Problem sa geforce 5200 fx
MarsiPulami
Imam problem sa ovom karticom ali bash cudan, kad god pokrenem 3d igricu racunar ni se zaledi, restartujem ga i onda je sve ok, radi bez problema, inace probao sam je kod prijatelja i kod njega radi bez problema, mjenjao sam verzije directx i drivera tako da nije do toga ,)
Inace imam Plll na 933 mhz, sa 768 mgb sdram, ploca asus tuv4x, i bios Award Medallion v6.0
Jos nesto ne prepoznaje mi bus, mogu maksimalno dici na 2x a ono je 4...
Evo log fila kad mi se jednom sam restartovao :wall: :wall: :wall: :wall:
Watchdog Event Log File
LogType: Watchdog
Created: 2005-08-18 03:15:28
TimeZone: -60 - Central European Standard Time
WindowsVersion: XP
EventType: 0xEA - Thread Stuck in Device Driver
// The driver for the display device got stuck in an infinite loop. This
// usually indicates a problem with the device itself or with the device
// driver programming the hardware incorrectly. Please check with your
// display device vendor for any driver updates.
EaRecovery: 1
ShutdownCount: 252
Shutdown: 0
EventCount: 3
BreakCount: 3
BugcheckTriggered: 1
DebuggerNotPresent: 1
DriverName: nv4_disp
EventFlag: 1
DeviceClass: Display
DeviceDescription: NVIDIA GeForce FX 5200
HardwareID: PCI\VEN_10DE&DEV_0322&SUBSYS_80DF1043&REV_A1
Manufacturer: NVIDIA
DriverFixedFileInfo: FEEF04BD 00010000 0006000E 000A1C15 0006000E 000A1C15 0000003F 00000008 00040004 00000003 00000004 00000000 00000000
DriverCompanyName: NVIDIA Corporation
DriverFileDescription: NVIDIA Compatible Windows 2000 Display driver, Version 71.89
DriverFileVersion: 6.14.10.7189
DriverInternalName: nv4_disp.dll
DriverLegalCopyright: (C) NVIDIA Corporation. All rights reserved.
DriverOriginalFilename: nv4_disp.dll
DriverProductName: NVIDIA Compatible Windows 2000 Display driver, Version 71.89
DriverProductVersion: 6.14.10.7189
Ako ko moze pomoci neka javlja, dobije bombonu od mene
Instaliran mi je vec 9.0c, sto se tice drivera nije do toga, bio sam uradio format pa ih reinstalirao ponovo (Version 71.89) i nije radilo. Sve 3d igre zaledi :crash: :crash:
Probacu ponovo sa ovim cleanerom pa ti javim ,)
Nisu ti drajveri za tu kartu, dakle obavezno probaj sa 56.64 ili 66.93.
Voodoo_NBGD je napisao(la):
Probao sam nije u tome problem, odradio sam kako mi je cova rekao bez ikakvih promjena je
:crash: :crash: :wall: :wall:
Cekaj, da li je u bios-u namesteno 2x ili 4x AGP ???
posto je to ploca sa via chipsetom a i starija je malcice
ja bi probao sa novim biosom
i via hyperion drajverima
naravno ako je grafika ispravna i ako su podesavanja u biosu ok
expertski zakljucak
btw.
MarsiPulami je napisao(la):
exr je napisao(la):
4X
@ filo: i ja sam kontao tako neshto, kad flasujem bios javicu, i da ako imas kakv link za te drajvere bio bih zahvalan 🙂
i da txs za ovo na kraju :smoke:
Flashovao sam bios na 1005 i nista, opet isto? sta sad?? :wall:
Stvarno neznam.Sve si probao.Da li je ta kartica ikada radila dobro na tom kompu(u 3d)?
Mozda se jednostavno ne mirise sa plocom pa nece.Stvarno neznam!
I da li mozda sumnjas na neku drugu komponentu npr. memorija ili napajanje...???
Kontao sam da je do rama ili napajanja, proverio sam nije, a nije radila nikako od kako sam je nabavio na ovom kompu
Nista uzmi od ortaka karticu pa probaj kod tebe da li radi.Ako da tu tvoju prodaj i uzmi neku drugu.
