Problem u XP-u
  • Začetnik teme Začetnik teme bibby
bibby
Od kako sam bio prinudjen da instaliram neko budjavo programce zarad downloada rom-ova sa neta vise ne mogu da otvorim Add or Remove Programs. Pojavi se message: "Value creation failed " at line 472"
Da li se jos nekom desilo nesto slicno, i na koji nacin da sada uninstaliram odredjene programe.
Add-remove cupa informacije odavde "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall".Tu mozes da vidis sta on pokrece za uninstall programa
As to se tice toga sto se desilo, ***...nem' pojma 🙂
p. s. ovaj kljuc je iz win2k, ali je isti i na '98 pa bi trebalo da je takav i na XP-u
Hvala, probacu kad dodjem kuci. Ma meni ne gine reinstalacija sistema, ali pre toga moram napraviti huge backup, koji ce potrajati - a neki programi mi smetaju pa sam hteo da ih se lisim, al' slaba vajda.
Amon_Ra je napisao(la):
A prilikom reinstalacije i ne moras bas formatirati hard.Pokreni normalnu instalaciju winxp-a(znaci digni sistem sa win98 sistemske diskete pa startuj winnt)a onda umesto da instaliras odaberi da ti popravi trenutnu instalaciju(ali ne pomocu recoveru console)
LENJA BUBO!!!!
samo da si otkucao u google-u poruku koju izbaci ...ti lenjivce jedan!! 🙂
Fixing the dreaded "Parser Message: Value creation failed " at line 472" error. This is a problem with the file shellstyle.dll, which is included in most visual styles. Use the following steps to fix the problem: 1.) Go to your /WINDOWS/Resources/Themes directory, or wherever you may have your themes located.
2.) Go into the directory of the theme your currently using.
Example: Using 'Semplice' by KoL? Navigate to /WINDOWS/Resources/Themes/Semplice
3.) Go into the folder called 'Shell" within the previous directory.
4.) Inside you'll find a folder with a file called 'shellstyle.dll' inside. Now remember the name of the theme your using? (Example: Semplice). You need to rename this folder from Shell to the name of the theme your currently using. If you don't know the exact name, go to Display Properties, and try to Display/Show the theme, the name you see in Display Properties is the name you need to change the 'Shell' folder to.
Example: Using Semplice as an example, the Shell folder for that theme is called 'Shell', in this situation you'll need to rename the folder to 'Semplice'. Easy enough, right?
Note that for multi-part themes, aka themes with more than one variation or color, you'll need to rename each corresponding 'Shell' folder to what is displayed in Display Properties when you try to apply the theme.
5.) Now that you've changed the 'Shell' folder name to correspond with the visual styles name, reapply the theme.
6.) Go to Add/Remove Programs, and voila! 🙂
D-KEE majstoru!!! Ima da smenimo drapina oma 😀, pa nisam ja tebe za dz pustio da me dobijes u basketu 😀. Salu na stranu hvala ti, ovo je pomoglo.
