Sound Forge
  • Začetnik teme Začetnik teme cilebg
cilebg
Hocu da snimam kako pevam karaoke. Kako da podesim Sound Forge 9 da snima i iz izvora zvuka sa kompa(da bi se snimljena muzika cula kako treba u punoj jacini i kvalitetu) i mene sa mikrofona. Da li je to u Visti izvodljivo?(ne snalazim se bas ni oko volume controla drugaciji je od xp-ovog)
Upali i cekiraj "what u hear" u recording properties
jel to u opcijama zvucne ili Sound Forge-a? ne mogu da nadjem...
Pa za zvucnu kartu 😉 Dole na onom zvucniku
snasao sam se, hvala na pomoci.googlovo sam what you hear i nasao resenje
Windows Vista and recoding "What you hear" (How to!)
Anyone in windows vista, and wishing to use the creative option "What you hear" or similare (Realtek has this feature named as "Stereo Mix" and various other sound cards devices have it named various other things as well)
This feature isn't highly used by many people, but anyone that wishes to perhaps "Capture" audio WITH thier video, this feature is initially extremely hard to track down on a vista machine.
Most people will encounter this problem when they perhaps use a program called "Fraps", a neat little program that allows you to CAPTURE video/audio of any 3D Application that may be running, however by default, frap won't be able to find the correct audio input device at all, as by default, window vista forcefully hides/disables this (probably for content protection measures)
Heres the fix, now listen closely, (If a problem arises and a visual how to is required and the demand for it is high enough, i CAN post screenshots on how to do this)
Go into your control panel under vista, and by default, vista will show a although user friendly, a much to simplified version of the control panel, up on the left hand side there should be an option for "Classic View" Select this:
Now in the classic view of the control panel, open up "SOUND"
Click on the RECORDING Tab
Now usually you'll only have one, maybe 2 things in this list, heres what you do,
Right click anywhere in the white area of this list
A sub menu should appear
Click on "Show Disabled Devices"
Now the list should grow and allow you to select "What you hear" or "Stereo Mix" or similare option. You must select the disabled "What you hear" or "Stereo Mix" and right click on it to select "Enable"
If a device isn't listed yet, another sub menu option MAY be available for "Show hidden devices", hopefully this will give you all the rest of the options.
Now to get fraps to use this audio device, you must select the "What you hear" or "stereo Mix" and right click to set it as "default"
From there you should have no problems exiting fraps and restarting it to get the correct audio device.
NOTE: IT IS recommended that you LEAVE the recording "what you hear" or "stereo mix" volume slider at it's default, first record something and then adjust it as you see fit.
samo sto kad stavim stereo mix(kog sam enable-ovo) kao default, ne radi mi snimanje mikrofonom, ali kad vratim na mikrofon default radi super... juuuupii 🙂
Sad me zanima kako da stereo fajl pretvorim u ujednačen, da se jednako čuje na levom i desnom zvučniku? Znači da glas sa jednog zvučnika spoji sa muzikom sa drugog zvučnika? Da bude iste jačine? Kako na najlakši način to uraditi u SF?
    109.3 KB · Pregleda: 30
negde ima opcija channel converter, zaboravio sam gde. :S:
hvala, vrlo je lako za pronaci-proceses-channel converter... slabo sam koristio program pa nisam znao za to..pre sam koristio samo win-ov sound recorder 🙂
sad me još nešto zanima.baš sam smarač :d .... kako da u SF-u uradim sledeće: npr. snimam pesmu(mp3, ne karaoke) iz winampa, i pevam uz nju, pesma se snimi na jednom zvučniku, ja na drugom. kako da uradim da izmiksuje levu i desnu stranu tako da kada pevam(kad je u mom kanalu glas) smanji jačinu pevača(pesme) iz originalne mp3 pesme, a kad ide muzika u drugom kanalu, kad ja ne pevam (kad se ne čuje ništa na mom kanalu) da se muzika čuje u punoj jačini...Jel može to da se odradi sa SF-om, ili treba neki dodatni(VST) plugin?
još me ovo zanima. jel zna neko?
