Crysis Benchmark CPU/GPU [HIGH]
Vidio sam u par igara gdje 8800GTS SLI ima losiji fps od jedne GTS. Vjerovatno je tako situacija i sa Atijem. Ja drivere koristim tweakforce, tj zadnje na njihovom sajtu. Ove zadnje testove sam radio sa njihovim driverima XTreme-G 169.17 XP 32bit
Sto bre te drajvere sinko :D.
Pa imas oficijelne whql 169.21 :type:.
Dojadile mi vise bete...
Nisam bio na nvidia sajtu 2-3 mjeseca. Samo tweakforce drivere koristim:)
to ti ja i pricam isto je i sa atijem, nesto fes kubure sa SLI/CF optimizacijom
Lijepi voodoo2 sli kad se sjetim. 2x po 200 njemackih maraka. Kako je tad sve lijepo radilo, a sad....:) Ja sam na par dana imao 8800GTS sli. U krizi sam dobio samo 10fps. Iznervirao sam se i prodao je. I rekao sam sebi nikad vise SLI, crossfire!
eh lepa vremena i 3dfx GLIDE mod rada, uh kako je to sve klizilo covece a o lepoti grafike da ne pricamo.... :(, odosmo u debeli off sada...
1280x1024 HIGH
1440x900 (very high tweak, ali bez colour grading efekta - menja boje a utice na performanse, doduse nisam testirao)
Iz nekog razloga ne mogu da stavim attachment :trust:
Kad budem imao vremena uradicu 1680x1050 (high)
1680x1050 (high) :wave:
Popravka. Nije nesto ali sto da ne.
E2180@3600
8800GTS 512 800/2000/2160
1/9/2008 11:42:25 PM - XP
Beginning Run #1 on Map-island, Demo-benchmark_gpu
DX9 1280x1024, AA=No AA, Vsync=Disabled, 32 bit test, FullScreen
Demo Loops=3, Time Of Day= 9
Global Game Quality: High
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 42.60s, Average FPS: 46.95
Min FPS: 32.18 at frame 138, Max FPS: 60.77 at frame 1011
Average Tri/Sec: 46248760, Tri/Frame: 985029
Recorded/Played Tris ratio: 0.93
!TimeDemo Run 1 Finished.
Play Time: 38.08s, Average FPS: 52.52
Average Tri/Sec: 52276988, Tri/Frame: 995414
Recorded/Played Tris ratio: 0.92
!TimeDemo Run 2 Finished.
Play Time: 38.05s, Average FPS: 52.56
Min FPS: 32.18 at frame 138, Max FPS: 61.62 at frame 985
Average Tri/Sec: 52343672, Tri/Frame: 995938
TimeDemo Play Ended, (3 Runs Performed)
Completed All Tests
<><><><><><><><><><><><><>>--SUMMARY--<<><><><><><><><><><><><><>
Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 52.54
1/9/2008 11:47:34 PM - XP
Beginning Run #1 on Map-island, Demo-benchmark_cpu
TimeDemo Play Started , (Total Frames: 1500, Recorded Time: 44.62s)
Play Time: 34.19s, Average FPS: 43.87
Min FPS: 32.17 at frame 1079, Max FPS: 59.41 at frame 372
Average Tri/Sec: 42917392, Tri/Frame: 978240
Recorded/Played Tris ratio: 0.74
Play Time: 30.70s, Average FPS: 48.86
Min FPS: 32.17 at frame 1079, Max FPS: 62.85 at frame 123
Average Tri/Sec: 47891268, Tri/Frame: 980095
Recorded/Played Tris ratio: 0.73
Play Time: 31.11s, Average FPS: 48.21
Average Tri/Sec: 47177312, Tri/Frame: 978555
Completed All Tests
Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 48.535
11.01.2008 18:28:28 - XP
Play Time: 66.10s, Average FPS: 30.26
Min FPS: 16.68 at frame 154, Max FPS: 38.19 at frame 877
Average Tri/Sec: 29802294, Tri/Frame: 985010
Play Time: 56.31s, Average FPS: 35.52
Min FPS: 16.68 at frame 154, Max FPS: 42.28 at frame 991
Average Tri/Sec: 35366808, Tri/Frame: 995825
Play Time: 56.22s, Average FPS: 35.58
Average Tri/Sec: 35444440, Tri/Frame: 996265
Completed All Tests
Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 35.55
Jel ovo dobar skor ili ne??
Probao sam da malo kloknem proc ,ali se rezultat nije popravio...
Completed All Tests
Mozda ipak ima razlike izmedju C2duo i Athlona, ali whip tvrdi da nema, tako da mislim da je ovo ipak malo:
min fps 16,68
avg fps 35,5
max fps 42
Ja sa GTS 320MB (sa stabilnim IGRIVIM klokovima 660/950) imam
min fps 25,2
avg fps 36,4
max fps 43,6
Min fps nemoj posebno nesto da gledas, on jednostavno varira, meni je nekada kada testiram 20 nekada 22-23, a nekada 25.
