3 stvari koje Microsoft ne moze da objasni...
  • Začetnik teme Začetnik teme borab
borab
Uradite sledece:
MAGIC #1
Found that nobody can create a FOLDER anywhere on the Computer which can be named as "CON". This is something funny and inexplicable… At Microsoft the whole Team, couldn't answer why this happened!
TRY IT NOW, IT WILL NOT CREATE A "CON" FOLDER
MAGIC #2
For those of you using Windows, do the following:
1.) Open an empty notepad file
2.) Type "Bush hid the facts" (without the quotes)
3.) Save it as whatever you want.
4.) Close it, and re-open it.
Noticed the weird bug? No one can explain!
MAGIC #3
Again this is something funny and can't be explained… At Microsoft the whole Team, including Bill Gates, couldn't answer why this happened!
It was discovered by a Brazilian. Try it out yourself…
Open Microsoft Word and type
=rand (200, 99)
And then press ENTER
And see the magic…..!
Ako ima jos koje cudo, napisite...
LOL
1 i 3 mi "rade"
drugo ne, sve normalno
Kod mene se sve greske pojavljuju ali 3 je posebno smesna.
Old...
MAGIC #1
isto vazi i kad pokusas da kreiras folder koji se zove aux
Vista & Office 2007: radi samo #1.
Pod XP-om rade sva tri, ja sam se baš pitao da li su u Wordu 2007 izmenili ovu "komandu" (pod 3.)
rade sva tri (XP + Office2007)
treći magic radi i sa drugim brojevima (200,80 etc )
ali ovaj drugi magic ... wtf ... how ?
3. Magic radi i na najjnovijem Word-u za Microsoft Office 2008 for Mac
Kod mene na Office 2003 rade 1. i 2.,ali 3. ne radi
http://support.microsoft.com/kb/212251
This feature is turned on by default, and is disabled when the Replace text as you type option is turned off. To turn this option on or off, click AutoCorrect on the Tools menu, click the AutoCorrect tab, and then click to select or clear the Replace text as you type check box.
Zato meni ne radi 😉
http://en.wikipedia.org/wiki/The_quick_brown_fox_jumps_over_the_lazy_dog
Češće ceđenje mrežastim džakom poboljšava fertilizaciju genskih hibrida.
Ahah 🙂
hehe treca je najjaca 😀 fox and lazy dog 😀
Znao sam za ovu caku još odavno, ali reko ajde da probam da li oni parametri 200 i 99 prave neki problem. Na kraju sam se baš razočarao, u novom Wordu nema više lije 🙁 . Word 2007 izbacuje neke rečenice iz Helpa.
u magic 2 mogu da se imzene slova opet radi
a i ovo sve je staro mnogo
ovo je malo bezveze - mislim, ne može M$ da objasni? Nebuloza!
Zaključavajte ovaj thread!
Mozda je staro, ali za magic 2 i 3 nisam znao 😀 a inace, rade sva tri i kod mene. I naravno da sve moze da se objasni, samo... :wall:
Sto volim ovakve postove... Sta ti smeta ako je tema otkljucana?? Ako ti se ne svidja zaobidji. Mislim, nije mi vazno da li ce tema biti zakljucana ili ne, ali definitivno nije na tebi da odlucujes o tome (srecom). Postoje ljudi koji su zaduzeni za to.
Zaista ovo sve radi....WindowsXP + Office 2k7.....
Radi i notepad, i folder.....
Kako, zasto :S:
koji 3p 😀
idem da saljem caletu ovo na mail, da se pravi posle pametan na poslu.
Ova druga radi ako se upotrebi kombinacija:
[jedna rec sa cetiri slova] [dve ili vise reci sa tri slova] [jedna rec sa pet slova]
i pokusa se snimanje u ASCI kodu.
znaci moze i
Pero nas pas smrdi
Magic #1
CON je bio naziv uređaja u dos-u , zato se ne može nazvati folder, ali ni fajl, njegovim nazivom.Isto to važi i za bilo koji port (com, prn, lpt).To i nije ništa naročito, oduvek postoji.
Ovo je sa jednog sajta:
copy con test.txt
Once the above command has been typed in, a user could type in whatever he or she wishes. When you have completed creating the file, you can save and exit the file by pressing CTRL+Z, which would create ^Z, and then press enter. An easier way to view and edit files in MS-DOS would be to use the edit command.
A ovo ostalo je stvarno misterija :bottle:
moze da se napravi i CON direktorijum
start, run pa pokrenite konzolu sa cmd
c:\
md\\.\\c:\\con
i eto vam con folder, za brisanje upotrebite DOS analogiju. 😉
