Ajde neko ko je pokretao test bat iz bin32 foldera,ako moze, da proveri da li mu test ocitava podesavanja u samoj igri ili kao kod mene bez obzira na podesavanja pokazuje HIGH...??
Izgleda da je Crysis Benchmark Tool merodavniji..
Crysis_Benchmark_Tool-[www.guru3d.com]
Skini odavde.....
Ajde probaj da u igri namestis Medium podesavanja pa pokreni onaj test iz Bat-a..Bas me interesuje da li pise High u testu..
To sam i uradio...samo sto nisam okacio sliku(ne dozvoljava mi kacenje atachmenta)...uradio sam copy cmd...
:wave:
Mali update nakon instaliranja Patch-a 1.1
X6800@3225
8800GTX 630/1475/2000
1/15/2008 4:50:20 PM - XP
Beginning Run #1 on Map-island, Demo-benchmark_gpu
DX9 1280x1024, AA=No AA, Vsync=Disabled, 32 bit test, FullScreen
Demo Loops=3, Time Of Day= 9
Global Game Quality: High
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 46.84s, Average FPS: 42.70
Min FPS: 30.57 at frame 166, Max FPS: 53.69 at frame 990
Average Tri/Sec: 42046868, Tri/Frame: 984743
Recorded/Played Tris ratio: 0.93
!TimeDemo Run 1 Finished.
Play Time: 43.72s, Average FPS: 45.75
Min FPS: 30.57 at frame 166, Max FPS: 53.81 at frame 1021
Average Tri/Sec: 45558488, Tri/Frame: 995796
Recorded/Played Tris ratio: 0.92
!TimeDemo Run 2 Finished.
Min FPS: 30.57 at frame 166, Max FPS: 55.05 at frame 1004
Average Tri/Sec: 45595992, Tri/Frame: 996851
TimeDemo Play Ended, (3 Runs Performed)
Completed All Tests
<><><><><><><><><><><><><>>--SUMMARY--<<><><><><><><><><><><><><>
Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 45.75
1/15/2008 5:25:48 PM - XP
Beginning Run #1 on Map-island, Demo-benchmark_cpu
TimeDemo Play Started , (Total Frames: 1500, Recorded Time: 44.62s)
Play Time: 37.29s, Average FPS: 40.23
Min FPS: 29.93 at frame 1085, Max FPS: 54.90 at frame 102
Average Tri/Sec: 39308048, Tri/Frame: 977108
Recorded/Played Tris ratio: 0.74
Play Time: 34.71s, Average FPS: 43.22
Min FPS: 29.93 at frame 1090, Max FPS: 54.90 at frame 102
Average Tri/Sec: 42302204, Tri/Frame: 978820
Play Time: 34.18s, Average FPS: 43.89
Min FPS: 29.93 at frame 1090, Max FPS: 54.91 at frame 106
Average Tri/Sec: 42841924, Tri/Frame: 976206
Completed All Tests
Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 43.555
@box85 ako ti nije tesko odradi cpu2 bench, koji se dobija patchovanjem na 1.1 (u bin32 folderu), pod ovim uslovima.
@goranm ne treba svima je na high toliko, vidi ostale rezultate.
Nesto ti tu nije na high, posto ti je Tri/Frame: 978820, a treba preko 1 miliona.
Poslusao sam tvoj savet, pa sam reinstalirao igru i dobio sledece rezultate (imam i slike, ali u predhodnom postu sam objasnio svoju situaciju):
X6800@3225
8800GTX 633/1484/2014
1/17/2008 12:13:12 AM - XP
Demo Loops=4, Time Of Day= 9
Play Time: 36.50s, Average FPS: 41.09
Min FPS: 28.98 at frame 1093, Max FPS: 55.53 at frame 103
Average Tri/Sec: 40184088, Tri/Frame: 977845
Play Time: 33.28s, Average FPS: 45.07
Min FPS: 28.98 at frame 1093, Max FPS: 57.90 at frame 112
Average Tri/Sec: 44093372, Tri/Frame: 978254
Play Time: 33.30s, Average FPS: 45.05
Min FPS: 28.98 at frame 1093, Max FPS: 58.24 at frame 113
Average Tri/Sec: 44157736, Tri/Frame: 980155
Recorded/Played Tris ratio: 0.73
!TimeDemo Run 3 Finished.
Play Time: 33.36s, Average FPS: 44.97
Min FPS: 28.98 at frame 1093, Max FPS: 58.30 at frame 113
Average Tri/Sec: 43946772, Tri/Frame: 977261
TimeDemo Play Ended, (4 Runs Performed)
Completed All Tests
Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 45.03
1/16/2008 8:44:16 PM - XP
Play Time: 44.46s, Average FPS: 44.98
Min FPS: 30.41 at frame 168, Max FPS: 57.74 at frame 992
Average Tri/Sec: 44308296, Tri/Frame: 984986
Play Time: 41.09s, Average FPS: 48.67
Min FPS: 30.41 at frame 168, Max FPS: 58.58 at frame 997
Average Tri/Sec: 48471444, Tri/Frame: 995883
Min FPS: 30.41 at frame 168, Max FPS: 59.42 at frame 1009
Average Tri/Sec: 48519584, Tri/Frame: 996829
Completed All Tests
Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 48.67
Ako te cudi sto su rezultati veci, jedini moguci razlog je sto sam igru presao sa tweak-om na Very High, a potom eksperimentisao sa nekim setovanjima za Ultra High (koji nisu radili :smash. A jedini backup za High mi je bio jos od Demo-a.
X6800@3225
Completed All Tests
Completed All Tests
Gore je objasnjenje. Ima ralike da li testiras sa bin fajlom ili programom za test.
Ima, i to oko pola frejma u Gpu testu, i cak do 2 frejma :trust: za CPU test u korist CBT-a, inace odradio sam jos juce sve testove i iz bin fajla, kao i one iz CBT-a.
Evo to izgleda odprilike ovako iz BIN fajla:
X6800@3225
Fps.....................GPU....................CPU
Min:...................29.21..................30.81
Avg:..................48.18..................43.10
Max:..................59.15..................56.84
Tri/Frame:.........1021299..............1025943
Nego jel znas sto ne mogu da postujem slike? Cini mi se da sam naleteo na jos par ljudi sa istim problemom.
X6800@3225
C2Q E6600@3000Mhz
Gainward 8800GTS 512MB 750/2000/1875 GPU/MEM/SHADER
1680x1050
AVG = 37.5 fps
GTX by BOX85 45.75