Tako da probaj nove drajvere i jos klokuj graficku, ako zelis da izvuces max rezultat, mada sto se tiche igranja, ti tvoji fps-ovi su sasvim dovoljni za komotno igranje, jer su veoma slicni sa mojim :type:.
Ali u principu bi trebalo da imas vise od mene, jer je 3870 512MB brza od GTS 320MB. Jedino ako ovaj moj C2Duo pravi prednost nad tim Athlonom, ali sumnjam da je to slucaj.
min fps 16,68
avg fps 35,5
max fps 42
min fps 25,2
avg fps 36,4
max fps 43,6
Pa to je rez se klokovanom karticom 850/1350 i sa proc na 3,2 GHz zato mi je i cudno sto ima tako malo FPS.(Iskreno ocekivao vise.Mozda ima dosta istine da je ova igra bolje optimizovana za Nv...)Drajveri najnoviji 7.12..
A u 3dmark06 ide preko 11k.Inace u samoj igri ne primecujem nikakva seckanja(AA na 4x i sve na high)..
Ja u 3DMark06 imam 11300 poena (sa stabilnim klokovima za igranje 660/950, dok sa nestabilnim imam), mada tu je prednost C2Duo nad Athlonom jasna.
A ovo drugo, pa nisi valjda pokretao test sa ukljucenim AA ?
Tema je 1280x1024 high AA iskljucen.
Ako mozes da igras na 1280x1024 AA 4x high, onda je to odlicno.
Ja nema sanse da igram sa AA toliko, eventualno 2x, ali to je zbog mojih 320MB memorije, za AA u Crysisu treba ipak 512MB memorije na brzoj kartici (moja GTS jeste brza :), ali joj fali memorije).
GTS 320 by ja 39.70
GTS 320 by Zdravko 37.06
GTS 640 by Paradigma 37.10
GT by Jera 44.75
GT by Miljko 43.38
GT by Panzer75 46.24
GT by Lanselot 40.72
GT by P$ycho 44.95
GTS 512 by Placebo 52.56
3850 by GoranM 30.44
GTX by BOX85 45.05
3870 crossfire by Studiovpc 45.25 Vista OS
3870 by terzazak 35.58
Ne znam, mozda kriza nije bash optimizovana za atija. Proc ti je ok, samo se 3870 nije bash nesto u praksi pokazao. Mada za svoju cijenu daje extra performanse. Ja sa svojim 8800GTS 320 imam oko 12.500 3dmarka06.
@zravko..." A ovo drugo, pa nisi valjda pokretao test sa ukljucenim AA ?
Tema je 1280x1024 high AA iskljucen."
Ne nisam test pokretao sa AA ,to je u igri ukljuceno na 4x....
Za 3dmark06 duplo veca razlika izmedju X2(cpu score oko 2500) i C2Duo(oko 5000)...to znam,ali u ovom testu sam probao proc na def i klokovan i skoro da nema razlike.Razlika se napravi kad kloknem karticu..Doduse nisam flesovo bios.Sa novim se kartica jos vise klokuje,ali ipak FPS bi trebao da bude veci..
Cek malo, sta ti je ukljuceno u igri? AA? Koji ti je test, jel onaj fajl sto pokrenes u folderu igre ili je original igra pa imas onaj lijepi prozor pa u njemu podesis sta hoces da imas u testu? Nisam te bash najbolje razumio.
Ma kad igram igru u podesavanjima sam stavio AA na 4x..
Sad sam i ja poceo da se gubim..:d..Ajd jedno glupo pitanje da razjasnim nesto..Kad pokrenem test Crysis Bechmark, ne mora i igra da bude pokrenuta..??
Znaci ja samo pokrenem test(Crysis_Benchmark_Tool-[www.guru3d.com]) stavim rezoluciju 12x10 i nista drugo ne menjam (bez ukljucenog AA).Test vrti tri puta i to je to..
da vrti tri puta i to je to. Samo ako si u igri stavio AA 4x onda ce ti i i testu biti 4xAA
Izgleda da nema veze koliko je AA u igri.Iskljucio sam AA i rez jedva malo bolji...
12.01.2008 12:47:26 - XP
12.01.2008 13:08:33 - XP
Play Time: 65.35s, Average FPS: 30.60
Min FPS: 17.35 at frame 137, Max FPS: 40.53 at frame 979
Average Tri/Sec: 30150266, Tri/Frame: 985222
Play Time: 55.77s, Average FPS: 35.86
Min FPS: 17.35 at frame 137, Max FPS: 42.34 at frame 984
Average Tri/Sec: 35700116, Tri/Frame: 995426
Play Time: 55.63s, Average FPS: 35.95
Min FPS: 17.35 at frame 137, Max FPS: 43.21 at frame 992
Average Tri/Sec: 35827608, Tri/Frame: 996540
Completed All Tests
Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 35.91
Completed All Tests
Test ispisuje da li je upotrebljen AA, tako da ni sada kao ni u prošlom testu koji si radio AA nije bio uključen.
