acep
Masina od telefona za samo 120$! Ili ipak samo plastikaner
Specifications
Brand Vernee
Model Thor
Color Grace Black / Metal Grey
Dimensions 142 x 70.3 x 7.9mm
Weight 140g ( with battery )
Box Size: 96.5 x 169.5 x 43mm
Operating system Android 6.0
CPU MTK6753 Octa Core
GPU ARM Mali-T720 MP3 450MHz
RAM 3GB
ROM 16GB (Miro SD card Up to 128GB)
Battery 2800mAh (Typ.)
Display
Size 5.0 inch
Resolution HD 720 x 1280 pixels
Type On-cell LTPS IPS; 2.5D Screen; 5-point touch?
Material Corning Gorilla Glass 3
Cameras
Rear camera 13MP
Front camera 5MP
Video HD 720P,1080P
Connection
Network Network type: FDD-LTE+WCDMA+GSM
2G: GSM 900/1900/2100MHz
3G: WCDMA 900/2100MHz
4G: FDD-LTE 800/1800/2100/2600MHz
SIM Dual sim dual standby, Micro SIM and Micro SIM
Both SIM slots are compatible with 4G, respectively.
WiFi WiFi 802.11 b/g/n, Wi-Fi 2.4GHz
Bluetooth Bluetooth 4.0
Positioning GPS, A-GPS,
Gravity Sensor,
Ambient Light Sensor,
Touch Sensor, OTG
https://www.youtube.com/watch?v=oKoBIu39kZU
Ako ga neko pazario neka se pohvali ovde.
Specifications
Brand Vernee
Model Thor
RAM 3GB
Display
Size 5.0 inch
Cameras
Rear camera 13MP
Front camera 5MP
Video HD 720P,1080P
Connection
Gravity Sensor,
Touch Sensor, OTG
