Ako imate neku ideju javite, ovaj tip sa microsoft foruma ima identicne probleme kao i ja:
microsoft podrska se ne oglasava po ovom pitanju, a problem je postojao i na visti.
Hvala
Kod:
-- Drive is recognized by Windows 7 (can be seen in Explorer and Device Manager)
-- BIOS will recognize discs and prompt for booting (should the disc be a boot disc)
-- I have tried removing the Upper and LowerFilters in the registry; NEITHER value existed when I searched for them
-- I have uninstalled the drive, both physically and via device manager
-- I have run Devcon to determine the parameters of the drive; this is the resulting information:
IDE\CDROMHL-DT-ST_DVD-RAM_GH22NS30_________________1.02____\5&F23758A&0& 1.0.0
Name: HL-DT-ST DVD-RAM GH22NS30 ATA Device
Setup Class: {4d36e965-e325-11ce-bfc1-08002be10318} CDROM
Controlling Service:
cdrom
1 matching device(s) found.
-- Have verified that both the power and data cables ARE seated properly
-- Have updated the firmware (from version 0 to 1, and then 1 to 2); issues existed in every firmware upgrade
Hvala
