Ipod
d0minat0r
koji sve formate pusta Ipod video i koji konvertor se koristi za prebacivanje u taj format
hvala unapred
Ja za konvertovanje koristim ImToo Ipod Movie Converter... Odlično mi služi... Lagan je, ima predefinisane postavke za kvalitet... Daje dobre rezultate...
LINK
Program "Super" je besplatan i odlicno radi, konvertuje sve u dosta razlicitih formata, ima predefinisane setinge za razne mobilne telefone, psp, ipod...
Jos jedan glas za "Super"!
Stvarno dobar programcic
Mali off, ali me zanima sta bi ste Vi, kao vlasnici naslova ove teme, rekli na tekst na koji sam naisao slucajno...
7 Reasons Not TO Buy THE iPoD!
1 Scratch Magnet
The Shiny Black surface of the iPod (Nano and 5th Gen) gets scratched even if you keep it inside it's inadequate Cover. The scratching can get so bad that the screen display becomes "Un-viewable",which beats the whole point of having the device!
2 Battery replacement
Most of the other portable players let you change their batteries quite easily. Not the iPod. If you need to change the batteries,you need to send the player to their service centre, where they will take a week ! Even after that ,you Will not get the same iPod back, What is returned to you is a refurbished piece. If you think I'm kidding, check out Apple's support page here: http://depot.info.apple.com/ipod
3 Doesn't flay fm
FM is no more the boring monotonous A.I.R Variety. With airwaves openinh up and cities getting up to mor & more radio stations,having Fm is a good thing and every competing portable media player out there today incoporates Fm .
4 It syncs to just one PC
Each iPod can be synced to just one pc at a time.This means that if you have synced it to your desktop,it won't work with your notebook,unless you re-sync it,which will then result in a "remove-all previous songs" accident.What a hassle !
5 Slow interface
Despite the Broadcom chip inside and Apple's claims about how great it's hardware is watching videos and forwarding/skipping through then leaves the hardware quite breathless and can be irritating at times .
6 The photo features is silly
While most portable out there let you copy images through direct drag & drop,ipod does it differently.It converts and optimizes each photo into proprietary format.This is pretty stupid because if you want to actually SHARE your photographs(Like leave a copy behind),You'll need to carry the original JPEGs separately.Also you can't directly view these JPEGs on the ipod pretty dumb if you ask me !
7 Shifting songs via iTunes is a PAIN
Why should you be limited to shifting songs only through iYunes ? Every time you get a New song from somewhere,you first need to add it to your iTunes library.Only then can you move it to your iPod.It would be so much simpler if i could moves songs by a simple copy/paste,as is the case with your players.
http://forum2.mobile-review.com/showthread.php?t=62433
1 Scratch Magnet
3 Doesn't flay fm
5 Slow interface
evo kao ponosni vlasnik jednog iPod-a mogu da ti kazem da od ovog navedenog nista nije tacno...
1. za ovo nisam siguran (ali ako si manijak izgrebaces i drugi mp3 player pa ni njega neces videti)
2. ne zaboravi da je ovo baterija na punjenje (traje dosta dugo), a ne obicne AA(A) baterije koje svakih 5 dana punis (ili kupujes - sto je jos gore)
3. ima dodatak za fm radio ukoliko hoces da ga slusas
4. ubacis winamp+plugin i prebacujes kolko hoces bez ikakvih ogranicenja
5. meni nije sporo na miniju, a ni mom drugu na 5g
6. ko kupuje iPod za slike uopste? to je samo marketing
7. ja ne koristim iTunes, kao i mnogi drugi korisnici
sve u svemu se svelo na to da je iPod najbolji (doduse ima los delimicno softver - iTunes, ali to uvek moze da se popravi ako cike iz Apple-a odluce)...i pritom koji mp3 ima 6,8,20,30,80GB????? (osim creative-a)
Ja se slazem sa Northwood-om ... i taj touchpad krug koji je zastitni znak Ipod-a je ekstra stvar jer koliko god pesama imam jako brzo se dolazi do zeljene pesme, drugo kad vrsis pregled slika on ne pravi ni mili sekundu zastoja prilikom menjanja slika, po meni nikako nije spor ! ... i takodje postoje umesto Itunesa dosta drugih programa ... sad sam probao Anapod i skroz je dobar !
