System mechanics
  • Začetnik teme Začetnik teme petri
petri
Keep your PC running faster, cleaner, and error-free with System Mechanic's full set of 15 powerful tools. Streamline your Registry by finding and removing invalid information. Find and remove debris left behind on your system by untidy programs, system freezes, and sudden system restarts. Turbocharge your Internet connection with NetBooster, a tool that will boost your system's performance in just a few clicks.
Windows Customizer allows you to fine-tune various settings in Windows that affect appearance, security, and performance. Keep sensitive information secure by eliminating the tracks you leave behind. Use the Incinerator tool to securely delete sensitive files and data. Dispose of private items properly with this unique tool that operates as a secondary and more secure Recycle Bin. Find and automatically fix Windows shortcuts, and clean up your Start Menu. System Mechanic tracks your use of its tools, providing you with complete reports of actions performed with all tools. It even keeps track of how much each tool has benefited you over time.
Jel probao neko ovaj soft?
dosta korisnih alatki u svega 1.5MB, mislim da bi trebalo imati ovo.
Oce ga neko na mail pa da ga okaci na web? 🙂
Koristim ga vec nekih godinu i po dana ili mozda i vise, ne secam se...odlicna stvar, vrlo korisna i nikad ne pravi nikakve probleme.
Topla preporuka. Inace lako se skida sa sajta proizvodjaca i lako se crac...ups, sorry, necemo o tome ! 😛 ctp;
petri je napisao(la):
kazi link za download.
ps. petri, ti si isao u nisku gimnaziju bora stankovic ili se varam?
Re: Re: System mechanics
kustera je napisao(la):
skinuo sam ga sa under-a tako da ga imam u arhivi zajedno sa ser... 🙂
inace nemam pojma odakle moze da se skine :d
a jeli, odakle znas da sam iso u Boru? 😕
Jerbo sam i ja zavrsio istu gimnaziju, samo generacija iza tebe. Cak smo se i jednom upoznali dok si radio sajt za skolu (mislim da si ti radio sajt). Ja sam radio sledecu verziju tog istog sajta.
