Problem sa paljenjem MBP-a
  • Začetnik teme Začetnik teme Stator
Stator
Kada upalim MBP nekada se zakuca na logou jabuke kada vrti onaj kruzic. Jenostavno taj kruzic prestane da se vrti i to je to komp nece da se upali koliko god ga dugo ostavio.
OS je 10.6.3
Kacim kernel.log onaj deo kod koga je stao. Posle ovoga se opet ponavlja jer sam resetovao komp. Napominjem da ni drugi put nije hteo da se upali vec tek iz 4 puta. Nekada se ovo desi a nekada se upali iz prve.
May 28 17:29:54 localhost kernel[0]: npvhash=4095
May 28 17:29:54 localhost kernel[0]: PAE enabled
May 28 17:29:54 localhost kernel[0]: 64 bit mode enabled
May 28 17:29:54 localhost kernel[0]: Darwin Kernel Version 10.3.0: Fri Feb 26 11:58:09 PST 2010; root:xnu-1504.3.12~1/RELEASE_I386
May 28 17:29:54 localhost kernel[0]: vm_page_bootstrap: 901223 free pages and 81817 wired pages
May 28 17:29:54 localhost kernel[0]: standard timeslicing quantum is 10000 us
May 28 17:29:54 localhost kernel[0]: mig_table_max_displ = 73
May 28 17:29:54 localhost kernel[0]: AppleACPICPU: ProcessorId=0 LocalApicId=0 Enabled
May 28 17:29:54 localhost kernel[0]: AppleACPICPU: ProcessorId=1 LocalApicId=1 Enabled
May 28 17:29:54 localhost kernel[0]: calling mpo_policy_init for TMSafetyNet
May 28 17:29:54 localhost kernel[0]: Security policy loaded: Safety net for Time Machine (TMSafetyNet)
May 28 17:29:54 localhost kernel[0]: calling mpo_policy_init for Quarantine
May 28 17:29:54 localhost kernel[0]: Security policy loaded: Quarantine policy (Quarantine)
May 28 17:29:54 localhost kernel[0]: calling mpo_policy_init for Sandbox
May 28 17:29:54 localhost kernel[0]: Security policy loaded: Seatbelt sandbox policy (Sandbox)
May 28 17:29:54 localhost kernel[0]: Copyright (c) 1982, 1986, 1989, 1991, 1993
May 28 17:29:54 localhost kernel[0]: The Regents of the University of California. All rights reserved.
May 28 17:29:54 localhost kernel[0]: MAC Framework successfully initialized
May 28 17:29:54 localhost kernel[0]: using 16384 buffer headers and 4096 cluster IO buffer headers
May 28 17:29:54 localhost kernel[0]: IOAPIC: Version 0x11 Vectors 64:87
May 28 17:29:54 localhost kernel[0]: ACPI: System State [S0 S3 S4 S5] (S3)
May 28 17:29:54 localhost kernel[0]: mbinit: done (64 MB memory set for mbuf pool)
May 28 17:29:54 localhost kernel[0]: rooting via boot-uuid from /chosen: 8C5DCCE0-8675-3FA1-A168-FD36EA2EE995
May 28 17:29:54 localhost kernel[0]: Waiting on <dict ID="0"><key>IOProviderClass</key><string ID="1">IOResources</string><key>IOResourceMatch</key><string ID="2">boot-uuid-media</string></dict>
May 28 17:29:54 localhost kernel[0]: com.apple.AppleFSCompressionTypeZlib load succeeded
May 28 17:29:54 localhost kernel[0]: AppleIntelCPUPowerManagementClient: ready
May 28 17:29:54 localhost kernel[0]: wl0: Broadcom BCM432b 802.11 Wireless Controller
May 28 17:29:54 localhost kernel[0]: 5.10.91.27
May 28 17:29:54 localhost kernel[0]: Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@B/AppleMCP79AHCI/PRT0@0/IOAHCIDevice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/Hitachi HTS543232L9SA02 Media/IOGUIDPartitionScheme/Customer@2
May 28 17:29:54 localhost kernel[0]: BSD root: disk0s2, major 14, minor 2
May 28 17:29:54 localhost kernel[0]: jnl: unknown-dev: replay_journal: from: 1272320 to: 1490432 (joffset 0x951000)
May 28 17:29:54 localhost kernel[0]: FireWire (OHCI) Lucent ID 5901 built-in now active, GUID 002332fffed5d5dc; max speed s800.
May 28 17:29:54 localhost kernel[0]: jnl: unknown-dev: journal replay done.
May 28 17:29:54 localhost kernel[0]: AppleIntelCPUPowerManagement: initialization complete
May 28 17:29:56 localhost kernel[0]: NVEthernet: Ethernet address 00:23:32:d5:d5:dc
May 28 17:29:57 localhost kernel[0]: AirPort_Brcm43xx: Ethernet address 00:23:12:57:71:42
May 28 17:29:57 localhost kernel[0]: IO80211Controller::dataLinkLayerAttachComplete(): adding AppleEFINVRAM notification
May 28 17:29:58 localhost kernel[0]: systemShutdown false
May 28 17:30:02 localhost kernel[0]: Waiting for DSMOS...
