VMWare workstation 7 guest OS problem
Doomhammer
Pozdrav.
Instalirao sam Slackware 13 linux u virtualnu mašinu na VMWare Workstation 7. Prilikom kreiranja mašine podesio sam da ima dve mrežne karte. Nakon instalacije linuxa i pokretanja komande ifconfig vidim da linux guest nije prepoznao mrežne adaptere. vmware-tools-e sam uz manje poteškoće instalirao. Komanda lspci -v daje slijedeci izlaz:
02:01.0 Ethernet controller: Advanced Micro Devices [AMD] 79c970 [PCnet32 LANCE] (rev 10)
Subsystem: Advanced Micro Devices [AMD] PCnet - Fast 79C971
Flags: bus master, medium devsel, latency 64, IRQ 19
I/O ports at 2000
[virtual] Expansion ROM at dc400000 [disabled] [size=64K]
Kernel driver in use: vmxnet
Kernel modules: vmxnet, pcnet32
02:02.0 USB Controller: VMware USB2 EHCI Controller (prog-if 20 [EHCI])
Subsystem: VMware USB2 EHCI Controller
Flags: bus master, fast devsel, latency 64, IRQ 16
Memory at d8900000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: ehci_hcd
Kernel modules: ehci-hcd
02:04.0 Ethernet controller: Advanced Micro Devices [AMD] 79c970 [PCnet32 LANCE] (rev 10)
Flags: bus master, medium devsel, latency 64, IRQ 18
I/O ports at 2080
[virtual] Expansion ROM at dc410000 [disabled] [size=64K]
Dakle to su ta dva adaptera koja sam dodao prilikom kreiranja virtualne masine.
Provjerio sam komandom lsmod i modul vmxnet je ucitan u kernel. Takodje nisam skontao kako da umjesto ovih PCnet32 adaptera koristim Intel e1000 adaptere. Da li se nekome ovo desavalo, ili neko zna u cemu je problem???
P.S. Ovo dobijem kucanjem ifconfig komande
bash-3.1# ifconfig
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Jesi li instalirao VMware Tools unutar virtuelne mašine ?
Jesi li probao putem komande netconfig da setujes ručno IP adresu ?
Možeš i da probaš komandom
ifconfig eth0 192.168.1.2 netmask 255.255.255.0 up
mesto 192.168.1.2 umetni IP adresu koja tebi treba.
Prebacio sam u Linux podforum.
I daj output od lspci komande
Da. VMWare tools sam instalirao unutar virtualne mašine.
Komande netconf i ifconf mi ne pomažu jer sistem ne prepoznaje mrežne adaptere. Dakle nema eth0 i eth1. Pogledaj gore u drugoj poruci koji je ispis komande ifconfig. Samo loopback interfejs.
Nego napravio sam slijedeće, zakačio sam PCLinuxOS 2010 live cd na virtuelnu mašinu i butao sa CD-a i PCLinuxOS je uredno prepoznao mrežne adaptere, ali sam primjetio da on koristi pcnet32 kernel modul a ne vmxnet kao u Slackwareu. Komandom modprobe pcnet32u Slacku nisam ništa postigao.
P.S. Da, ispade da tema spada u Linux podforum jer problem nije do VMWare Workstationa, mada i dalje stoji pitanje da li se može Workstation natjerati da kao mrežne adaptere koristi one bazirane na "e1000"?
Još nešto,
U prvoj poruci ima output lspci -v komande (onaj dio koji se odnosi na mrežne adaptere) a u attachmentu ove poruke je kompletan output lspci komande, dakle bez -v flaga.
  • lspci-complete.txt
    2.8 KB · Pregleda: 35
Izlistavanje svih mreznih interfejsa i onih koji nisu setovani ide sa
Kod:
ifconfig -a
U svakom slucaju prvo pokusaj da load-ujes modul za mreznu kartu sa
Kod:
modprobe pcnet32
Proradilo. Kako ? Neznam. Sinoć ugasim virtualnu mašinu I danas kad sam je upalio vidim da su prepoznate mrežne karte.