Pa onda je to to ...nece vise...:smash:
Ustvari bitnije je to sto u igri uopste ne secka sa podesavanjima High i sa AA 4x..
A veci rez kad se usudim da flesujem bios kartice (890/1250)...:D
To je vec malo cudno, da ti ne secka sa AA 4x, a da imas malo losiji skor od mene kada je AA off.
Jer meni bas dosta pada fps kada ukljucim AA, doduse ti imas 512MB, a ja 320MB na grafickoj.
Mislim ni meni ne secka na 1280x1024 high AA 2x, ali mi se fps krece izmedju 25 i 35, sto nije seckanje, ali je ipak sporo :type:.
Ajde ukljuci fraps, pa kada budes igrao stavi na 1280x1024 na high AA4x, pa posle i AA2x, i pogledaj tacno koliko imas frejmova, zanima me.
Uradio sam reinstal drajvera (7.12) i posle probao ponovo test i za malo je bolji...
A sto se tice toga da mi ne secka sa AA4x nisam napomenuo da sam jos na pocetku igre.Kako cujem sto igra vise odmice sve je zahtevnija pa cu da vidim kako ce dalje da se ponasa..
12.01.2008 20:10:12 - XP
Play Time: 67.84s, Average FPS: 29.48
Min FPS: 9.53 at frame 144, Max FPS: 40.46 at frame 962
Average Tri/Sec: 28909980, Tri/Frame: 980686
Play Time: 54.99s, Average FPS: 36.37
Min FPS: 9.53 at frame 144, Max FPS: 41.44 at frame 960
Average Tri/Sec: 36045804, Tri/Frame: 991073
Play Time: 54.79s, Average FPS: 36.50
Min FPS: 9.53 at frame 144, Max FPS: 42.21 at frame 995
Average Tri/Sec: 36164764, Tri/Frame: 990779
Completed All Tests
Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 36.44
Kada se koristi Crysis benchmark tool, nema veze sta si namestio u igri. Bira se da li hoces da ukljucis AA, rezolucija, i nivo detalja. Ako se pokrene bat iz bin32 foldera onda ide test sa podesavanjima koja su namestena u igri. Takodje ovaj test nema overall average rezultat.
Pa kad pokrenem taj test bat iz bin32 foldera rez je mnogo veci...
Koji je sad merodavan onaj sa Crysis Benchmark Tool ili ovaj ...??.:D
Running GPU benchmark 1
Results will depend on current system settings
Press any key to continue . . .
Running...
12.01.2008 20:21:34 - XP
Play Time: 39.75s, Average FPS: 50.32
Min FPS: 35.98 at frame 1962, Max FPS: 71.41 at frame 966
Average Tri/Sec: 36265228, Tri/Frame: 720687
Recorded/Played Tris ratio: 1.27
Play Time: 32.66s, Average FPS: 61.23
Min FPS: 35.98 at frame 1962, Max FPS: 85.09 at frame 96
Average Tri/Sec: 44571304, Tri/Frame: 727900
Recorded/Played Tris ratio: 1.26
Play Time: 32.55s, Average FPS: 61.44
Average Tri/Sec: 44749112, Tri/Frame: 728340
!TimeDemo Run 3 Finished.
Play Time: 32.44s, Average FPS: 61.65
Average Tri/Sec: 44918428, Tri/Frame: 728596
TimeDemo Play Ended, (4 Runs Performed)
Running...
Opet ne valja, malo pre je bilo premalo, sada je premnogo :d.
Ozbiljno, nesto tu smrdi, pa mnogo jaca GTS 512 ima avg fps 52.56.
Ima je Placebo, i jos ju je dosta klokovao, dobro i ti si tu tvoju, ali GTS 512MB je sigurno brza od 3870, jer je 3870 sporija od GT-a, a plus je Crysis - The Way It;s Meant To Be Played (Nvidia) ;).
Tako da je po meni ovo veoma cudan skor...
U pravu si...Moja greska doduse nenamerna..:d
Kad sam pokrenuo test u igri su podesavanja bila setovana na MEDIUM iako je test prikazao da je HIGH..Zato je rez toliki,ali sam barem na kratko bio u vrhu trke..:D..
Kad sam vratio podesavanja na HIGH rez je bio kao ranije 36.50..
Verovatno moze jos ako bih kloknuo karticu vise sa novim biosom(onim sto ne blokira OC na 861),ali se jos ne usudjujem da flesujem...:S:
Inace oc za karticu je 860/1370..
