[Laptop] Acer Aspire 5920G
@Northwood:
Obavešten kao i obično :)
u pravu si, stiže dosta toga novog, prvo nam stiže:
LX.ANU0X.100, Aspire 7720G-832G64Hn PENRYN
· Intel® Core™ 2 Duo T8300 (2.4 GHz, 800 MHz FSB, 3 MB L2) PENRYN CORE
· 2GB DDRII (1 x 2GB, 1 slot free)
· 2 x 320GB HDD RAID 0+1 (5400rpm)
· HD DVD Drive with DVD-RW super multi support
· Nvidia Gforce 8600GT-512MB DDRII
· 17” LCD Acer CrystalBrite 1440x900 super high brightness
· Acer Gemstone A design with holographic finish (white)
· Acer CrystalEye 0.3Mpix Webcam
· TV tuner DVB
· BlueTooth 2.0
· DVI, HDMI, TV Out, Dolby Surround with subwoofer
· G-LAN, modem, WLAN (a/b/g/DraftN), 5-in-1 card reader
· ExpressCard slot, FireWire, 4xUSB
· Microsoft Office 2007 trial
· Microsoft Vista Home premium
Očekivana cena za krajenjeg kupca (bez PDV) će biti 1355 EUR
@Acer Specialist: A sta je sa Aspire 7720-812G25Mn? Koja ce biti njegova preporucena cena i kad stize? Karakteristike:
- Intel Core 2 Duo T8100, 2.1 GHz, 3MB L2 cache, 800 MHz FSB Penryn
- 2048 MB DDR2 667MHz
- 17-inch WXGA + (1440 x 900) CrystalBrite
- NVIDIA GeForce 8600M GT, 512MB DDR2 dedicated
- 250 GB SATA
- DVD Super Multi DL
- 4 x USB 2.0 ports, 1 x ExpressCard ™ / 54 slot, 1 x 5-in-1 card reader (SD / MMC / MS / MS PRO / xD), 1 x DVI-D port with HDCP support, 1 x IEEE 1394 port, 1
x Consumer infrared (CIR) port, 1 x External display VGA port, 1 x S-video/TV-out (NTSC / PAL) port, 1 x AV-in port, 1 x RF-in jack, 1 x Headphones / speaker / line-out jack with S / PDIF support, 1 x jack-in Microphone, 1 x Line-in jack, 1 x RJ-45 Ethernet port, 1 x RJ-11 modem port, 1 x DC - in jack for AC adapter
- Modem 56K V.92, Wired 10/100 Ethernet LAN, Intel PRO / Wireless 3945ABG LAN 802.11b / g
- Microsoft Windows Vista Premium Edition
- Acer CrystalEye Webcam
- 8 cells Li-Ion battery
- Weight: approximately 3.5 Kg
- Warranty: 1 years
I ako nije problem da odgovoris na ovo: Bluetooth na 7720-302G50Mi
Problem!!!
Proslo je 2 mjeseca od kupovine A5920g i sad prije neki da uocio sam da su mi se pojavili na nekoloiko mjesta mrtvi pixeli....na crnoj pozadini su mi bijele tackice(samo na crnoj)na bijeloj i ostalima je sve ok....sta da radim?da ga vratim posto je pod garancijom,tj.da li je tu ukljucena garancija?:mad::mad::mad:
najbolje da pozoves servis pa ih pitas ;)
pokusaj sa http://www.jscreenfix.com/
srecno :wave:
Zasto nema nista na Google-u o tom novom Aceru Aspire 7720G-832G64Hn?
Nadje samo dva sajta od kojih je jedan ovaj a drugi je isto domaci? :trust:
Inace ta dva modela izgleda imaju i Blu Ray/HD DVD citace pa je sad pravo pitanje sta uzeti?!
a da li je ovo thread o 7720G? :trust:
Pa i nije ali je malo cudno zar ne?(Ako sam ista zgrijesio time onda se izvinjavam)
Inace ovaj drugi najavljeni model (Acer Aspire 5920G-812G32Bn ) ima Blu-Ray citac pa me interesuje hoce li (ili da li je vec) Blu-Ray nadmasiti HD DVD posto nisam u toku :D :D i interesuje me koliko traje baterijana ovome Aspire 5920G-302G16Mi
da li je neko pazario model sa Penryn-om? :)
pre svega me zanima temperatura samog procesora, razlika izmedju 65 i 45nm, ne bitno koja frekvencija (posto mogu da uporedim sa celom T7xxx serijom :)), samo ocitavanja temperatura!...thx
@Acer Specialist: da li ti mozda imas neke informacije o tome? :)
5920G-302G25Mn - Vista Base Score
zanima me jel ovo normalan Vista Base Score za 5920G-302G25Mn??
nekako mi se cini prenizak....