Dal je je neko mogao da smisli 7 glupljih i manje tacnih stvari u vezi iPod-a?
1. Nosim iPod bez maske par meseci, i mogu da okacim sliku kako izgleda -samo 2 sitne ogrebotine.
2. Baterije mogu da se menjaju i bez slanja u nazad u Apple.
3. Ima dodatak za FM radio.
4. tvoj iPod sinhronizujes sa tvojim kompom. Ako hocu da pokupim muziku od nekog, prebacim je na iPod (u funkciji HDD-a) i kad dodjem kuci prvo tu muziku sredim (tagovi, coveri itd)- i onda se vratim na prvu recenicu u ovoj stavci. A ako neko hoce sa mog iPoda da skine muziku, ima programa za to koliko hoces.
5. Moj iPod nema spori interfejs, ili sam ja takodje spor pa mi tako sporo odgovara. 🙂
6. Sto se tice slika, mislim da niko normalan nije ocekivao nesto previse od ove funkcije na uredjaju za slusanje muzike (kao ni ja), ali mi odgovara kada npr. sa koleginicom idem na zurku pa sutra dan na kafi u gradu hoce da vidi slike sa zurke.
7. iTunes nije ******. Jeste u pocetku kada godinama koristis Winamp, ali naviknes se i ukapiras kako radi i posle ne mozes da verujes da si godinama koristio Winamp.
Nisam mislio da uplicem Mac vs. PC, ali vecina ljudi jedino sto vidi iz Apple sveta je samo iPod, koji sa navikama sa PC-a moze da bude nocna mora. Mac+iPod je mnogo bolja kombinacija koja radi savrseno i bez nerviranja.
Ovo gore je klasicni M$-ov FUD (Wikipedia: Microsoft soon picked up the art of FUD from IBM, and throughout the 80's used FUD as a primary marketing tool, much as IBM had in the previous decade. They ended up out FUD-ding IBM themselves during the OS2 vs Win3.1 years.). Naime, FUD je nesto sto je imanenetno M$-u i oni to rade. Citajte samo sta ***** Balmer o Apple-u i Google-u poslednjih par meseci.
Enivej...
1. IPod se grebe. Grebe se mozda vise nego ostali uredjaji, ali daleko od toga da ce se izgrebati bas toliko da postane neupoterebljiv. Uostalom, novi iPod Nano plejeri su totalno otporni na grebanje, kao i novi Shuffle. Verovatno ce iPod 6th generation biti slican. To je bar lako srediti, ako se koristi odgovarajuca plastika, koju Apple (samo) kod "video iPod-a" ne koristi.
2. Bateriju nisam nikada menjao, ali znam par ortaka koji jesu. U svakom slucaju, ljudima u Americi je ostavljeno vise izbora za zamenu baterije, jer lako mogu da nabave u radnji novu i zamane je sami, a isto tako mogu i da se prosetaju u Apple store i dobiju brzo svoj iPod nazad sa novom baterijom, za razliku od nas ovde koji bi u tom slucaju cekali mozda i par meseci. Ipak, ovaj FUD je pisan za US trziste, a ne za nase. Ne kazem da je situacija sa baterijom kod iPod-a idealna, ali je daleko od one kakvom je predstavljena u linkovanom FUD-u.
3. Who cares about FM kada imas prostor od 30 GB za skladistenje muzike? Kome treba uzasan kvalitet FM-a koji krci, stanice se gube dok vozis kola ili putujes? Ipak, ako je neko stvarno toliki mazohista i pored sopstvene muzike hoce da mu neki tzv. DJ pusta svoju Winamp listu i da mu sve to jos i krchi moze uvek da kupi dodatak za iPod koji je zvanicno predstavljen od strane Apple-a i donosi FM podrsku.
