Problem oko instalacija Linuxa (UEFI)
tesseract
Poštovan
Pozdrav svima. Imam sledeci problem.
Konfiguracija je Intel Pentium G4400, Asus H110M-A, 850 EVO 250GB.
Na ovoj konfi sam koristio samo Windows 8.1, ali zelim da odradim dual boot: Win 8.1 + Linux Mint Cinnamon.
Dakle, fomatirao sam ssd, pritom obrisao Windows, i podelio ga na dve particije (ntfs + ext4).
Kad sam pokrenuo live usb instalaciju Linux-a, pojavljuje se sledeca poruka:
"Force UEFI installation?
This machine's firmware has started the installer in UEFI mode but it
looks like there may be existing operating systems already installed using
"BIOS compatibility mode". If you continue to install Debian in UEFI mode,
it might be difficult to reboot the machine into any BIOS-mode operating
systems later.
If you wish to install in UEFI mode and don't care about keeping the
ability to boot one of the existing systems, you have the option to force
that here. If you wish to keep the option to boot an existing operating
system, you should choose NOT to force UEFI installation here."
Ako idem na "force", instalacija se nastavi i onda se prekine sa porukom: "The 'grub-efi-amd64-signed' package failed to install into /target/. Without the GRUB boot loader, the installed system will not boot"
Sledio sam razna uputstva sa neta, ali posto sam Linux pocetnik, nisam uspeo da nadjem resenje.
Procitao sam da problem pravi UEFI koji je dosao na novijim plocama umesto starog BIOS-a.
