Da li se neko igrao sa kamerom i slo-mo snimanjem? Koja su ograničenja, da li je samo deo snimka u slow motion ili može ceo? Ima li nekih ograničenja u dužini?
Treba da napravim neprekidan duži snimak (nekoliko desetina minuta, možda i dva sata, ako bude mesta) i da sve bude u 120fps. Može li to sa ugrađenom kamerom ili treba neka sa PS?
Nijedno ti ne pokriva ceo ekran. To je tehnologija koju izgleda kao rasa nismo savladali.
Mislim da ti je sigurnije da to uradiš preko servisa. Pogledaj par stranica unazad, napisao sam koji servis ima originalne baterije (bar tako oni kažu, a jesu zvanični servis za Xiaomi) i koliko košta.Jedno pitanje:
Gde kupiti kvalitetne baterije za Xiaomi telefone? Mi shop, kp, aliexpress?
Nemojte stavljati stakla na zakrivljene ekrane, stavite ili foliju ili hidro gel
Sent from my Mi A3 using Tapatalk
https://androidfilehost.com/?fid=17248734326145706205
CHANGELOG
System
New - MIUI 12.5 update
New - Android 11 update (Mi 9, Mi 9 SE, Mi 9T Pro, Mi 10T/Pro). Existing newest TWRP releases should work on these devices after Android 11 update (at least on Mi 9)
New - New super wallpapers: Geometry and Mount Siguniang
New - Nature mix is a new exciting way of creating your own notification sound system
New - Hundreds of system sounds that represent animals from all around the world
Optimization - Improved system stability and speed
Optimization - Updated Android Security Patch to January 2021 (Redmi Note 7)
Optimization - Updated Android Security Patch to December 2020 (most of devices)
Fix - Restored M font size (by xiaomi.eu)
Fix - Couldn't paste clipboard items on system apps
Notes
New - New tools for doodling and sketching
New - Press and hold a sketch to adjust the strokes automatically
New - A gesture shortcut now allows you to create notes, tasks, and excerpts anywhere
New - Excerpts save texts, URLs, and images to Notes in a few simple taps
New - Dynamic layouts make bring the typography in Notes to a new level
MIUI+
New - Redesigned Screen Combo to MIUI+
New - You can combine your phone and computer into a single working station (run apps, open notifications, make edits in documents, transfer files etc.). This feature is supported by selected devices: Mi 11, Mi 10 Ultra, Mi 10 Pro, Mi 10, Mi 9 Pro 5G, Mi 9, Redmi K30s Ultra/Mi 10T/Mi 10T Pro, Redmi K20 Pro/MI 9T Pro, Redmi K30 Pro/POCO F2 Pro
Security
New - Now you can see what apps access your clipboard and control access
New - Using approximate location adds up points to privacy protection
System launcher
New - New design for app folders
Fix - Action bar didn't show up when selecting a conversation
Fix - Removed useless Chinese setting from account settings
Gallery
Fix - Crashes in certain scenarios (e.g. while trying to make clip)
New - New photo editing layout
New - Few new photo filters, e.g. Midwinter, Snowfall, Sangria, Nightfall, Caramel
New - Added random sky filter feature
New - Added advanced settings for photo editing, e.g. exposure, color temperature, hue
New - ID photo feature, Art photo feature
Optimization - Reclassified photo filters
Themes
Optimization - Personalization features for system wallpapers, animations, and sounds
Clock
New - New hourglass animation for Timer (Snapdragon 888/865 devices)
Xiaomi Cloud
New - Password manager allows you to store passwords in the cloud
This update is suspended for Mi 9 Pro 5G, Mi 9 Lite, Redmi Note 8, Redmi Note 9 4G/Redmi 9T, Redmi Note 9 Pro 5G/Mi 10T Lite. These devices are expected to get this update on mid-or-late January 2021, with Android 11 update accordingly.
Starting from today, Redmi 7A, Redmi 8A and Redmi S2 are EOL for MIUI 12 stable - xiaomi.eu team won't support these devices (32-bit architecture).
To je to.
Neće se oštetiti ekran prilikom pada.
