223BW
Samsung SyncMaster 223BW je wide monitor dijalgonale 22 in?a koji isporu?uje oštar tekst i žive boje.Odziv mu je 5ms. Ekran poseduje kontrast od 1000:1 (DC 3000:1), osvetljenje od 300 cd/m2, rezoluciju od 1680 x 1050, ugao vidljivosti od 170 stepeni horizntalno i 160 vertikalno, kao i frekvenciju osvežavanja od 30-81kHz horizontalno i 56-75Hz vretikalno. SyncMaster 223BW nudi mogu?nost koriš?enja digitalnog ili analognog interfejsa za pregled slika i teksta. DVI interfejs osigurava oštriju i ?istiju sliku kao i ta?niju reprodukciju originalnog video izvora. SyncMaster 223BW je dostupan u crnoj boji
2232BW
Panel Viewable area 22" Wide
Pixel Pitch(mm) 0.282 x 0.282
Brightness(cd/?)(typ.) 300 cd/?
Contrast Ratio(typ.) DC 3000:1 (1000:1)
Viewing Angle(H/V) 170?/170? (CR>5)
Response Time(ms)(typ.) 2(GTG)
Frequency Horizontal Frequency(kHz) 30 ~ 81
Vertical Frequency(Hz) 56 ~ 75
Maximum Resolution 1680x1050
Color Supported 16.7 Mil.
Signal Input Input Video Signal Analog RGB, DVI
Sync. Type Separate H/V, Composite , SOG
Input Connectors D-sub, DVI-D
Plug & Play DDC 2B
USB powered hub option -
Mac compatibility
Power On Mode 50W
DPMS Mode <1 Watt >
Type Built-in
Multimedia Speakers -
Wall-Mount -
TCO -
Cabinet Color Black High Glossy
Other include accessories
Dimension Set(W*H*D)(mm) (with stand) 517*419*210
Set(W*H*D)(mm) (w/o stand) 517*372*70
Packing(W*H*D)(mm) 600*437*132
Weight Set(kg) 4.95
Packing(kg) 6.5
Special Features DVI(HDCP) .MagicBright3 .High Glossy Black
Stand Type Simple
Function Tilt
