Taj eunetov modem je ujedno i wifi ruter? Ako je tako jel mozes da ga prebacis u bridge mode?
Napisao je vec da je eunetovom modemu iskljucio wifi.
@DaPimp I iz opisa a I iz svog iskustva s DIR-635 mislim da je problem u njemu. Za moj ne postoji drugi firmware ali mislim da bi tebi moglo da bude resenje ddwrt. Ne postoji cini mi se nista sto nisam probao da resim taj problem ali nisam uspeo - kada sam juce procitao tvoj post pomislio sam da je nesto u vezi samog dlink firmware-a, nekog feature-a koji je poceo da bude destruktivan ...a posto sam u logovima pronalazio puno blokiranih upita I sa IP samog provajdera pa cak I ako je iskljucen firewall I ako sve razlabavim, to mi je dalo ideju da iskljucim (po defaultu ukljucenu I korisnu) opciju nevidljivosti za ping. Nisam siguran da li je resenje I da li je samo splet okolnosti ali danas imam znatno manje pucanja wifi-a, mozda tri za ceo dan. Da, posto ta pucanja bivaju najcesca ujutru, meni je ovaj moj rezon bio logican - kao da me ruter stiti od precestih upita tako sto prosto iskljuci wifi ...dok ne dozivim demanti verovacu da sam na pravom tragu a ti probaj ovo, ko zna mozda I jeste pravi put.
For DSL routers, ‘bridge mode’ commonly refers to switching off the router part of your combined DSL-modem-and-router, leaving it as a DSL-modem-and-bridge.
Blocked incoming TCP packet from 157.55.130.173:40021 to 213.198.203.252:63126 as FIN:ACK received but there is no active connection
Blocked incoming TCP packet from 173.45.120.200:80 to 213.198.203.252:63277 as FIN:ACK received but there is no active connection
Blocked incoming TCP packet from 173.194.69.188:443 to 213.198.203.252:54828 as FIN:ACK received but there is no active connection
Blocked incoming TCP packet from 64.40.9.6:2133 to 213.198.203.252:62891 as PSH:ACK received but there is no active connection
Blocked incoming TCP packet from 173.45.120.200:80 to 213.198.203.252:63279 as FIN:ACK received but there is no active connection
Blocked outgoing TCP packet from 192.168.1.7:63169 to 173.194.113.184:443 as ACK received but there is no active connection
Blocked incoming TCP packet from 64.40.9.6:2133 to 213.198.203.252:62891 as FIN😛SH:ACK received but there is no active connection
Issuing request for offer for INTERNET PPPoE Session
Above message repeated 1 times
Offer of service open.telekom.rs accepted for INTERNET PPPoE Session
Offer received for INTERNET PPPoE Session, service offered is open.telekom.rs from brasgub (00308811D1B3)
Discovering PPPoE servers for INTERNET PPPoE Session
Trying to establish INTERNET PPPoE connection
Attempting to start always-on WAN connection
Bringing up WAN using PPPoE
WAN interface cable has been connected
LAN interface is up
LAN Ethernet Carrier Detected
Device initialized
Wireless schedule init
No Internet access policy is in effect. Unrestricted Internet access allowed to everyone
Opcija je ovde:...Mozes li da mi kazes putanju do te opcije, posto nisam siguran da je nalazim...