4. Sto se tice sinhronizovanja muzike, ne kapiram kako drugacije da se sinhronizuje nego tako. Sinhronizacija znaci pravljenje identicne kopije biblioteke muzike na dva uredjaja. Kome to ne odgovara uvek moze rucno, preko iTunes-a, da prevlaci pesme - ne mora da automatski sinhronozuje. Ne secam se nesto da je kod Zen-a drugacije - i ona se sihronizuje preko Media Player-a ili onog Creative softvera sa jednim racunarom, ako odaberes automatski sync. Da ne pricam da je za obicne korisnike Media Player ili Creative softver Nneuporedivo komplikovaniji za upotrebu.
5. 🙂
6. Ne kapiram u cemu je problem sa fotkama na iPod-u? Bolje od toga, u pokretu, mogao bi jedino notebook (a opet to nije problem, jer imate idneticu kopiju fotki na iPod-u i u iPhoto-u, pa sta je pri ruci). U svakom slucaju pregled fotki na iPod-u daleko je prijatniji od pregleda fotki na bilo kom mobilnom telefonu. Kod kuce niko nije lud da gleda fotke na iPod-u ili slusa muziku sa njega kada ima kucni HiFi i racunar za fotke. U kom smislu je pregled slika bolji npr. na iriver-u ili Creative-u ili Zune-u? Pregled slika nije komforan ni na jednom plejeru, ali je opet bolje gledati fotke tako kada racunar nije pri ruci nego putem mobilnog telefona.
7. Mozda, stvar navike rekao bih, ali kapiram sta su hteli da kazu.
ma ovo je klasicni marketinski spam...pa ako cemo ovako mozemo i onom maybach-u na sajmu da nadjemo sto i jednu manu...nesto mu je bila izduvana prednja leva guma, pa mi se ne svidja😀
1 Scratch Magnet
3 Doesn't flay fm
5 Slow interface
1. Crna povrsina? Ne bih rekao, moj je stalno u dzepu pantalona i jos nije ogreban. Odozdo jeste, ali zaista zanemarljivo.
2. Tutoriala za zamenu baterije ima po netu gde hoces. Tako da je vrlo lako mozes sam zameniti. Uostalom, ako si dao 250-300e za plejer, mozes jos 50 posle godinu - dve za zamenu baterije.
3. FM? A cemu to sluzi pored 30, 60 ili 80 gb prostora? Ajde neka mi neko realno kaze koji ce mu djavo FM pored tolikog prostora na koji moze da skladisti nekoliko razlicitih zanrova muzike i to u poprilicnim kolicinama?
4. Nije tacno, treba samo jedna opcija da se "odstiklira" i problem je resen.
5. A sta ti toliko radis na plejeru da ti je spor interfejs? To sto secne malo, nije uopste strasno. Uostalom, 95% vremena stoj iu dzepu tako da je brzina interfejsa krajnje nevazna.
6. Ako je Photo feature na iPodu smesan, onda je na iRiverima i Creative plejerima (da ne pricam o MS Industrial, Blackberry i sl.) jos smesniji. Da ne napominjem da je to svima "vazan" feature. Besmisleno.
7. To ko je napisao nema pojma o zivotu. Postoji gomila odlicnog 3rd party softvera koji to radi jos bolje od smornog iTunesa. Nisi obavezan da koristis iTunes a realno ne postoji opasnost po uredjaj ako se isti ne koristi.
Slazem se Itunes je uzasna gnjavaza, imam Ipod 30Gb i nano Gb. Kao mp3(4) player je nenadmasan, postoji konkurencija ali mu do sada nniko nije ni za prineti.
Jednia mana mu je taj Itunes sa kojim se covek muci dok ne oblentavi i navikne na to mucenje.
