ROGastic project
nessa78
3.5" Floppy
Hello friends,
Guided by the need for the ultimate workstation machine, I throw myself into a project that consists of a complete change of the interior and a bit of the exterior of the CM Cosmos 25th edition case.
As you can see in the renders below, I plan to insert a large EKWB 540 radiator and provide airflow through the air tunnel with 4x120mm fans. This project also includes a complete EKWB LC system for which I will specially customize the custom distro/reservoire.
Hardware:
ASUS ROG Strix Z490 A-Gaming
Intel i9 10900
Adata XPG SPECTRIX D50 DDR4-3600Mhz RGB 4x8Gb
Adata XGP SPECTRIX S40G RGB M.2 1Tb
Cooler Master V1000 Platinum
Cooler Master MasterFan MF120 Halo White Edition
EKWB all water cooling parts and components
I know this case has been redesigned many times but I will do my best to make something different!
Thanks for following!
BR neSSa :)
nessa78
3.5" Floppy
Izrada unutrasnjih, pregradnih alu elemenata:
nessa78
3.5" Floppy
Maticna ploca je stigla, prelepa belo/silver ROG Strix z490, savrseno se uklapa u moju ideju o ovom projektu :)
nessa78
3.5" Floppy
Cutting, grinding, sanding ...
nessa78
3.5" Floppy
Cooler Master V1000, mora biti bele boje :)
nessa78
3.5" Floppy
Uradjena plastifikacija na delovima gde je to bilo planirano, ista nijansa sive kao sto su EKWB fitinzi :D
nessa78
3.5" Floppy
Ooooo kako se dobro uklapaju ovi "saten" fitinzi uz CPU block :)
nessa78
3.5" Floppy
Adata XPG Spectrix D50 4x8Gb 3600Mhz :)
I kratki video:
nessa78
3.5" Floppy
EK-Loop Vertical GPU Holder, zaista profi izradjen :)
nessa78
3.5" Floppy
XPG Spectrix S40G 1Tb
i kratki video raspakivanje :)
nessa78
3.5" Floppy
Displej (1024x800) za front kucista je stigao :)
nessa78
3.5" Floppy
CM SK650 tastatura i MM711 mis ce biti modovani kao deo ovog projekta :)
Hvala Cooler Master na podrsci!
nessa78
3.5" Floppy
Ofarbao sam backpalte graficke karte u istu nijansu kakvi su i fitinzi :)
nessa78
3.5" Floppy
Na kraju ipak promena tipa ventilatora, ovi mi se vise uklapaju u dizajn :)
nessa78
3.5" Floppy
Fino brusenje, instalacija alu maski i displeja na front panelu :)
nessa78
3.5" Floppy
Nasmestio sam masku oko displeja i stigli su SSD-I :)
DukeLander
Moderator
Super Moderator
Neso, pitanjce: npr da nabavis 3d sla stampac, pravis custom unilatne nosace i delove za svoje projekte?
Sent from my CPH1951 using Tapatalk
