D
Ne moze. Uredjaj ne sluzi za to![]()
Mislim, kome bi pala ideja da uredjaj od 300 USD koristi kao kabl za povezivanje (npr.) MacBook Pro sa TV-om![]()
samo reklamirasccc
E jedva cekam nove iMac-ove. Nadam se da ce mi to biti good-bye za PC.
Fale vece senke :wall::wall:
Bio sam ironican. Ne znam cemu tolike senke?
Ne znam, nekako mi deluje sve...zbudzeno s' brda s' dola.
Inace, Santa Rosa sa FSB na 800 MHz, Core 2 Duo na 2.2 GHz, 2 GB RAM-a, GeForce 8600GT-M i HDD na 7200 RPM
Ti onda vozi Win.(ili Linux, Solaris,...)
Mislim, senke, daj, zar je to najvažnije...
Iako, pakovanje jeste bitno, nije da nije.
Yeah yeah..
Pa izvini, koja je poenta da senka zauzme pola ekrana? Nisu bitne, bas zato sto nisu bitne ne mora da bude tolika.
hm... pa to mu dodje skoro isto kao i ovaj iMac koji sada imam;
FSB je: 667 vs 800
CPU: 2.13 vs 2.2GHz (mozda vise za top model)
ram: 2GB = 2GB
HDD: 7200 = 7200
gfx: 7300 vs 8600 (najveca razlika)
dakle razlika u brzini ce najverovatnije biti minimalna... :/
System requirements
You must have a Macintosh computer with:
• an Intel processor or a PowerPC G4 (800 MHz or faster) or G5 processor
• a DVD drive
• built-in FireWire
• at least 512 MB of RAM (additional RAM is recommended for development
purposes)
• a built-in display or a display connected to an Apple-supplied video card supported
by your computer
• at least 7 GB of disk space available, or 12 GB of disk space if you install the
developer tools
Migrating iCal data from Mac OS X Tiger to Mac OS X Leopard
If you use iCal and migrate from Mac OS X Tiger to Leopard, be sure to open iCal in
Leopard before you open Mail. If you don’t you will not be able to create To Do notes
in Mail.
.Mac syncing with Mac OS X Tiger and Mac OS X Leopard
.Mac syncing in Leopard introduces a new mechanism which does not sync with older
systems. Because of this you can not sync contacts, calendars, and bookmarks with
Panther or with Tiger 10.4.6 or earlier.
To sync Leopard with Tiger 10.4.7 or later, you must update .Mac syncing on the Tiger
system. However, you cannot use that Tiger system to sync with other Tiger or Panther
systems.
To update .Mac syncing on a computer using Tiger to sync with Leopard, first sync all
your data on Tiger. Next, copy transitionDotMac.sh and UnregisterDotMac, located in
/usr/bin/ on the Mac OS X Install DVD, to your Tiger system. Finally, in Terminal run
the copy of transitionDotMac.sh on your Tiger system.
If you want to revert your Tiger computer to the earlier mechanism so that it works
with other Tiger and Panther systems, run the transitionDotMac script again.
Originally Posted by Egomaniac
I'm typing this from the new seed. First, Leopard is gorgeous. Not sure why you would think otherwise, but the UI is much more attractive and consistent.
I had mixed feelings about the transparent menu bar in the last two seeds, but the slight tweaks in this seed make all the difference. It's more opaque and blurs the underlying image more, so it looks good against everything. I've got my background set to change randomly every minute, with about a hundred different images to choose from, and they all look nice with it. You'll like it.
Second, the UI changes are such a tiny thing compared to the rest of Leopard that it's amusing to see so much time spent discussing it. Leopard is not about the new UI. It's got hundreds upon hundreds of small improvements that individually may not sound all that exciting, but all together make for a huge leap forward.
After using Leopard, going back to Tiger is like fingernails on a chalkboard. And I loved Tiger.
I don't want to break my NDA in a big way, so I'll just add one more thing. Leopard is fast. Impossibly fast compared to Tiger, and it makes Vista seem like it is running in slow motion. Spotlight is really instant now, to the point that I uninstalled QuickSilver. If you've used QuickSilver, hopefully you understand what a big deal that is.
For reference, my Leopard machine is a first-gen MacBook -- the lowest configuration, but bumped to 1GB RAM. My Tiger machine is a 2.66GHz Mac Pro with 3GB RAM. And the MacBook is snappier.
I dalje je prisutna ona odvratna velika senka. Kada bi to sredili ili dozvolili da sami biramo velicinu i jacinu, bilo bi savrseno.