Vista Business je instalirana...
kako mogu utjecati na taj score??
jel ima veze s driverima??
sta se uopste opterecujete Vista skorom!? :trust:
Ako sve radi kako treba (vase redovne aktivnosti + sinteticki programi) onda Vista tu nema sta da ocenjuje ;)
Ma kakva Vista, meni je dala skor 1.0 :(
Posto mi je Laptop bio na bateriji kad je test otpoceo:):):):)
Kupio sam i ja Acer 5920G sa diskom 160GB, platio 76700 din u Stevaco. Vistu sam bekapovao na dva dvd i 1 dvd za drivers and application. Podelili su disk na 5 particija. Dve se vide C i D, dve neke skrivene EISA (ne znam cemu ovo sluzi, pretpostavljam za fabricki backup) i 1 mala particija od 512 M u FAT32 sistemy. Tek neznam cemu ona sluzi. By the way ubio sam sve te particije, napravio 2 i instalirao stari dobri XP. Radi sad mnogo brze nego sa Vistom. Svi drajveri imaju na americkom sajtu ACER-a. Medjutim ostao mi je jedan znak pitanja u device menageru, PCI MEMORY CONTROLER. Da li neko zna sta je to, tj. pod koji drajver to potpada. Za plocu nije, njega sam instalirao. Vidi mi i ostale komponente za koje znam. Da li neko zna sta je to?
Pozdrav
Pozdrav
verovatno je Intel Robson (Intel® Turbo Memory) koja radi samo u Visti ako se ne varam...
A dali moze da se koristi Vistin drajver. Nisam probao jer je exe file. A sta je to? Flash memory na ploci, ili sta?
Intel Turbo Memory
ReadyBoost
IBM, tj. Lenovo ima programcic za disable ovog uredjaja pod XP/2000 OS-u za svoje laptopove (ne znam da li ce raditi i na Acer-u)...
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-68244
Microsoft Windows XP/2000 operating systems do not support Intel Turbo Memory. If you are using Windows XP/2000, there will be a Yellow Exclamation (!) shown in Device Manager. This package is to eliminate the Yellow Exclamation (!) in Device Manager.
pokusaj sa njim da resis problem :)
Pa ti si CAR:D:D:D:D:D
Radi! Puno ti hvala.
:banana::banana::banana:
CAR je on, a ja sam northwood :D ahahah...sala mala...cimaj ako treba jos neka pomoc ;)
Pozdrav svima...
Vrlo sam zadovoljan Acerom, osim što mu treba dosta vremena da loaduje Vistu.
Počev od samog paljenja, pa i kasnije, kada se ulogujem, da bi učitao sve, i Norton Security, baš ume da potraje...s obzirom na konfiguraciju, očekivao sam da će ići mnogo brže.
Kada se sve učita, onda je super, ali ovo dugo učitavanje ume malo da smara.
Nisam do sada imao Vistu, tako da ne znam da li je to normalno i koje je prosečno vreme učitavanja, ali meni deluje da je sporije od uobičajenog...Još neko sa sličnim "problemom"?
Pozdrav svima...
dovoljno je to sto si pomenuo Norton :D
iskljuci nepotrebne programe iz startup-a i donekle ces osetiti ubrzanje boot-a...
to nije problem vec klasika Viste, zato ja i drzim tweak-ovan 2003 Server kao OS ;)
Isključio sam uglavnom sve što ne koristim, tipa ono za wireless i neki njegov menadžer za net, ako znaš na šta mislim...
Blue screen of death
Mom prijatelju pojavio se blue screen i pise> Bad Pool Caller?zadnje sto je install je NFS Pro street....da li zna neko kako mogu da iskljucim blue screen....?ili da rijesim ovaj problem?
Da li je neko uspeo da instalira Leopard na ovo cudo?
Planiram da pokusam sutra...
Moj drug je uspeo, mada je imao nekih problema(prvenstveno sa drajverima)!! Ajd videcu sa njim sutra pa ti javljam sta je bilo i sta se desilo. Znam samo da mu je po...je...balo neke stvari!!!!
Al zato ubuntu sljaka kao........
Odlicno, drajveri mi i trebaju, a nema sta da se po**** posto sam formatirao hard :) .
Instalirao sam Leopard, naravno bez zvuka i LANa.
Cudno je sto je posle nekog vremena tastatura prestala da radi, pokusavam da provalim u cemu je problem.
Navodno je moguce sve naterati da radi. Ako neko zna nesto o ovome neka pomogne :) .
