babac90
Cenjen
eh ovako, ljudi pomazite molim vas.
maloprije sam instalirao Cyanogenmod RC 7.1 na moj optimus 2x i radio sam prema uputstvima sa wikipedije.
"Method via ROM Manager
Launch RomManager.
Optional: Choose the first option in the app, Flash ClockworkMod Recovery to update to the latest version.
Select the Download ROM option from the main menu in the ROM Manager.
Select the CyanogenMod option, and then choose the latest version of CyanogenMod from the menu.
Optional: When you select the latest version of CyanogenMod, check the Google Apps* option.
Once the ROM is finished downloading, it asks if you would like to Backup Existing ROM and Wipe Data and Cache.
If Superuser prompts for root permissions check to Remember and then Allow.
The LG Optimus 2X will now reboot into the recovery, wipe data and cache, and then install CyanogenMod. When it's finished installing it will reboot into CyanogenMod. "
i sve sam uspjesno zavrsio i instalirao. Kada je doslo vrijeme da se pokrene mobitel, stalno mi se ovo desava:
Znam da bi mi pola vas predlozilo servis ali ako postji ikakav nacin da se ovo popravi bez servisa molim vas objasnite mi :S
Launch RomManager.
