Problem sa Nvidia drajverima
freestyler
Cenjen
Prvi problem je bio sa blue screen of death pri svakom startovanju racunara. Kada se pojavi BSOD ja restartujem i sve ide normalno.
Ovo je pisalu u BSOD-u:
A problem has been detected and your windows has been shut down to prevent
damage to your computer.
Attempt to reset the display driver and recover from timeout failed
If this is the first time you've seen this stop error screen,
restart your computer. If this screen appears again, follow
these steps:
Check to make sure that any new hardware or software is properly installed.
If this is a new installation, ask your hardware or software manufacturer
for any windows updates you might need.
If problems continue, disable or remove any newly installed hardware
or software. Disable BIOS memory options such as caching or shadowing.
If you need to use Safe Mode to remove or disable components, restart
your computer, press F8 to select Advanced setup options, and then
select Safe Mode.
Technical Information:
*** STOP: 0x00000116 (0x86B08510, 0X8E4D31A0, 0X00000000, 0X00000002)
*** nvlddmkm.sys - Adress 8E4D31AO BASE AT 8E414000, dATE sTAMP 4abfff9d
Collecting data for crash dump...
Initializing disk for crash dump ...
Beginning dump of physical memory.
Dumping physical memory too disk: 100
Physical memory dump complete.
Contact your system admin or technical support group for further assistance.
To sam resio instaliranjem najnovijih nvidia drajvera.
Sada nema BSOD ali se javlja drugi problem - svaki put moram da instaliram nvidia drajvere. Kada idem u Device manager-display adapters-Nvidia ge force 9600 gt update driver softvare-browse my computer for driver software-let me pick from a list of device drivers on my computer pojavi mi se prozor (stavio sam sliku), Ja izaberem Nvidia Ge Force 9600 GT i idem na Next i drajveri se instaliraju.
Jako me iritira sto se ovo desava svaki put kad startujem racunar. Probao sam sa reinstalacijom i sve se ponavlja. Da li neko zna u cemu je mozda problem?:wall:
P.S. Izvinjavam se zbog predugacke poruke!
    23 KB · Pregleda: 86
Kada upalim racunar IRQ graficke karte mi je 5 i nema aero efekta a kad ga restartujem onda je IRQ 16.
Na IRQ 16 ima 5 stvari. Sta bi mogao da uradim dea mi IRQ graficke karte uvek bude 16? Kako da promenim IRQ?
    98.7 KB · Pregleda: 47
Ne mozes ozbiljno uticati na raspodelu sistemskih resursa, ovde je izgleda problem u drajveru iako bas nemam istorijat na raspolaganju. Najbolje sto mi pada na pamet je da ako si imao ranije podesen drajver, udjes u safe mode i odande uradis Roll Back drajvera pomocu Device Manager-a ili da ga prosto uklonis. Vrlo je bitno da se uradi iz safe mode-a.
Problem je konacno resen!!!!!!!!!!!!! :banana:
Samo sam izvadio graficku i vratio je i sve je normalno.:smash:
Ne mogu da verujem, a toliko sam se patio.
