Prodajem/menjam Sentry 2.0 mini-ITX kuciste
bibby
Potpuno novo kuciste vrhunske izrade
Ogranicena serija
Izuzetno kvalitetno i elegantnog izgleda
Kvalitetan powder coating u crnoj boji izgleda izuzetno
Kuciste kupljeno u okviru Indiegogo kampanje na cijoj stranici postoji detaljan opis
Na YT postoji 10ak testova ovog kucista
Cena: 350
MAIN BODY DIMENSIONS
340 x 310 x 66mm, 6.96L Volume
MOTHERBOARD FORMAT
Mini-ITX
POWER SUPPLY SUPPORT
SFX 100mm, SFX-L is not supported
Custom internal pass-through power cord with flexible C13 plug enabling support for multiple power connector orientations
CPU COOLER FORMAT
Max 47mm tall, may obstruct first 2.5" mount depending on motherboard layout
Max 37mm tall, regardless of the layout
120mm AIO Liquid Cooler, 47mm max pump height, 50mm max radiator+fan height
GRAPHICS CARD FORMAT
Dual-Slot, Full-Length 12"/305mm
Reference-Sized PCB/Max 18mm oversize
Dual-Slot, ITX-Length 6.9"/175mm
For use with 120mm AIO CPU Liquid Cooling
STORAGE DRIVE MOUNTS
2x 2.5" drive mounts on central rail
2x 3.5" drive mounts in graphics chamber
(obstructing GPU and AIO Liquid Cooling)
MEMORY COMPATIBILITY
Standard profile DIMM modules, max 31.4mm tall pcb/34mm with heatspreaders.
Tall modules will obstruct hard drive bracket and are not recommended for builds with 120mm AIO CPU Liquid Cooling
FRONT PANEL
2x USB 3.0 type A Connectors
16mm anti-vandal momentary power switch with 5v red ring power status LED
PCI-E RISER
Two-piece rigid PCB PCI-E Riser
with high quality multi-layer PCB
PCI-E 3.0 x16 support
CASE BODY MATERIAL
1mm thick galvanized steel
high-graininess structural powder coating
HORIZONTAL ORIENTATION
4x 20mm wide 6.5mm tall riveted feet
4x 12mm wide 6mm tall adhesive feet
Case cover inlet creating air pocket inside graphics card chamber for safe cover temperature and improved thermal performance
VERTICAL ORIENTATION
2mm thick galvanized and powder coated vertical stand with rubber contact areas
Toolless mounting with two sliding bolts.
4x 8mm hole plugs in place of chassis feet
WIRELESS SUPPORT
3x RP-SMA compatible holes for antennas
SECURITY MEASURES
Kensington Security Slot
(with stainless steel backing)
MAIN BODY WEIGHT
2.625kg
    28.5 KB · Pregleda: 168
    126.3 KB · Pregleda: 166
    116.6 KB · Pregleda: 173
    152.3 KB · Pregleda: 181
    160.1 KB · Pregleda: 178
    15.1 KB · Pregleda: 182
    51.3 KB · Pregleda: 173
    56.7 KB · Pregleda: 175
    58.8 KB · Pregleda: 166
