jorgovan
Ogranicena mi je brzina na 70000bits/sec. Evo sta dobijem:
Downstream Channel
The data shown in the table below provides information about the signal coming from the network to your cable modem.
Downstream Status Operational
Channel ID 0
Downstream Frequency: 703000000 Hz
Modulation: 64QAM
Bit Rate 70000 bits/sec
Power Level 6.1 dBmV
Signal to Noise Ratio :39.5 dB
Upstream Channel
Upstream Status Operational
Channel ID 4
Upstream Frequency 34000000 Hz
Modulation QPSK
Bit Rate 30000 bits/sec
Power Level 44.0 dBmV
Inace imam paket 128. Zasto mi je brzina smanjena? Da nije nesto do kabla i kolike su vama vrednosti za Power Level i Signal to Noise Ratio???
Sta da radim? Da proveravam kablove i kako ili da vidim sa njima??? Mazda jesam malo vise skidao, ali nigde ne pise da ne smem da skidam koliko hocu...
Downstream Channel
Channel ID 0
Modulation: 64QAM
Upstream Channel
Channel ID 4
Modulation QPSK