May 28 17:30:14 localhost kernel[0]: NVDANV50HAL loaded and registered.
May 28 17:30:14 localhost kernel[0]: Warning - jp.plentycom.driver.SteerMouse declares no kernel dependencies; using com.apple.kernel.6.0.
May 28 17:30:14 localhost kernel[0]: AGC: 2.8.56, HW version=1.7.3, flags:0, features:4
May 28 17:30:15 localhost kernel[0]: Previous Shutdown Cause: 3
May 28 17:30:15 localhost kernel[0]: DSMOS has arrived
May 28 17:30:16 localhost kernel[0]: AirPort: Link Down on en1. Reason 8 (Disassociated because station leaving).
evo i system.log
May 28 17:29:47 localhost com.apple.launchd[1]: *** launchd[1] has started up. ***
May 28 17:29:55 localhost DirectoryService[15]: Improper shutdown detected
May 28 17:29:58 localhost bootlog[41]: BOOT_TIME: 1275060586 0
May 28 17:29:59 localhost fseventsd[34]: event logs in /.fseventsd out of sync with volume. destroying old logs. (62955 13 63098)
May 28 17:30:00 localhost fseventsd[34]: log dir: /.fseventsd getting new uuid: 5229A488-AABB-40A1-8233-C1F21624F700
May 28 17:30:01 localhost com.apple.launchd[1] (com.apple.aslmanager): Throttling respawn: Will start in 7 seconds
May 28 17:30:05 localhost blued[17]: Apple Bluetooth daemon started
May 28 17:30:12 localhost VMware Fusion 261058[56]: Starting VMware Fusion:
May 28 17:30:12 localhost com.vmware.launchd.vmware[45]: VMware Fusion 261058: Starting VMware Fusion:
May 28 17:30:12 localhost com.apple.launchd[1] (com.apple.aslmanager): Throttling respawn: Will start in 6 seconds
May 28 17:30:13 localhost mDNSResponder[29]: mDNSResponder mDNSResponder-214.3 (Feb 11 2010 04:49:16) starting
May 28 17:30:15 localhost com.apple.usbmuxd[21]: usbmuxd-190 built for iTunesNineOne on Mar 8 2010 at 20:25:36, running 32 bit
El ima neko ideju sta je u pitanju ?
Koliko vidim 'onako s nogu' problem je mozda u journal logovima file sistema. Kao da kada si radio shutdown nije uradjen korektno, ne mora da znaci da je HDD u problemu (da te odmah utesim 😉). To moze da bude i zbog prevelikih sistemskih logova kod UNIX OS-a.
Predlazem sledece, ne moze da skodi, a moze da pomogne:
sudo launchctl stop com.apple.syslogd
sudo launchctl stop com.apple.aslmanager
sudo mv /var/log/asl/* ~/tmp
sudo launchctl start com.apple.syslogd
Odradi ove komande u konzoli, pa reboot-uj sistem.
V...
Odaradio sam:
sudo rm -Rv /var/log/*
Sada cu da vidim da li je to pomoglo.
Odaradio sam:
Uh, ti to bas voles radikalno 😛 A'e daj Boze. Mada nisam siguran da je obrisao ceo log dir jer su aktivni logger daemon procesi...
:fingers crossed:
Naravno zaustavio sam procese 🙂 Ono sto je najgore sto se ovo ne desava svaki put pa ne mogu lepo da testiram :/
Uh ok 😀 Pa nista, prati sad logove, narocito ovaj deo
Ako se ne bude pojavljivao ubuduce, onda bi trebalo da bude sve ok.
Nek je sa srecom, V....
Ponovo se desilo. I ovaj put nemam nista u logovima u trenutku neuspelog paljenja.
Razmisljam se da uradim restore permision, nesto mi se bas i ne rainstalira system :/
Damn...
Permission repair obavezno uradi ako nisi, i proveri pod system info sta raportira smart za HDD. Pade mi napamet i da proveris pod tvojim accountom login iteme, tj. sta se startuje od util-a kad se logujes, mozda nesto i od skorije instaliranih aplikacija pravi problem, posto videh u tvojim logovima npr. da imas vmware instaliran.
Mada, cini mi se da je i dalje najveci problem sto ti se sistem ne obori regularno...grrrr
U svako slucaju nek je sa srecom, i ne zuri sa reinstalom, to je bar lako na OSX 😛
V..
da, pokreni neki system test util... mislim da TechTool ima dobar i sveobuhvatan test ali ako ti se komp blokira samo pri paljenju onda je nesto najverovatnije ili do diska ili do systema. podigni ponovo OS sa "restore" opcijom. ako i dalje nastavi da se blokira moraces cist instal bez restorea... (sacuvaj user folder i application folder negde sa strane pa samo vrati fajlove koji ti trebaju... npr. keychain...)
