at server midnight to display the new date,
by expiring the clock then */
var nextDayLocal = (new Date(serverDateObject.getFullYear(),
serverDateObject.getMonth(),
serverDateObject.getDate() + 1)).getTime() - clockOffset;
if (nextDayLocal < clockExpirationLocal) {
clockExpirationLocal = nextDayLocal;
function clockOnLoad()
clockUpdate();
function clockOnUnload() {
clockClearTimeout();
function clockClearTimeout() {
if (clockTimerID) {
clearTimeout(clockTimerID);
function clockToggleSeconds()
if (clockShowsSeconds) {
else {
clockShowsSeconds = true;
clockIncrementMillis = 1000;
clockUpdate();
function clockTimeString(inHours, inMinutes, inSeconds) {
return inHours == null ? "-:--" : ((inHours == 0
? "12" : (inHours <= 12 ? inHours : inHours - 12))
+ (inMinutes < 10 ? ":0" : ":") + inMinutes
+ (clockShowsSeconds
? ((inSeconds < 10 ? ":0" : ":") + inSeconds) : "")
+ (inHours < 12 ? " AM" : " PM"));
function clockDisplayTime(inHours, inMinutes, inSeconds) {
clockWriteToDiv("ClockTime", clockTimeString(inHours, inMinutes, inSeconds));
function clockWriteToDiv(divName, newValue) // APS 6/29/00
var divObject = simpleFindObj(divName);
newValue = '<p>' + newValue + '<' + '/p>';
if (divObject && divObject.innerHTML) {
divObject.innerHTML = newValue;
else if (divObject && divObject.document) {
divObject.document.writeln(newValue);
divObject.document.close();
// else divObject wasn't found; it's only a clock, so don't bother complaining
function clockGetCookieData(label) {
/* find the value of the specified cookie in the document's
semicolon-delimited collection. For IE Win98 compatibility, search
from the end of the string (to find most specific host/path) and
don't require "=" between cookie name & empty cookie values. Returns
null if cookie not found. One remaining problem: Under IE 5 [Win98],
setting a cookie with no equals sign creates a cookie with no name,
just data, which is indistinguishable from a cookie with that name
but no data but can't be overwritten by any cookie with an equals
sign. */
var c = document.cookie;
if (c) {
var labelLen = label.length, cEnd = c.length;
while (cEnd > 0) {
var cStart = c.lastIndexOf(';',cEnd-1) + 1;
/* bug fix to Danny Goodman's code: calculate cEnd, to
prevent walking the string char-by-char & finding cookie
labels that contained the desired label as suffixes */
// skip leading spaces
while (cStart < cEnd && c.charAt(cStart)==" ") cStart++;
if (cStart + labelLen <= cEnd && c.substr(cStart,labelLen) == label) {
if (cStart + labelLen == cEnd) {
return ""; // empty cookie value, no "="
else if (c.charAt(cStart+labelLen) == "=") {
// has "=" after label
return unescape(c.substring(cStart + labelLen + 1,cEnd));
cEnd = cStart - 1; // skip semicolon
return null;
/* Called regularly to update the clock display as well as onLoad (user
may have clicked the Back button to arrive here, so the clock would need
an immediate update) */
function clockUpdate()
var lastLocalTime = localTime;
localTime = (new Date()).getTime();
/* Sanity-check the diff. in local time between successive calls;
reload if user has reset system clock */
if (clockOffset == null) {
clockDisplayTime(null, null, null);
else if (localTime < lastLocalTime || clockExpirationLocal < localTime) {
/* Clock expired, or time appeared to go backward (user reset
the clock). Reset cookies to prevent infinite reload loop if
server doesn't give a new time. */
document.cookie = 'remoteClock=-';
document.cookie = 'localClock=-';
location.reload(); // will refresh time values in cookies
else {
// Compute what time would be on server
var serverTime = new Date(localTime + clockOffset);
clockDisplayTime(serverTime.getHours(), serverTime.getMinutes(),
serverTime.getSeconds());
// Reschedule this func to run on next even clockIncrementMillis boundary
clockTimerID = setTimeout("clockUpdate()",
clockIncrementMillis - (serverTime.getTime() % clockIncrementMillis));
/*** End of Clock ***/
</script>
</head>
<body bgcolor="#FFFFFF"
onload="clockInit(clockLocalStartTime, clockServerStartTime);clockOnLoad();"
onunload="clockOnUnload()">
<div id="ClockTime" style="position: absolute; left: 406px; top: 28px;
width: 200px; height: 20px; z-index: 11; cursor: pointer"
onclick="clockToggleSeconds()">
<p><?php echo(clockTimeString($gDate,$gClockShowsSeconds));?></p>
</div>
<div id="ClockBkgnd" style="position: absolute; left: 406px; top: 28px;
width: 200px; z-index: 10">
<p> <br>
<?php echo(clockDateString($gDate));?></p>
</div>
<p><i>Click on the time to show or hide seconds.</i></p>
</body>
</html>
Verovatno ces morati da dodas tih 6 kao privremenu meru 😉na hostu kazu da je do phpbb a na phpbb kazu da je do hosta
Ako znas kako mozes to i rucno, a da ti i dalje stoji +1 ili jednostavno stavi napomenu da je privremeno +7 i kad srede sat na hostu vrati nazad.
Drugo pitanje je: a gde se nalazi host, tj u kojoj je vremenskoj zoni?
Pa reci coveku da nije dobro uradjen copy/paste i da mu fali pocetak php taga, tj. treba da pocinje sa:Nije serpent napisao kada pise > /*** Beginning of Clock 2.1.2, by Andrew Shearer
<?php
@dehi15697Kod:<?php /*** Clock -- beginning of server-side support code
S obzirom da ni toliko nisi uspeo sam da provalis, zaboravi na moj komentar oko manuelne promene vremena 😀
Promeni vremensku zonu iz control panela i reci da to tako mora da bude do daljnjeg 😉
^^Kad sam ne konta, sta imam da mu objasnjavam.