Sreca pa postoji odlican 3rd party softver koji sluzi kao zamena za bangavi iTunes.
Koji preporucujes ?
Probao sam Avanti i bar je kod mene uzasno spor...
Poz ljudi...kao vlasnik ipod 30gb 5.5g imam nedoumicu kako da znam da je to stvarno 5.5g....Ovako u about mi pise irod i verzija 1.2.1 na zadnjoj strani pise 2005 ali imam opciju search u meniju a cujem da je to za sada samo za 5.5g
Josh nesto koje sluske preporucujete za ipod...imam nejgove i takodje KOSS THE PLUG ali one kod jaceg basa treste znaci ne mogu da ga izguraju kako treba...
Hvala to mi je bilo vazno....A jel istina sto mi drug rekao da moze da se instalira Gameboy emulator i josh neki...E da koliko je opasno staviti Linux na njega...Uradio bi to ali ne znam da li je murderabilan
E pa mene zbog baterije to brine....a nista pusticu mu jedne gospodare prstenova od 3.5 sati pa da vidimo ako izgura super ako ne bice gadno....a prezivece se ....btw alergicansam na baterije
Odgurao je zacudjujuce ceo Fellowship of The Ring i josh bilo juice za sat i po muzike...nije lose nije lose...
A sada jedna molba...Tj pitanje...Dal je neko od vas radio zamenu baterije na Ipod-u...koliko to kosta(do it yourself) i da li je mnogo zeznuto...citao sam po netu i kaze se da je moguce...Jedini problem mi je to sto tih kit-ova i sardina nema kod nas nego preko a ja to ne mogu da izvedem tj da placam preko neta...
Btw ako ga punish svaka dva dana koliko bi trajalo dok ne pocne baterija da crkava...pod time mislim 3-4 sata muzike ili 1 sat video da samo izgura...
To je ustvari samo do softvera 1.2.1 taj search ... i brightness , inace razlika izmedju te 5g i 5.5g je samo u bateriji tj jacini iste zar ne ? Ja imam Ipod video 60Gb i sada softver 1.2.1 i naravno imam i search i brightness a takodje mi na poledjini pise godina 2005 ...
I ja imam 1.2.1 ali nigde nema search? Inace posedujem iPod video 30 Gb 5. generacije. Brightness podesavanja imam. Gde je taj search?!
Nije tacno. 1.2.1 na 5g iPod-u ne donosi search, samo brightness podesavanje.
PS: I ekran je bolji kod 5.5g iPod-a, zvanicno 60% svetliji u praksi - primetno svetliji.
The Fifth Generation "Enhanced" iPods also have improved software with a new screen brightness control, an advanced search function, and additional iconography. The original Fifth Generation iPods can be updated in software to add the screen brightness control but, at least when published (see top), not the search function.
http://www.everymac.com/systems/app...on-ipod-and-enhanced-5th-generation-ipod.html
Kod 5g iPod-a se pojavljuje ovo tokom skrolovanja, nakon sto se updateuje softver (isto je i kod 5.5g), ali to nije advanced search funkcija...
Da, upravo to... koji smor.... 5.5 generacija im je trebalo da se sete da ubace search? Uzas.
Da li postoji mogucnost Cross flasha? 😀
Hvala na informacijama ja sam sve to citao na sajtovima ali nisam video uzivo nista ... Ali opet je bolje i sto su stavili bilo kakav vid search-a makar taj kod skrolovanja , opet je dosta laksa pretraga 😉 pozZ
Izgleda da razlike ipak nisu samo do softvera.
Ja imam iPod Nano 2GB prva generacija, donesen iz Kanade, a drugarica ima novi Nano, i ona kada zavrti scroll duze vreme, izbaci joj abecedu da bira pesmu po pocetnom slovu. Ja to npr. na svom Nanou nemam iako je uradjen update na najnoviji softver.
