Radeon R9 280X problem
  • Začetnik teme Začetnik teme Kovac
Kovac
od pre nekog vremena - preinstalirao sam win - desavaju mi se jako cudne stvari sa kompom - a mislim da je sve vezano sa grafikom - u pitanju je Asus Radeon R9 280X
cesto mi se desava kad prelazim sa jednog usera na drugog - da jednostavno nema slike, monitor se ugasi ali vidim da komp i dalje radi i kombinacijom tastera alt+f4 i enter - uspem da ga ugasim
to se desava i kad pokrenem neke igre - nema nekig pravila - ponekad i kad ode u sleep to se desi
par puta mi je izbacio i ovu poruku
pokusao sam sa razlicitim verzijama drajvera 18.12.1 pa onda 18.12.2 - i sad 18.12.3
evo otprilike ovo je moja konfiguracija
Model:
Operating System: Windows 10 Enterprise Edition build 17763 (64-bit)
Motherboard Manufacturer: SAPPHIRE
Motherboard Model: Pure Black P67 Hydra
Motherboard Version: SIP67065
BIOS Manufacturer: American Megatrends Inc.
BIOS Version: 4.6.5
BIOS Release Date: 2014/02/06
CPU Information:
Manufacturer: GenuineIntel
Type: Intel Core i5-3570K @ 3.40GHz
Codename: Ivy Bridge
CPUID: Family 6, Model 3A, Stepping 9
Socket: LGA1155
Lithography: 22nm
Number of CPU's: 1
Cores per CPU: 4
Logicals per Core: 1
Clock Frequencies:
Measured Speed: 3392.6 MHz [Turbo: 4490.2 MHz]
Multiplier: 34.0X
Bus Speed: 99.8 MHz
Front Side Bus Speed: (N/A)
Timing Error Ratio: 1.000
Cache per CPU package:
L1 Instruction Cache: 4 x 32 KB
L1 Data Cache: 4 x 32 KB
L2 Cache Size: 4 x 256 KB
L3 Cache: 6 MB
Memory Information:
Total Physical Memory: 8157MB
Available Physical Memory: 5252MB
Memory Devices:
Slot 1: 4GB DDR3 SDRAM PC3-10600
Patriot Memory (PDP Systems) PSD34G133381, serial#: 117440512, yr: 2102
1.5V, Clk: 666.7MHz, Timings 9-9-9-24 (@ Max. freq.)
Slot 2: 4GB DDR3 SDRAM PC3-10600
Video Adapters:
Video Card 1: AMD Radeon R9 280X
SLI/Crossfire Enabled: No
Chip Type: AMD Radeon Graphics Processor (0x6798)
DAC Type: Internal DAC(400MHz)
Memory: 3072MB
Video BIOS: 113-AD47800-100
Driver Provider: Advanced Micro Devices, Inc.
Driver Version: 25.20.15002.58
Driver Date: 12-6-2018
Monitor 1: 1680x1050x32 60Hz 96 DPI (Primary monitor)
Monitor 2:
Temperatures:
CPU 0: 45.5C (Maximum: 45.5C)
CPU Core 0: 48.0C (Maximum: 52.0C)
CPU Core 1: 38.0C (Maximum: 47.0C)
CPU Core 2: 39.0C (Maximum: 49.0C)
CPU Core 3: 41.0C (Maximum: 49.0C)
Hard Disk 0: 34.0C (Maximum: 37.0C)
Hard Disk 1: 35.0C (Maximum: 38.0C)
Hard Disk 2:
Hard Disk 3:
GPU 0: 34.0C (Maximum: 39.0C)
Vrati se na još starije drajvere. 18.10.1 ili starije.
Bilo je priče o bagovima sa 18.12 drajverima, pa moguće da si i ti zapatio neki.
A moguce je i da karta polako odlazi u vecna lovista.
ne baš večna lovišta.
kod problema sa blek skrinom i drajverima koji neće da se instaliraju (a karta radi sa windows generic drajverom) POMAŽE RERNA.
190c i 10 minuta, okruglo, u stepen, u sekundu. (skini hladnjak prvo, naravno, i omotaj plastične delove alufolijom.
ako se problem ponovo javi, ponovo rerna. rinse and repeat.
*mjau**mjau**mjau**mjau*te zamisli ženu da vidi za Božić grafičku u rerni umesto praseta .... pa mene bi ubacila u nju
Instalirao sam ove starije drajvere - pa da vidim šta će biti
Koje je napajanje?
probaj sa asus gputweak-om ili nekim sličnim softverom da nakucaš konstantno 3d klokove i kako će na njima da se ponaša.
Sad je počeo na običnom alt+ tab da se zacrni ekran .... probaću - hvala
Još jednostavnije, obori u katalistu (overdrive) GPU i Vram taktove za po 150 MHz, a power limit POVEĆAJ za 15 posto.
ako mu je nestabilno u 2d režimu neće mu to pomoći,može da edituje bios ali ovo je lako rešenje da samo utvrdi gde je problem.
za nestabilnost u 2d režimu (blek skrinovi, problemi sa powerplay režimima) , isključivo rerna.
A mozda je napajanje neispravno. Ili nadji drugu karticu da testiras racunar ili drugi racunar da testiras karticu. Da ne peces kartu bez veze jer je tako mozes upropastiti
Sent from my MI 5s using Tapatalk
nije isključivo,znam i više od jedne karte koje rade perfektno ili sa editovanim biosom ili nakucanim klokovima i to duže vremena.ja bi to pek'o samo kao zadnju soluciju kad 3d režim neće da radi.
