WORD problem
  • Začetnik teme Začetnik teme to3a
to3a
Naime kad dodjem sa kucanjem do kraja stranice ne otvori se automatski next page nego kursor jednostavno nestane na neku drugu nevidljivu stranu.
Pokusao sam da ga repair preko help pa detect and repair (shto mi je pomagalo da excelom). Sad ide kombinacija insert/break/next page
jel ima neko predlog shta da uradim da se vrati na stara setovanja.
Naravno uradio sam i remove pa opet install celog office-a al avaj pamti dechko negde u winxp setovanja i je8e me gadno.
Svaka sugestija ce pomoci.
Evo sta bi mogao da uradis (ako se radi o Wordu 2003): napravi novi shortcut za Support Template.
Desni klik na desktop>New>Shortcut pa u polju koje se otvorilo pastuj ovo
---begin copy here---
"C:\Program Files\Microsoft Office\Office11\Winword.exe" /a "C:\Program Files\Microsoft Office\Office11\Macros\Support.dot"
---end copy here---
Nakon dvoklika na novokreirani shortcut, u Wordu ce ti se otvoriti stranica sa nekoliko veoma korisnih alata sa kojima mozes da popravis Word bez reinstalacije. Naravno, ovo vazi ako si Word (Office) instalirao complete (pri instalaciji si cekirao sve komponente). Ako nisi, postupi po tackama:
1. Click Start, and then click Control Panel.
2. Click Add or Remove Programs.
3. Click Change or Remove Programs.
4. In the Currently installed programs list, click your version of Microsoft Office 2003 (for example, click Microsoft Office Professional Edition 2003), and then click Change.
5. Click Add or Remove Features, and then click Next.
6. In Custom Setup, click to select the Choose advanced customization of applications check box, and then click Next.
7. In the Choose update options for applications and tools list, follow these steps: a. Expand Microsoft Office Word.
b. Expand Wizards and Templates.
c. Click the icon for More Templates and Macros, and then click to select Run all from my computer.
8. Click Update to install the Support Template.
ma samo obrisi "normal.dat" i sve ce biti ok
