S22
Postavlja se pitanje da li bi ste smeli da ovo zakacite na maticnu? :hair:
http://www.anandtech.com/Gallery.aspx?id=20
:d
:d
Cooler Master impressed us with the largest cooler we’ve seen so far. The V10 consists of two 120mm fans, one mounted vertically and the other horizontally. The horizontal fan is located above the DIMM-slots and will cool the ram through the fins of the cooler later. Simply put, the V12 is massive, capable of providing AC to a small European country if necessary. The V8 has a different design, with only one 120mm fan which located in the middle of the cooler.
:zgran: http://www.anandtech.com/weblog/showpost.aspx?i=349
Skoro nisam video ništa ružnije, ovo je pravo čudovište! :-devil-:
Debilan dizajn, ogroman.A po chemu si zakljuchio da je V10 chista glupost?
Meni se sviđa ovo rešenje sa jednom 12-icom.
