gadafi je napisao(la):Postoji li neki program za glasovnu komunikaciju u LAN-u koji omogucava p2p razgovor bez povezivanja na neki server?
Do skora sam koristio SkyPe, ali dusmani (administartori) pozatvarase sve portove.
IPi Phone v0.7 build 715 (c) Olej
http://www.aolej.com
IPi Phone is internet IP to IP telephone software that allows you
to talk and use text chat. IPi Phone is easy to use. All you need
to know is the other person IP address and you can connect to them
and start talking over the internet for free.
You can use secure communication and voice modification.
It allows you to keep your privacy and stay anonymous.
Communication can be encrypted with AES (160 bit key length).
Password should be exchanged over other channel.
grozda je napisao(la):Ovaj sam probao i radi savrseno ... ne ide preko servera vec direktno preko IP adrese racunara tako da nema gubitaka u zvuku da ide do servera i nazad. Interfejs je takav kakv jeste, noviju verziju nisam probao.
Moguc razgovor u lokalnoj mrezi ali i preko interneta. Podrazumeva se da obe strane imaju isti program.
