dekili68
Dragi moji pomagaci!!!Evo u cemu je moj problem.Vec sam imao instaliran zone alarm pro ,samo verzija 6.5.737....sada zelim da instaliram noviju verziju 7.0.302.....kada pokrenem instalaciju prvo dobijem info:"this application has failed to start because zpy.dll was not found.Re-installing the application may fix this problem."Odmah zatim dobijem i sledecu poruku:"setup is unable to log into yhe TrueVector service.Install cannot continue without logging into the TrueVector service.Please use the service manager to shut down the TrueVector service and then restart the installer program."
Napominjem da sam staru verziju deinstalirao i da mi se ovo dogadja pri instalaciji nove.U "SERVICES" sam trazio TRUEVECTOR service ali on nije prikazan..imam admin.prava,a i secam se da sam imao problema sa tim TrueVector sevicom i pri prvoj instalaciji.....Sta da radim narode,daj te pomazite!!!!!!!:wall: :wall:
