XP SP1 problem - Error With Add/Remove Programs Using Servic
kUdtiHaEX
Super ridža
Administrator
CPU & Cooler
Intel® Core™ i5-9500F, NZXT Kraken Z63
GPU
Asus GTX 2070 Super
Storage
Samsung 980 Pro NVMe 1 TB
Kućište
NZXT H210i
Monitor
LG C2 42"
Miš & tastatura
Logitech G502, Keychron K8, Nuphy Air75, Ducky TKL One 2
Ostale periferije
Glupi HP štampač
Laptop
Apple Macbook Pro 14" M1
Tablet
Apple iPad Pro 11"
Mobilni telefon
Apple iPhone 13 Pro Max
Pametni uređaji
Apple Watch Ultra
Pristup internetu
  1. Kablovski internet
Evo sta sam slucajno iskopao na jednom od sajtova..
I've noticed quite a few people asking questions about getting errors when using Add/Remove Programs, when Windows XP Service Pack 1 is installed, so I've decided to do a quick "How-To" Guide on fixing the problem.
Ovo me je zacudilo pa sam pronasao link..
http://www.winbeta.org/modules.php?name=News&file=article&sid=252
Kompletan clanak:
I've noticed quite a few people asking questions about getting errors when using Add/Remove Programs, when Windows XP Service Pack 1 is installed, so I've decided to do a quick "How-To" on fixing the problem.
Fixing the dreaded "Parser Message: Value creation failed " at line 472" error:
This is a problem with the file shellstyle.dll, which is included in most visual styles.
Use the following steps to fix the problem:
1.) Go to your /WINDOWS/Resources/Themes directory, or wherever you may have your themes located.
2.) Go into the directory of the theme your currently using.
Example: Using 'Semplice' by KoL? Navigate to /WINDOWS/Resources/Themes/Semplice
3.) Go into the folder called 'Shell" within the previous directory.
4.) Inside you'll find a folder with a file called 'shellstyle.dll' inside. Now remember the name of the theme your using? (Example: Semplice). You need to rename this folder from Shell to the name of the theme your currently using. If you don't know the exact name, go to Display Properties, and try to Display/Show the theme, the name you see in Display Properties is the name you need to change the 'Shell' folder to.
Example: Using Semplice as an example, the Shell folder for that theme is called 'Shell', in this situation you'll need to rename the folder to 'Semplice'. Easy enough, right?
Note that for multi-part themes, aka themes with more than one variation or color, you'll need to rename each corresponding 'Shell' folder to what is displayed in Display Properties when you try to apply the theme.
5.) Now that you've changed the 'Shell' folder name to correspond with the visual styles name, reapply the theme.
6.) Go to Add/Remove Programs, and voila! 😉
