Odes u My Documents, pa Command and Conquer Generals Data ili Command and Conquer Generals Zero Hour Data, vec zavisno sta pokreces, i tu kreiras u notepad-u novi fajl koji sacuvas kao options.ini
Obrati paznju na ekstenziju. Prilikom snimanja dole odaberes umesto txt -> all files, da bi snimio kao ini fajl.
U samom dokumentu ubacis ovo
AntiAliasing = 2
BuildingOcclusion = yes
CampaignDifficulty = 0
DrawScrollAnchor = yes
DynamicLOD = no
ExtraAnimations = yes
GameSpyIPAddress = 0.0.0.0
Gamma = 50
HeatEffects = yes
IPAddress = 0.0.0.0
IdealStaticGameLOD = Low
LanguageFilter = false
MaxParticleCount = 5000
MoveScrollAnchor =
MusicVolume = 50
Resolution = 1440 900
Retaliation = yes
SFX3DVolume = 72
SFXVolume = 64
ScrollFactor = 145
SendDelay = no
ShowSoftWaterEdge = yes
ShowTrees = yes
StaticGameLOD = Custom
TextureReduction = 0
UseAlternateMouse = yes
UseCloudMap = yes
UseDoubleClickAttackMove = no
UseLightMap = yes
UseShadowDecals = yes
UseShadowVolumes = yes
VoiceVolume = 78
i sacuvas. Rezoluciju naravno podesi onu koju koristis.
Zatim desni klik na precicu i pod compatibility podesis XP sp3 i otkacis run as admiinistrator.
I to je to. Radi i na Win7 x64.
Igra se iz nekog razloga zaglupi i ne kreira automatski ovaj options.ini fajl i zbog toga se ne pokrece.