Najveća mana ove folije je što je ona sama osetljiva, i što se malo teze stavlja u odnosu na foliju i staklo
Tako da i ako je nevidljiva na ekranu može da se ošteti noktima, rajsfeslusom, ili nekim oštrim predmetom inace leži perfektno na ekranu.
Najbolje da odmah uzmeš dve može da se desi da ne umes da je staviš i tako upropastis, i ako na videu izgleda jako prosto.[emoji16]
Redmi 9T, jel su ovo mislili na mi 9t? To znači da očekujemo official update januara?
Da li je neko koristio miui 12 na a11? Kakvo je iskustvo?
Ne vidim kakve to ima veze. Ako želiš da promeniš hardver van garancije.Da, ali samo za telefone legalno uvezene.
Ne kapiram kako misliš da ti obična folija zaštiti staklo od lomljenja?! Pogotovo mi nije jasno kako može bolje da štiti od kaljenog stakla.Kao poprave se same od sebe posle oštećenja?
Kazu da štite bolje od stakla...
Ja sam pokušao 2x da zalepim i nijednom nije dobro prošlo, mnogo je teze nego kad se staklo lepi jer ode iz tri poteza. Najbolje nekom iskusnom dati.
Kako radi fp skener sa tom folijom btw?
Šaomi i njihovi nazivi [emoji1749][emoji15][emoji28]Redmi 9T je nesto sto tek treba da izadje.
https://www.gsmarena.com/xiaomi_redmi_9t_launch_date_unboxing_video-news-46986.php
Ova nije obična, već je višestruko deblja. Mislim da je debljine kao i staklo možda malkice tanja. Ne znam, kažu da bolje amortizuje udarce, gledao neke YouTube recenzije. Ko će ga znati.Ne kapiram kako misliš da ti obična folija zaštiti staklo od lomljenja?! Pogotovo mi nije jasno kako može bolje da štiti od kaljenog stakla.
Pa znam šta je hydrogel folija, imam je na leđima telefona. To štiti samo od ogrebotina.
To je vise u teoriji nego sto je u praksi tako.Kao poprave se same od sebe posle oštećenja?
gel na ledjima nije nikakva zastita osim od ogrebotina.Pa znam šta je hydrogel folija, imam je na leđima telefona. To štiti samo od ogrebotina.
https://www.theandroidportal.com/hydrogel-screen-protector-vs-tempered-glass/?amp=1
https://www.pcmag.com/news/what-kind-of-screen-protector-should-i-get-for-my-phone
Ovde kažu da ipak staklo bolje zaštiti.
Zbog toga i razmišljam da zalepim najobičniju foliju, fp senzor mi je bio jako spor sa prošlim, očigledno debljim staklom, sada sa ovim drugim je ok ali bih voleo da bude još brži. Ionako mi telefon nikad ne ispada. Bukvalno nikad.To je vise u teoriji nego sto je u praksi tako.
posto je u pitanju mekani gel poput neke oni racunaju da ako je bilo nekog deformiteta da ce se posle nekog vremena on sam vratiti u prvobitno stanje, naravno da to retko tako bude
da li bolje stite od stakla?
Staklo je dosta deblje od gela, tako da verujem da fizicki bolje stiti.
FP u ekranu najbolje radi sa obicnom folijom, gel i staklo su daleko iza.
Ali kada stavis telefon u case i na ekran stavis gel skoro da nema sanse da se razbije.
nemoze gel na ledjima nikako da te zastiti od loma ekrana jer je dovoljno da ti telefon padne na ivicu i slomice se
bitno je da ivica telefona i sam ekran ne udari direktno u podlogu prilikom pada, zato je neka futrola neizbezna a na ekran onda sta god da stavis tel je 99% siguran.
Clanak je malo bez veze,
kao prvo mi svi kupujemo kineske hidrogelove i kineska stakla pa nama gel, staklo, ili folija sve to kosta skoro isto tako da nama cena nije presudna prilikom odabira.
Staklo je deblje i sigurno da bolje stiti na sredini,
ali polemika se povela zbog toga sto staklo ne pokriva ivice, a hidrogel savsreno pokriva te ivice i gotovo je neprimetan na ekranu
